Alfred Posted February 23, 2015 Share Posted February 23, 2015 (edited) With the current interest in the Action! I thought I would take a look at PL65. I had never heard of this language before, and after reading the manual I was quite interested in it. Similar to Action!, but some notable differences, particularly being able to use assembler mnemonics directly in your code. I've spent some hours disassembling the PL65 compiler, and looking at the code it generates in a couple of programs. Sad to say, my initial excitement has waned as it has become apparent that PL65 just doesn't generate very good code at all. I suppose it's faster than Basic, but I expect Action! would beat it handily. The main problem is that virtually everything is done via subroutine. While this is understandable for complex routines like 16 bit multiply or divide, it's rather wasteful when it's employed for simple calculations. Main() PChar(0,"Hello, World") End generates Main()PushByte(0) ; PChar(0,"Hello, World")PushWord($2cF3)PushByte(12)Jsr PcharEnd; which doesn't seem so bad. However for something a little more involved: Func Str$(Int num) String Sbuff[16] Byte a,b ;Begin jsr PopWord sta num sty um+1 ;Sbuff[15]="0" lda #15 jsr PushByte lda #<addr("0") ldy #>addr("0")jsrPushWord lda #1jsr PushByte lda #<sbuff+15 ldy #>sbuff+15jsr PushWordjsr Move ; Block copy routine used to move one character ; a= 16 lda #16 sta a ;Repeat ; Dec a dec a ; handy to use asm code here ; B=num mod 10 + 48 lda num ldy num+1 jsr Pushword lda b jsr PushByte jsr Mod lda #48 ldy #0 jsr Add2Stack etc. It's too bad. PL65 has some nice features, but all this stack juggling is wasted effort. It's hard to say, but with all the stack juggling and zero page use in the compiler, I could almost believe that PL65 was itself written in PL65. Maybe if someone gets bored, they can upgrade the compiler. Edited February 23, 2015 by Alfred Quote Link to comment Share on other sites More sharing options...
Alfred Posted February 23, 2015 Author Share Posted February 23, 2015 I think in the "PL65 cracked" thread there was mention of merging segments of the PL65 produced object file. It's true, PL65 produces a horrendous binary, segments galore like the nonsense you see with Mac/65, except for one thing: IT'S WORSE ! Running a segment merger like Unify.com against a PL65 output binary is useless because PL65 doesn't output any of the filler bytes used as temporary variables in the code. Thes result is dozens or hundreds of segments which are separated from each other by one or two bytes in many cases. Loading this kind of binary is akin to watching paint dry and is a good reason all by itself for avoiding this compiler. Quote Link to comment Share on other sites More sharing options...
DanBoris Posted February 26, 2015 Share Posted February 26, 2015 With the current interest in the Action! I thought I would take a look at PL65. I had never heard of this language before, and after reading the manual I was quite interested in it. Similar to Action!, but some notable differences, particularly being able to use assembler mnemonics directly in your code. I've spent some hours disassembling the PL65 compiler, and looking at the code it generates in a couple of programs. Sad to say, my initial excitement has waned as it has become apparent that PL65 just doesn't generate very good code at all. I suppose it's faster than Basic, but I expect Action! would beat it handily. The main problem is that virtually everything is done via subroutine. While this is understandable for complex routines like 16 bit multiply or divide, it's rather wasteful when it's employed for simple calculations. Main() PChar(0,"Hello, World") End generates Main() PushByte(0) ; PChar(0,"Hello, World") PushWord($2cF3) PushByte(12) Jsr Pchar End; which doesn't seem so bad. However for something a little more involved: Func Str$(Int num) String Sbuff[16] Byte a,b ;Begin jsr PopWord sta num sty um+1 ;Sbuff[15]="0" lda #15 jsr PushByte lda #<addr("0") ldy #>addr("0") jsrPushWord lda #1 jsr PushByte lda #<sbuff+15 ldy #>sbuff+15 jsr PushWord jsr Move ; Block copy routine used to move one character ; a= 16 lda #16 sta a ;Repeat ; Dec a dec a ; handy to use asm code here ; B=num mod 10 + 48 lda num ldy num+1 jsr Pushword lda b jsr PushByte jsr Mod lda #48 ldy #0 jsr Add2Stack etc. It's too bad. PL65 has some nice features, but all this stack juggling is wasted effort. It's hard to say, but with all the stack juggling and zero page use in the compiler, I could almost believe that PL65 was itself written in PL65. Maybe if someone gets bored, they can upgrade the compiler. I remember looking at the code PL65 generated back when that "PL65 Cracked" thread first popped up. The took an approach that made code generation fairly easy, but the tradeoff is very inefficient code. Action jumps through a lot of hoops get the code as tight as it does. 6502 is a challenging processor to write a compile for. Quote Link to comment Share on other sites More sharing options...
