RMT Patch 8
229 replies to this topic
#1 analmux OFFLINE
analmux
  • 2,392 posts
Posted Sat Feb 7, 2015 9:00 AM
Here is the official RMT 1.28 Patch 8.
See the attached zip-file. One test-file included: "Test1" (Test1.rmt and Test1.xex). Any questions? Answers & other examples will be next time.
And here are some background topics:
AtariAge Forums - Atari Systems - Atari 8-Bit Computers - RMT 1.28 Patch 8 theory
AtariAge Forums - Atari Systems - Atari 8-Bit Computers - RMT 1.28 no bugs?
AtariAge Forums - Atari Systems - Atari 8-Bit Computers - How to improve the PoKey "NOTE-2-PITCH" table, compared to RMT.
AtariAge Forums - Atari Systems - Atari 8-Bit Computers - More about PoKey 16-bit mode and 'distortion guitar'
#2 analmux OFFLINE
analmux
  • 2,392 posts
Posted Sat Feb 7, 2015 9:24 AM
And here's the final table schedule:
Patch 8 Table:
RMT          PoKey        Bits:  Clock:    Number     Instrument
distortion:  distortion:                   of bytes:  name:
0            0            8      x         x          White noise
2            2            8      1.79 MHz  48         Poly 5 / Generator 2
4            A            8      1.79 MHz  36         Sawtooth / Triangle
6            C            8LSB   1.79 MHz  32         Clarinet (Poly 4), LSB
8            A            8HSB   1.79 MHz  64         Harmonic square undertones of Clarinet / Distortion guitar, HSB
A            A            8      15 kHz    48         Pure bass
A            A            8      1.79 MHz  12         Pure flute
C            C            8      1.79 MHz  31         Poly 4 (degenerate 1)
C            C            8      1.79 MHz  17         Poly 4 (degenerate 3)
E            8            8LSB   1.79 MHz  32         Distortion guitar (Poly 9), LSB
Edited by analmux, Sat Feb 7, 2015 9:24 AM.
#3 emkay OFFLINE
emkay
  • 9,892 posts
  • What's up?
Posted Sat Feb 7, 2015 1:48 PM
I like your effort with those instruments.  But, due to the changes, other important stuff gets lost.
Here a quick test. At the start at 15kHz and it turns to 64khz mode later.
Possibly it shows my intentions ;)
The guitar is a great addon...
If just the 16 bit resolution was usable for all types of instruments
Carefull, it's very noisy ;)
#4 analmux OFFLINE
analmux
  • 2,392 posts
Posted Sat Feb 7, 2015 3:24 PM
Could you also post your .rmt version?
#5 emkay OFFLINE
emkay
  • 9,892 posts
  • What's up?
Posted Sun Feb 8, 2015 3:02 AM
Ofcourse...
#6 emkay OFFLINE
emkay
  • 9,892 posts
  • What's up?
Ofcourse...
#7 analmux OFFLINE
analmux
  • 2,392 posts
Posted Sun Feb 8, 2015 7:20 AM
Thanks.
The 16-bit 'distortion guitar' works best when you use RMT-distortion 8 instead. It looks a bit mysterious, but the HSB (highest significant byte) has a full automodulation control.
If you use command 2 (at voice 2), then (X/,Y\) = (0,0) gives a modulation of 0. If f.e. (X/,Y\) = (0,6) = $06, then the automodulation speed is not zero, and it sounds a bit like an electric distortion guitar effect. Backwards automodulation, then you compute a binary minus of $06, i.e. $00-$06=$FA.
