Retro Lord Posted March 4, 2015 Share Posted March 4, 2015 Fiddling with a sideproject, a homage of Adventure Island for the NES and I was wondering, how do I slow down the horizontal scrolling? set kernel_options player1colors playercolors pfcolors dim rand16 = z pfhline 8 5 23 on COLUPF = $CE playfield: ................................ ................................ .......X...X.............X...X.. ......X.XXX.X...........X.XXX.X. .........X.................X.... .........X.................X.... .........X.................X.... .........X.................X.... .........X.................X.... XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end rem POSSIBLY INEFFICIENT CODE, SEPARATE COLOR INFO FOR EACH FRAME... player0color: $3E $3E $3E $D8 $3E $3E $3E $3E $3E $3E $3E $3E $3E $0E $0E $0E end player1: %00000000 %00000011 %11111001 %00011111 %10011111 %11111111 %00000011 %00000011 %00000011 %11000011 %11111111 %10011111 %11111111 end player1x = 255 : player1y = 255 __Main_Loop f=f+1 if f = 10 then player0: %00011100 %00011000 %00011000 %00011100 %00000100 %00110110 %01110110 %01101100 %01111000 %00111100 %00111000 %00111110 %00110100 %00111111 %00111100 %00111100 end player0x = 40 : player0y = 72 if f = 20 then player0: %01000011 %01100110 %00111100 %00000100 %00110100 %00110100 %01101110 %01101110 %01111000 %00111100 %00111000 %00111110 %00110100 %00111111 %00111100 %00111100 end if f=20 then f=0 pfcolors: $D6 $D6 $D6 $D6 $FC $FC $FC $FC $FC $D6 $FC end if joy0up then player0y=player0y-1 if joy0down then player0y=player0y+1 if joy0right then pfscroll left drawscreen goto __Main_Loop DEMO - default.bas.bin Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted March 4, 2015 Share Posted March 4, 2015 Here's one way to do it: set kernel_options player1colors playercolors pfcolors dim _Scroll_Control = a.b dim rand16 = z COLUPF = $CE playfield: ................................ ................................ .......X...X.............X...X.. ......X.XXX.X...........X.XXX.X. .........X.................X.... .........X.................X.... .........X.................X.... .........X.................X.... .........X.................X.... XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end rem POSSIBLY INEFFICIENT CODE, SEPARATE COLOR INFO FOR EACH FRAME... player0color: $3E $3E $3E $D8 $3E $3E $3E $3E $3E $3E $3E $3E $3E $0E $0E $0E end player1: %00000000 %00000011 %11111001 %00011111 %10011111 %11111111 %00000011 %00000011 %00000011 %11000011 %11111111 %10011111 %11111111 end player1x = 255 : player1y = 255 __Main_Loop f=f+1 if f = 10 then player0: %00011100 %00011000 %00011000 %00011100 %00000100 %00110110 %01110110 %01101100 %01111000 %00111100 %00111000 %00111110 %00110100 %00111111 %00111100 %00111100 end player0x = 40 : player0y = 72 if f = 20 then player0: %01000011 %01100110 %00111100 %00000100 %00110100 %00110100 %01101110 %01101110 %01111000 %00111100 %00111000 %00111110 %00110100 %00111111 %00111100 %00111100 end if f=20 then f=0 pfcolors: $D6 $D6 $D6 $D6 $FC $FC $FC $FC $FC $D6 $FC end if joy0up then player0y=player0y-1 if joy0down then player0y=player0y+1 if !joy0right then goto __Skip_JR _Scroll_Control = _Scroll_Control + 0.45 if _Scroll_Control > 1 then pfscroll left : _Scroll_Control = 0 __Skip_JR drawscreen goto __Main_Loop _ Right now it is scrolling at 0.45. If you want it to scroll faster, use a larger number such as 0.56 or 0.62 or 0.70 or whatever (I just picked some random numbers). If you want it even slower, use a smaller number such as 0.30 or 0.28 or 0.15 or whatever (I just picked some random numbers). Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted March 4, 2015 Share Posted March 4, 2015 (edited) This doesn't look quite right: _Scroll_Control = _Scroll_Control + 0.45 if _Scroll_Control > 1 then pfscroll left : _Scroll_Control = 0 it should be _Scroll_Control = _Scroll_Control + 0.45 if _Scroll_Control >= 1 then pfscroll left : _Scroll_Control = _Scroll_Control - 1.0 With the original routine the scrolling would always happen every 3rd frame if the scroll value was between 0.3333 and 0.5, and every 2nd frame if the value was 0.50 thru 1.0. Edited March 4, 2015 by SpiceWare 1 Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted March 4, 2015 Share Posted March 4, 2015 This doesn't look quite right: _Scroll_Control = _Scroll_Control + 0.45 if _Scroll_Control > 1 then pfscroll left : _Scroll_Control = 0 it should be _Scroll_Control = _Scroll_Control + 0.45 if _Scroll_Control >= 1 then pfscroll left : _Scroll_Control = _Scroll_Control - 1.0 With the original routine the scrolling would always happen every 3rd frame if the scroll value was between 0.3333 and 0.5, and every 2nd frame if the value was 0.50 thru 1.0. Thanks. Quote Link to comment Share on other sites More sharing options...
