Atari 1020 help.
1020 printer
15 replies to this topic
#1 Star castler OFFLINE
Star castler
    Star Raider
  • 82 posts
Posted Fri Feb 13, 2015 8:40 AM
Okay, so I just got a 1020 from ebay in fairly good shape.  So I power it on and the pens are dry, but I can see the pattern.  Then the paper wouldn't move enough, it would go about 1/3 of the way down/up.  Print head just needs new pens, and it moves perfectly fine.  Needing help on getting the paper to move properly, so anybody know what I should do?
#2 SIO2 OFFLINE
SIO2
  • 1,155 posts
Posted Fri Feb 13, 2015 9:12 AM
Many many years ago I used a 1020. Mine had trouble with the tiny plastic gear on the drive motors slipping and splitting or splitting and slipping. You might check to see if the gear is intact on the motor that drives paper advance.
As for pens, I had seen something on the web where a person drilled a tiny hole in the pen case and used a hypodermic needle to inject ink.
I used to get pens and paper from radio shack because their cgp-115 printer used the same mechanism.
#3 Bryan OFFLINE
Bryan
  • 10,927 posts
  • Cruise Elroy = 4DB7
Posted Fri Feb 13, 2015 9:18 AM
http://www.sd2iec.co...atalog/i27.html
#4 sm3 OFFLINE
sm3
    Dragonstomper
  • 652 posts
Posted Fri Feb 13, 2015 10:54 AM
According to Best Electronics, the gear failure rate is like 99% or something like that ;)
They probably still have the small gears in stock: http://best-electronics-ca.com/
He also has pens in stock, but be warned, you are only allowed 1 color set per customer. You can buy as many black pens as you like.
#5 Clint Thompson ONLINE
Clint Thompson
  • 4,437 posts
  • Kiss Reality Goodbye.
Posted Fri Feb 13, 2015 2:27 PM
Same thing happened to mine. I got replacement heads new from somewhere but never got around to installing or replacing them but it was indeed the plastic gears at fault. Nevermind the fact that obtaining new pens seemed impossible - I found a source but never imported them because I just never got around to replacing the head/gears or cared enough to pursue it after some time passed.
It would be nice if we could have some metal gears 3D printed but would it even be worth the effort with pen availability and many pepople probably not even using the 1020s at all...
#6 Bryan OFFLINE
Bryan
  • 10,927 posts
Posted Fri Feb 13, 2015 2:59 PM
This place sells all kinds of gears and I was able to find one to fix an automatic turntable that tends to break. Maybe they have something that will fit the 1020.
#7 sm3 OFFLINE
sm3
    Dragonstomper
  • 652 posts
Posted Fri Feb 13, 2015 3:06 PM
I know the Best Electronics page isn't really user friendly, but they have what you need, no real need to hunt elsewhere in my opinion, unless you don't want to pay what they are asking.
Just send them an email:
Page 143 1020 Platen Motor Unit FC100371  Sold Out
1020 Head Motor Unit FC100370 Sold Out
1020 Printer Mechanism CB101170 Sold Out
1020 Small gear set (2) for the Platen and Head Motors CB101727 $15.00  Limit of 2 sets per customer
Page 148  Atari 820 40 Column Printer Paper roll. CB101922 $5.95  Limit 1
Atari 820 Ribbon CO14854 $7.95  Limit 1
Atari 1020 BX4204 Color Pen Set (4 pens per set) $3.00   New Limit 10 sets per customer
Atari 1020 BX4206 Black Pen Set (4 pens per set) $3.00
Atari 1020 Plotter paper roll set (2 Rolls per package) These are the original Japanese Alps (the manufacture who made the Atari 1020 internal printer mech.) made 1020 printer rolls with the very smooth surface and bright white color.  Be aware of generic after market 1020 printer replacement paper with a rough surface and very off white/ light brown color.  Generic replacement 1020 paper not made Alps, does not print with the same quality as the OEM Alps made 1020 paper.  CO61533 $6.50  Limit of 1 Pack per customer
It appears they have increased their limit on color pen sets which is cool!
#8 SIO2 OFFLINE
SIO2
  • 1,155 posts
Posted Fri Feb 13, 2015 3:43 PM
Interesting to know Best has those. I suppose they are NOS parts and not improved gears? If the replacements have the same failure rate, you might have to have friends and relatives order gears to get around the two sets per customer limit.
1020 is fun to watch work. I even used it once to print out program listings in 80 col. Kind of fun to have the little scrolls on my shelf.
#9 sm3 OFFLINE
sm3
    Dragonstomper
  • 652 posts
Posted Fri Feb 13, 2015 3:56 PM
I've never purchased the gears myself, as I was lucky to get one of the 1% machines that worked out-of-the-box I guess.  I'd say email Bradley and ask him your questions, he checks and responds to emails daily. Just make sure you put the word Atari in the subject line, to keep it out of his spam filters.
#10 Star castler OFFLINE
Star castler
    Star Raider
  • 82 posts
Posted Fri Feb 13, 2015 8:45 PM
Found the culprit, just as everybody thought, it is the small paper feed gear:
Split shown on the top middle of the mini gear.
#11 Stephen OFFLINE
Stephen
  • 7,642 posts
  • A8 Gear Head
Posted Fri Feb 13, 2015 9:10 PM
Wonder if these can be 3D printed?  I still think brass is the way to go though.
#12 BillC OFFLINE
BillC
  • 1,911 posts
Posted Sat Feb 14, 2015 12:15 AM
The problem is the gears are so thin that eventually they split from the stress of the friction fit. If the center hole had been a little bigger they may have lasted but then may not have been tight enough on the shaft not to slip.
#13 Bryan OFFLINE
Bryan
  • 10,927 posts
Posted Sat Feb 14, 2015 5:31 AM
The gear looks long enough that you might be able to get a small zip-tie around it that doesn't interfere. Combine that with a little super glue or epoxy to keep it from slipping and you might be back in business.
#14 bob1200xl OFFLINE
bob1200xl
  • 2,624 posts
Posted Sat Feb 14, 2015 10:34 AM
Print the gear like this:
----vvvv----       (hard to draw)
Put a thick hub on each end, gear teeth only in the center as short as possible.
Bob
#15 Sleepy OFFLINE
Sleepy
    Moonsweeper
  • 365 posts
Posted Mon Feb 16, 2015 4:28 AM
There´s a similar thread at ABBUC-Forum: click
Maybe you´ll find some usefull information there.
Good luck, Sleepy
#16 Kyle22 ONLINE
Kyle22
  • 4,096 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Mon Feb 16, 2015 2:33 PM
This: http://www.helihuett...rung-0-25m.html
appears to be the gear (according to ABBUC).