#8 analmux OFFLINE
analmux
  • 2,392 posts
Posted Sun Feb 8, 2015 10:41 AM
And here's an 'Overview Orchestra', more details of post 2. It is a detailed scheme table scale of all the Patch 8 positibilies:
	RMT distortions:
	2:	4:	6:	8:	8:	A:	C:	C:	E:
	PoKey distortions:
	Dist 2:	Dist A:	Dist C:	Dist A:	Dist A:	Dist A:	Dist C:	Dist C:	Dist 8:
Note:							(deg 1) (deg 3)
G#0	-	-	-	-	32	-	-	-	-
A0	-	-	-	-	33	-	-	-	-
A#0	-	-	-	-	34	-	-	-	-
B0	-	-	-	-	35	-	-	-	-
C1	-	-	-	-	36	0 (*1)	-	-	-
C#1	-	-	-	-	37	1 --	-	-	-
D1	-	-	-	-	38	2	-	-	-
D#1	-	-	-	-	39	3	-	-	-
E1	-	-	-	-	40	4	-	-	-
F1	-	-	-	-	41	5	-	-	-
F#1	-	-	-	-	42	6	-	-	-
G1	-	-	-	-	43	7	-	-	-
G#1	-	-	-	-	44	8	-	-	32
A1	-	-	-	-	45	9	-	-	33
A#1	-	-	-	-	46	10	-	-	34
B1	-	-	-	-	47	11	-	-	35
C2	-	-	-	-	48	12	-	-	36
C#2	-	-	-	-	49	13	-	-	37
D2	-	-	-	-	50	14	-	-	38
D#2	-	-	-	-	51	15	-	-	39
E2	-	-	-	-	52	16	-	-	40
F2	-	-	-	-	53	17	-	-	41
F#2	-	-	-	-	54	18	-	-	42
G2	-	-	-	-	55	19	-	-	43
G#2	-	-	-	-	56	20	-	-	44
A2	-	-	-	-	57	21	-	-	45
A#2	-	-	-	-	58	22	-	-	46
B2	-	-	-	-	59	23	-	-	47
C3	0	0	-	0	60	24	-	-	48
C#3	1	1	-	1	61 (*3)	25	-	-	49
D3	2	2	-	2	62 (*3)	26	-	-	50
D#3	3	3	-	3	63 (*3)	27	-	-	51
E3	4	4	-	4	-	28	-	-	52
F3	5	5	-	5	-	29	-	-	53
F#3	6	6	-	6	-	30	-	-	54
G3	7	7	-	7	-	31	-	-	55
G#3	8	8	-	8	-	32	-	-	56
A3	9	9	-	9	-	33	-	-	57
A#3	10	10	-	10	-	34	-	-	58
B3	11	11	-	11	-	35	-	-	59
C4	12	12	0	12	-	36	-	-	60
C#4	13	13	1	13	-	37	-	-	61 (*3)
D4	14	14	2	14	-	38	-	-	62 (*3)
D#4	15	15	3	15	-	39	-	-	63 (*3)
E4	16	16	4	16	-	40	-	-	-
F4	17	17	5	17	-	41	-	-	-
F#4	18	18	6	18	-	42	-	-	-
G4	19	19	7	19	-	43	-	-	-
G#4	20	20	8	20	-	44	-	-	-
A4	21	21	9	21	-	45	-	-	-
A#4	22	22	10	22	-	46	-	-	-
B4	23	23	11	23	-	47	-	-	-
C5	24	24	12	24	-	-	-	-	-
C#5	25	25	13	25	-	-	-	-	-
D5	26	26	14	26	-	-	-	-	-
D#5	27	27	15	27	-	-	-	-	-
E5	28	28	16	28	-	-	-	-	-
F5	29	29	17	29	-	-	-	-	-
F#5	30	30	18	30	-	-	-	-	-
G5	31	31	19	31	-	-	-	-	-
G#5	32	32	20	-	-	-	-	-	-
A5	33	33	21	-	-	-	-	-	-
A#5	34	34	22	-	-	-	-	-	-
B5	35	35	23	-	-	-	-	-	-
C6	36	-	24	-	-	-	0	-	-
C#6	37	-	25	-	-	-	1	-	-
D6	38	-	26	-	-	-	2	-	-
D#6	39	-	27	-	-	-	3	-	-
E6	40	-	28	-	-	-	4	-	-
F6	41	-	29	-	-	-	5	-	-
F#6	42	-	30	-	-	-	6	-	-
G6	43	-	31	-	-	-	7	-	-
G#6	44	-	-	-	-	-	8	-	-
A6	45	-	-	-	-	-	9	-	-
A#6	46	-	-	-	-	-	10	-	-
B6	47	-	-	-	-	-	11	-	-
C7	-	-	-	-	-	-	12	-	-
C#7	-	-	-	-	-	-	13	-	-
