Pfscore health help and Game over screen
Matth89812
man I'm no expert
but I think your problem is that the sprites routine keeps
reseting pfscore1
set pfscore1 to %11111111 before (or at least outside)
the sprites routine (forget the pfscore1 = 100)
then instead of pfscore1 = pfscore1 - 25 make it
pfscore1 = pfscore1 * 4
Also the health bar pfscore1 and pfscore2 are really a graphic representation of your health and they don't display correctly unless the value is exactly 255, 127, 63, 31, 15,7,3,1 and 0. You will need to convert your damage value to scale to the pfscore_ value.
This is how I originally did it. Bogax showed me a better way. But this way is hopefully clear.
If my player0 touched player 1 or missile on it would take 3 damage. Depending on the damage level pfscore2 would display accordingly. Once the damage level became lethal, then it would jump to the death routine.
if collision(player0,player1) && !p=6:then r=r+3
if collision(player0,missile1) && !p=6:then r=r+3
if r=0 then pfscore2 = %11111111
if r>30 then pfscore2 = %01111111
if r>60 then pfscore2 = %00111111
if r>90 then pfscore2 = %00011111
if r>120 then pfscore2 = %00001111
if r>150 then pfscore2 = %00000111
if r>180 then pfscore2 = %00000011
if r>210 then pfscore2 = %00000001
if r>240 then pfscore2 = %00000000
if r>242 then goto __gizdead bank4
The more efficient way Bogax showed me looks like this:
if r > 0 && r < 31 then __skip
rem temp1 = r / 30
temp1 = r / 2 : temp1 = ((temp1 / 16) + 1 + temp1) / 16
pfscore2 = tbl[temp1]
data tbl
%11111111, %01111111, %00111111, %00011111, %00001111, %00000011, %00000001, %00000000
end
if r > 242 then goto __gizdead bank4
__skip
  if collision(missile0, player1) then score = score + 1 : player1x = rand/2 : player1y = 0 : missile0y = 255
  if collision(player0 , player1) then score = score - 1 : player1x = rand/2 : player1y = 0 : missile0y = 255 : pfscore1 = pfscore1*4
  rem pfscore1 may have changed so check to see if you've
  rem run out of lives and if so jump to game over
  rem !pfscore1 is like pfscore1 = 0
  if !pfscore1 then gameover
  goto __Main_Loop
jump
  goto sprites
  goto draw_loop
gameover
  playfield:
 ..XXXXXX..XXXXX..XXXXXXX..XXXXXX
 ..X.......X...X..X..X..X..X.....
 ..X.XXX...XXXXX..X..X..X..XXXXXX
 ..X...X...X...X..X..X..X..X.....
 ..XXXXX...X...X..X.....X..XXXXXX
 ..XXXXXX.X........X.XXXX..XXXX..
 ..X....X..X......X..X.....X..X..
 ..X....X...X....X...XXXX..XXXX..
 ..X....X....X..X....X.....XX....
 ..XXXXXX.....XX.....XXXX..X.X...
end
gameover_loop
 drawscreen
 goto gameover_loop
something like that then
although I assume you're going to want some way
to break out of the gameover_loop
