Papa Posted March 2, 2015 Share Posted March 2, 2015 (edited) I still need to be able to combine down and up and left, so the !(not) is pretty important! I like else commands, and when I do 2D games (I mean games where there is no discernible foreground that the sprite enters or exits) I use it to stop the variable, but as it is I'm pretty sure I would lose the reflection if the direction was combined. I actually have a much longer set of controller based variables that are cancelled and/or activated to allow for jumping in both direction and using the special attack. If I were to 'else' the variable in this particular game then my upward walking animation or downward walking animation would activate on a combination of directions rather than the mirrored walking frames. What I wrote out was a simple example. I agree that things can be changed to free 1 byte here or there, or reduce cycles, however this is simple explanation. I was more emphasizing that the variable can be used in conjunction with a direction to control animation and also coordinate with a 'reflect player' command to mirror the sprite. Anyone interested in using the above example for games should definitely take note!! Edited March 2, 2015 by Papa Quote Link to comment Share on other sites More sharing options...
