some movement code
Bresenham movement
32 replies to this topic
#26 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Tue Nov 14, 2017 12:22 AM
I made an example of what I want to do, I have robots in my game that shoots missiles at you, but they can only shoot in six directions now and I would like if they shot in the exact direction you where when they fired the shot, I can do that but the problem is that the robots slowly speed up with 0.05 every one hundred points, and the missile automaticly speeds up to,
the missilespeed is the robotspeed + 0.10
So it would just be for speed flexibility, and the smoothness ofcourse, subpixel bresenham movement seems impossible in my brain but I thought I should ask,
what do you think?
Attached File  StraightLine.bas   10.71KB   26 downloads
Edited by Lillapojkenpćön, Tue Nov 14, 2017 1:16 AM.
#27 Mountain King OFFLINE
Mountain King
    Dragonstomper
  • 689 posts
Posted Wed Nov 15, 2017 5:18 AM
Bogox,
How would you handle 3 moving objects?
Player moves a cursor,
first object moves to that cursor when activated.
Second object follows and tries to catch the first object.
#28 bogax ONLINE
bogax
    Dragonstomper
  • 787 posts
Posted Wed Nov 15, 2017 5:44 PM
what do you think?
attachicon.gifStraightLine.bas
The movement code always moves one pixel
The first thing I'd try is set up an accumulator for the fractional change of
position and when it's accumulated a pixel's worth do the movement
something like
  temp = accumulator
  accumulator = accumulator + speed
  if accumulator < temp then skip_move
  movement code
skip_move
#29 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Chopper Commander
  • 156 posts
Posted Thu Nov 16, 2017 8:58 PM
Seems like I don't have to? I have no idea how it works without setting the error accumulator and all the other stuff?
Attached File  _Chase.bas   3.67KB   25 downloads
Attached File  _NoChase.bas   3.9KB   25 downloads
#30 bogax ONLINE
bogax
    Dragonstomper
  • 787 posts
Posted Sat Nov 18, 2017 8:18 AM
attachicon.gif_Chase.bas
attachicon.gif_NoChase.bas
 I'm not sure what you're asking
 You're setting all the important stuff
 You don't neccesarily need to set the error accumulator
 it just makes nicer lines (I think)
 You count through the delta in the error accumulator until it rolls over
 at which point you've accumulated a pixel worth of error so you move one
 pixel in the minor direction
 If you set the error accumulator to 1/2 the delta you're half a pixel
 from where you want to be on the line and you can only be at whole pixels
 If you set the error accumulator to 0 you'd be at one pixel from where
 you want to be and the first thing you'd do is take a step in the minor
 direction
 The line is formed from horizontal or vertical line segments in the major
 direction
 Say the segment is going to be 8 pixels ie you'll move 8 pixels in the major
 direction to accumulate one pixel of error in the minor direction
 (the error accumulator counts down through the major delta in minor direction
 deltas until it goes through zero) if you set the error accumulator to
 0 you're one pixel away and you'll immediately take a step in the minor direction
 If you set the error accumulator to 1/2 the major delta you'll take four steps
 (half of 8 )  before you take a step in the minor direction
 and if you set EA to the major delta you'll take 8 steps before you've
 accumulated enough error for a step in the minor direction
 something like this for a 9 pixel line
 _
  ________
 ____
     _____
 ________
         _
 as far as multiplying by 2 if you're working with numbers below 128
 that just gives you a little more room for accuracy if you're going
 to do something else with the error accumulator (since you're continuously
 bending the line perhaps you'd want to take into account where you are
 on the previous line) but it's really not neccesary (or even useful if
 you're just setting the error accumulator to eg 1/2 the delta)
Edited by bogax, Sat Nov 18, 2017 8:19 AM.
#31 bogax ONLINE
bogax
    Dragonstomper
  • 787 posts
Posted Sat Nov 18, 2017 8:38 AM
Bogox,
 I'm not sure I know what you're asking
 Simplest would be to have variables and
 movement code for each object that needed it and reset up
 an object whenever a its target changed position
 However you might end up doing more setup than you needed
 depending on how they're moving relative to one another
 You could parameterize and reuse the same code for different objects
 not sure it would be worth it unless you had a lot of objects
#32 Mountain King OFFLINE
Mountain King
    Dragonstomper
  • 689 posts
Posted Sat Feb 24, 2018 10:15 PM
I think I almost have it. You can move missile0. Press the button and player1 will follow the missile while player0 chases player1. However player1 doesn't always move correctly. I'm not sure what I'm doing wrong.