D7	-	-	-	-	-	-	14	-	-
D#7	-	-	-	-	-	-	15	-	-
E7	-	-	-	-	-	-	16	-	-
F7	-	-	-	-	-	-	17	-	-
F#7	-	-	-	-	-	-	18	-	-
G7	-	-	-	-	-	-	19	31	-
G#7	-	-	-	-	-	-	20	32	-
A7	-	-	-	-	-	-	21	33	-
A#7	-	-	-	-	-	-	22	34	-
B7	-	-	-	-	-	-	23	35	-
C8	-	-	-	-	-	-	24	36	-
C#8	-	-	-	-	-	-	25	37	-
D8	-	-	-	-	-	-	26	38	-
D#8	-	-	-	-	-	-	27	39	-
E8	-	-	-	-	-	-	28	40	-
F8	-	-	-	-	-	-	29	41	-
F#8	-	-	-	-	-	-	30	42	-
G8	-	-	-	-	-	-	-	43	-
G#8	-	-	-	-	-	-	-	44	-
A8	-	-	-	-	-	-	-	45	-
A#8	-	-	-	-	-	-	-	46	-
B8	-	-	-	-	-	-	-	47	-
C9	-	-	-	-	-	48 (*2)	-	-	-
C#9	-	-	-	-	-	49 --	-	-	-
D9	-	-	-	-	-	50	-	-	-
D#9	-	-	-	-	-	51	-	-	-
E9	-	-	-	-	-	52	-	-	-
F9	-	-	-	-	-	53	-	-	-
F#9	-	-	-	-	-	54	-	-	-
G9	-	-	-	-	-	55	-	-	-
G#9	-	-	-	-	-	56	-	-	-
A9	-	-	-	-	-	57	-	-	-
A#9	-	-	-	-	-	58	-	-	-
B9	-	-	-	-	-	59	-	-	-
(*1) PoKey distortion A at 15 kHz
(*2) Pokey distortion A at 1.79 MHz
(*3) Silence (see rmtplayr.a65 code)
Edited by analmux, Sun Feb 8, 2015 10:45 AM.
#9 miker OFFLINE
miker
  • 1,904 posts
  • Stay Atari!
Posted Mon Feb 9, 2015 2:25 PM
Ok, my first one.
Small fragment from Linkin' Park (don't remember title now, though), and of my "impressions". ;)
Made on that "clarinet" sound.
Oh, .rmt and .xex files attached. :)
Edited by miker, Mon Feb 9, 2015 2:33 PM.
#10 emkay OFFLINE
emkay
  • 9,892 posts
  • What's up?
Posted Mon Feb 9, 2015 3:00 PM
Those tests would do better with some short Video.  Not all emulations work similar. At least Altirra plays it correctly.
And, let's see if this "16 bit" stuff" helps on development for a full working POKEY-Tracker.
#11 snicklin OFFLINE
snicklin
  • 2,209 posts
Posted Mon Feb 9, 2015 7:00 PM
Just for clarity, would it be possible to give each of your patches a name?
i.e. RMT 1.28 Patch X : Bass Guitar, Honky Tonk Piano & Recorder
... or something like this?
Then if there was a list of all the patches, it'd be easy to pick out which version would be good to use for your project.
#12 analmux OFFLINE
analmux
  • 2,392 posts
Posted Tue Feb 10, 2015 9:51 AM
For Patch 8, see post 2, right column. And I lost all other patches, except Patch 3. But Patch 3 is just a precursor of Patch 8: I added full clarinet control. Further I did a table-squeeze for frqtab. And I completed voice 1+2 and voice 3+4 control extension. Patch 3 had some errors.