Retro Lord Posted March 4, 2015 Author Share Posted March 4, 2015 Worked like a dream, what would I do without you guys? =) Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted March 4, 2015 Share Posted March 4, 2015 I don't know why I decided to waste a variable, though. I guess it's because I was just working with fixed point variables. This is probably a better way to do it: _ set kernel_options player1colors playercolors pfcolors dim _Scroll_Control = a dim rand16 = z COLUPF = $CE playfield: ................................ ................................ .......X...X.............X...X.. ......X.XXX.X...........X.XXX.X. .........X.................X.... .........X.................X.... .........X.................X.... .........X.................X.... .........X.................X.... XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end rem POSSIBLY INEFFICIENT CODE, SEPARATE COLOR INFO FOR EACH FRAME... player0color: $3E $3E $3E $D8 $3E $3E $3E $3E $3E $3E $3E $3E $3E $0E $0E $0E end player1: %00000000 %00000011 %11111001 %00011111 %10011111 %11111111 %00000011 %00000011 %00000011 %11000011 %11111111 %10011111 %11111111 end player1x = 255 : player1y = 255 __Main_Loop f=f+1 if f = 10 then player0: %00011100 %00011000 %00011000 %00011100 %00000100 %00110110 %01110110 %01101100 %01111000 %00111100 %00111000 %00111110 %00110100 %00111111 %00111100 %00111100 end player0x = 40 : player0y = 72 if f = 20 then player0: %01000011 %01100110 %00111100 %00000100 %00110100 %00110100 %01101110 %01101110 %01111000 %00111100 %00111000 %00111110 %00110100 %00111111 %00111100 %00111100 end if f=20 then f=0 pfcolors: $D6 $D6 $D6 $D6 $FC $FC $FC $FC $FC $D6 $FC end if joy0up then player0y=player0y-1 if joy0down then player0y=player0y+1 if !joy0right then goto __Skip_JR if _Scroll_Control = 4 then pfscroll left : _Scroll_Control = 0 : goto __Skip_JR _Scroll_Control = _Scroll_Control + 1 __Skip_JR drawscreen goto __Main_Loop _ Just change "if _Scroll_Control = 4" to a lower or higher number to change the speed. Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted March 4, 2015 Share Posted March 4, 2015 I think this is a great approach if the speed will be constant. If the speed will be changed at runtime there might be a more linear way to do it with a single variable. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted March 4, 2015 Share Posted March 4, 2015 I think this is a great approach if the speed will be constant. If the speed will be changed at runtime there might be a more linear way to do it with a single variable. Using assembly, I'd do something like this for a constant speed: SPEED = $64 ScrollCheck: clc lda #SPEED adc ScrollControl ; RAM variable sta ScrollControl bcc NoScroll ; Carry flag was set so we need to scroll ; scroll logic goes here NoScroll: If I wanted the speed to be variable I'd do this: ScrollCheck: clc lda CurrentSpeed ; RAM variable adc ScrollControl ; RAM variable sta ScrollControl bcc NoScroll ; Carry flag was set so we need to scroll ; scroll logic goes here NoScroll: Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted March 4, 2015 Share Posted March 4, 2015 Nice. Just wrap it in an asm statement and you've got linear scrolling speed control with a single variable in bB. Quote Link to comment Share on other sites More sharing options...
bogax Posted March 5, 2015 Share Posted March 5, 2015 Nice. Just wrap it in an asm statement and you've got linear scrolling speed control with a single variable in bB. or you could just do it in bB temp1 = scroll_distance scroll_distance = scroll_distance + scroll_speed if scroll_distance < temp1 then scroll Quote Link to comment Share on other sites More sharing options...