dim ea = a
 dim dy = b
 dim dx = c
 dim x1 = temp1
 dim x0 = temp2
 dim y1 = temp3
 dim y0 = temp4
 dim delay = h
 dim rand16 = z
 player0:
 %11000000
 %11000000
 %00000000
 %00000000
 %00000000
 %00000000
 %00000000
 %00000000
end
 player1:
 %11110000
 %11110000
 %11110000
 %11110000
 %00000000
 %00000000
 %00000000
 %00000000
end
 missile0x=80:missile0y=75
 player1x = 60 : player1y = 60
 player0x = 10  : player0y = 15
 gosub setup_move
 m=0
loop
 COLUP0 = $1C
 COLUP1 = $B4
 COLUPF = $62
 drawscreen
 delay = delay - 1
 temp1 = 0
 if joy0right then missile0x = missile0x + 1 : temp1 = 1
 if joy0left then missile0x = missile0x - 1 : temp1 = 1
 if joy0up then missile0y = missile0y - 1 : temp1 = 1
 if joy0down then missile0y = missile0y + 1 : temp1 = 1
 if player1x > 160 then player1x = 16
 if player1x < 16 then player1x = 160
 if player1y > 88 then player1y = 2
 if player1y < 2 then player1y = 88
 if missile0x > 160 then missile0x = 16
 if missile0x < 16 then missile0x = 160
 if missile0y > 88 then missile0y = 2
 if missile0y < 2 then missile0y = 88
 if joy0fire then m{0}=1 :temp1=1
 if m{0} then gosub __setup2:gosub __move2
 if collision(player0, player1) then gosub P0_rand : temp1 = 1
 if collision(player1, missile0) then temp1 = 1:m{0}=0
 if temp1 then gosub setup_move
 if delay & 1 then gosub move
 goto loop
P0_rand
 player0y = rand & $3F : player0y = (player0y / 8) + player0y + 8
 player0x = rand & $7F : player0x = (player0x / 8) + player0x + 16
 return
gub
 ;player1y = rand & $3F : player1y = (player1y / 8) + player1y + 8
 ;player1x = rand & $7F : player1x = (player1x / 8) + player1x + 16
 return
move
  temp1 = ea
  if f{0} then skip
  player0y = player0y + yinc[f]
  ea = ea - dx
  if temp1 < ea then ea = ea + dy : player0x = player0x + xinc[f]
  return
skip
  ea = ea - dy
  if temp1 < ea then ea = ea + dx : player0y = player0y + yinc[f]
  return
setup_move
 x0 = player0x + 1 : y0 = player0y + 1
 x1 = player1x + 1 : y1 = player1y
 if x0 < x1 then f{2} = 1 : dx = x1 - x0 else f{2} = 0 : dx = x0 - x1
 if y0 < y1 then f{1} = 1 : dy = y1 - y0 else f{1} = 0 : dy = y0 - y1
 if dx > dy then f{0} = 1 else f{0} = 0
 return
skip2
__move2
 temp5 = p
  if j{0} then __skip2
  player1y = player1y + yinc[j]
  p = p - n
  if temp5 < p then p = p + o: player1x = player1x + xinc[j]
  return
__skip2
  p = p - o
  if temp5 > p then p = p + n : player1y = player1y + yinc[j]
 temp1=1
 return
__setup2
 if (player1x+1) < missile0x then j{2} = 1 : n = missile0x - (player1x+1) else j{2} = 0 : n = (player1x+1) - missile0x
 if player1y < missile0y then j{1} = 1 : o = missile0y - player1y else j{1} = 0 : o = player1y - missile0y
 if n > o then j{0} = 1 else j{0} = 0
 temp1=1
 return
  data yinc
  $FF, $FF, $01, $01, $FF, $FF,$01, $01
end
  data xinc
  $FF, $FF, $FF, $FF, $01, $01, $01, $01
end
#33 Mountain King OFFLINE
Mountain King
    Dragonstomper
  • 689 posts
Posted Sun Feb 25, 2018 10:53 AM
I figured it out I had a greater than sign going the wrong way. see what a good night sleep will do.
__move2
 temp5 = p
  p = p - n
  return
__skip2
  p = p - o
  if temp5 < p then p = p + n : player1y = player1y + yinc[j]
 temp1=1
 return
Edited by Mountain King, Sun Feb 25, 2018 11:22 AM.