Edited by analmux, Tue Feb 10, 2015 9:53 AM.
#13 Heaven/TQA OFFLINE
Heaven/TQA
  • 11,258 posts
Posted Tue Feb 10, 2015 9:58 AM
btw... just to be clear... you added the patch into the Windows Executable and exchanged/edited the included freq tables in the ASM source supplied?
#14 analmux OFFLINE
analmux
  • 2,392 posts
Posted Tue Feb 10, 2015 10:05 AM
Yes & Yes.
That's why the map is called "RMT 128 (Patch 8)". And the rmtplayr.a65 has all the patches, see the extra comments there:
- 320 bytes frqtab*** table
- 16 bytes frqtabbeganddistor
- 32 patches in the qq1, qq1a, qq2, qq2a, qq3, qq3a, qq4, qq4a, qs1, qs1a, qs2, qs2a, qs3, qs3a, qs4, qs4a area
... and the 32 patches were done with a simple hex-editor to change the RMT.exe file, which contains some copies of the binaries of rmtplayr. I don't have the original win32 source code.
Edited by analmux, Tue Feb 10, 2015 10:11 AM.
#15 miker OFFLINE
miker
  • 1,904 posts
  • Stay Atari!
Posted Wed Feb 11, 2015 3:33 AM
Ok, here's my nother experiment.
Why do not use distort guitars where they are really required?
Here's Orion by Metallica in my blatant (hehe) converion.
Have fun with my little big disaster.
In STEREO.
#16 miker OFFLINE
miker
  • 1,904 posts
  • Stay Atari!
Posted Wed Feb 11, 2015 6:29 AM
Ok, second version.
Distorted guitars are a bit less aggresive now.
#17 Heaven/TQA OFFLINE
Heaven/TQA
  • 11,258 posts
Posted Wed Feb 11, 2015 6:43 AM
Miker... what a suprise... I love Orion... ;)
#18 miker OFFLINE
miker
  • 1,904 posts
  • Stay Atari!
Posted Wed Feb 11, 2015 7:02 AM
Nice then. :)
#19 analmux OFFLINE
analmux
  • 2,392 posts
Posted Wed Feb 11, 2015 9:37 AM
@ Miker,
It surprised me!
Note that orion2.xex is not replaced with patch 8. It sounds horrible. I assume you typed "export as xex" with a standard RMT.
Edited by analmux, Wed Feb 11, 2015 9:38 AM.
#20 miker OFFLINE
miker
  • 1,904 posts
  • Stay Atari!
Posted Wed Feb 11, 2015 9:44 AM
Sorry guys, my fault!
Attached correct one.
Thanks, Mux! :)
Edit: Removed bad one!
Edited by miker, Wed Feb 11, 2015 9:46 AM.
#21 emkay OFFLINE
emkay
  • 9,892 posts
  • What's up?
Posted Wed Feb 11, 2015 2:09 PM
Sorry, couldn't resist ;)
Didn't know the tune before, and it's really not my cup of tea.
But this is more what "I" Get from the original ;)
Also interesting that Altirra also here sounds slightly different to the RMT... and, you hear some sound issues, caused by Altirra itself.
#22 miker OFFLINE
miker
  • 1,904 posts
  • Stay Atari!
Posted Wed Feb 11, 2015 4:36 PM
Emkay, post rmt file as well, please.
#23 analmux OFFLINE
analmux
  • 2,392 posts
Posted Wed Feb 11, 2015 5:32 PM
emkay, I agree with miker
#24 emkay OFFLINE
emkay
  • 9,892 posts
  • What's up?
Posted Thu Feb 12, 2015 3:49 AM
The RMT file.
#25 analmux OFFLINE
analmux
  • 2,392 posts
Posted Thu Feb 12, 2015 7:27 AM
Thanks!
