+arcadeshopper Posted February 8, 2017 Share Posted February 8, 2017 I'm unable to download the latest version of tisim I had someone asking on the facebook ti group about the roms for it, as the directory structure has changed.. I can get 13 and install it fine but 14 seems to be not authorized for dl Greg Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted February 8, 2017 Share Posted February 8, 2017 It looks like only the i686 version is blocked from download. I downloaded the source, AMD, and ARM files without any problems. . . Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 9, 2017 Share Posted February 9, 2017 It looks like only the i686 version is blocked from download. I downloaded the source, AMD, and ARM files without any problems. . . thanks, looking again on the main tisim page you can dl those, on the 'archives' you can't download any of the v14 Quote Link to comment Share on other sites More sharing options...
ti99sim Posted February 9, 2017 Share Posted February 9, 2017 Sorry about that. It looks like there was a permission error on a few files. It should be fixed now. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 9, 2017 Share Posted February 9, 2017 Sorry about that. It looks like there was a permission error on a few files. It should be fixed now. thanks! Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 10, 2017 Share Posted February 10, 2017 Sorry about that. It looks like there was a permission error on a few files. It should be fixed now. So the file for 14 has a roms directory, when I put my roms in there for the console etc, it says they are missing.. Is there some sort of documentation on what to do with the files? Do the files for v13 (works fine) work with v14? Greg Quote Link to comment Share on other sites More sharing options...
Willsy Posted December 14, 2017 Share Posted December 14, 2017 (edited) I could do with information on this, too, as I'm no longer a Windows user. I'm using Linux Mint 64-bit. If anyone has this pre-built I'm all ears! I *think* I got it to build by following the instructions on the website, and I have ROM images, but it doesn't run. Edited December 14, 2017 by Willsy Quote Link to comment Share on other sites More sharing options...
WishItWas1984 Posted January 8, 2019 Share Posted January 8, 2019 FYI, earlier today I was playing with TI99sim in my RetroPie setup and I got annoyed with the mouse pointer constantly showing up when I switched games to the point that it motivated me to hunt down why it was happening and fix it. Since I compiled my TI99sim from version 0.12 source, I was able to go through the code and find the problem and fix it. if you have compiled from any version of source you can probably do the same thing. If you're using binaries you're probably out of luck for now. There's an SDL function, "SDL_ShowCursor" that's supposed to turn the cursor / mouse pointer off. I went looking in the source of TI99sim to see if I could find it or find someplace to shoehorn it in. I found it in "ti99sim-0.0.12/src/sdl/tms9918a-sdl.cpp" in a block of code that should conditionally be run if ti99sim is running full screen. That makes sense, because if it's running in a window in a multitasking environment, you're not going to want it to turn your pointer off. I went back and double checked /etc/emulationstation/es_systems.cfg (which is a big XML file that controls actually launching emulators in RetroPie & feeding them parameters). I wanted to make sure that TI99sim was getting launched with the "-f" (full screen) parameter (it was). It seems there's something about the RetroPie/EmulationStation environment that's making TI99sim think it's not running full screen when it clearly is being called as full screen, and appears to be running that way. Because of that, the conditional block of code that contains "SDL_ShowCursor(SDL_DISABLE)" never gets run, and the mouse pointer shows. My quick & dirty solution was to put the SDL function to hide the cursor someplace where it would get run unconditionally. In the same file, "ti99sim-0.0.12/src/sdl/tms9918a-sdl.cpp", I went to this section of the file: FUNCTION_ENTRY( this, "cSdlTMS9918A ctor", true ); m_Mutex = SDL_CreateMutex( ); memset( m_RawColorTable, 0, sizeof( m_RawColorTable )); memset( m_SDLColorTable, 0, sizeof( m_SDLColorTable )); and added the SDL function there, so that block wound up being: FUNCTION_ENTRY( this, "cSdlTMS9918A ctor", true ); m_Mutex = SDL_CreateMutex( ); SDL_ShowCursor( SDL_DISABLE ); memset( m_RawColorTable, 0, sizeof( m_RawColorTable )); memset( m_SDLColorTable, 0, sizeof( m_SDLColorTable )); Then I saved the file, went to the root of the ti99sim source directory, and compiled by doing: make ..lots of compiling ensues... then sudo make install After that, I launched RetroPie, launched TI99sim, launched Parsec, and NO POINTER! No apparent Ill effects, either. Annoyance is the other mother of invention, or modification, or whatever Obviously I am not a C programmer and I'm pretty sure this is violating some kind of programmer's prime directive, but it works and it causes no errors or warnings. This is really only useful for RetroPie or any other non-X launcher where full screen is used but mis-detected. Hopefully someone else can get some use from this. Resurrecting this because it's the only solution I can seem to find online. Hopefully someone can reply to this... I understand what was done here, but I'm unclear how to actually recompile the cpp file. I assume you edit via a nano command though, yes? Regardless, what are the odds of someone posting their edited cpp file?? LOL Cause that cursor is driving me nuts and I hate having to plug in a mouse to move it all of the time. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted January 8, 2019 Share Posted January 8, 2019 Resurrecting this because it's the only solution I can seem to find online. Hopefully someone can reply to this... I understand what was done here, but I'm unclear how to actually recompile the cpp file. I assume you edit via a nano command though, yes? Regardless, what are the odds of someone posting their edited cpp file?? LOL Cause that cursor is driving me nuts and I hate having to plug in a mouse to move it all of the time. "Then I saved the file, went to the root of the ti99sim source directory, and compiled by doing: make" Quote Link to comment Share on other sites More sharing options...
davros4269 Posted May 11, 2021 Share Posted May 11, 2021 I'm using t99sim on a Rasberry Pi4. Basic works, but I can't get it to save anything. Specifically, I get a segmentation fault when I try using F2 or F3 to save state, and when I try to save from basic (save dsk1.test, etc), I get I/O error 60. Running the emu with the verbose flag gives me "Loading device: >0000 - "TI-Disk Controller" - ** Failed to add device **". Could it be a bad ROM? I'm running the binaries, btw, I didn't compile t99sim myself. Seems like a lovely project, just getting into the Ti994a now that I got an actual physical unit as a gift. I'm running Raspbian 10/buster. I have an SSSD floppy image named dsk1.dsk in the disks folder (made with the included disk utility, the setup script didn't make me one for some reason), and ti-disk.ctg in the console folder (which is a 5.5k sized file). I've tried loading the emu by telling it that I have dsk1.dsk, and without telling it explicitly (tho from the readme, it should auto-use it, I think). Any ideas? Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted May 11, 2021 Share Posted May 11, 2021 2 hours ago, davros4269 said: ...when I try to save from basic (save dsk1.test, etc), I get I/O error 60. You're not trying to use lowercase commands, device or file names? ...I can't say that I'm knowledgeable about the rest. P.S. Glad to have you here! 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted May 11, 2021 Share Posted May 11, 2021 I/O Error 60 means "Device not found". You likely used lowercase. Please keep in mind that on the TI-99/4A, uppercase is default for everything from device names, BASIC command up to assembly language. You better leave Alpha Lock depressed (unless you want to play with joysticks). 3 Quote Link to comment Share on other sites More sharing options...
davros4269 Posted May 11, 2021 Share Posted May 11, 2021 Lol, yes, I was typing the commands in lowercase?.. Basic didn't complain about entering/running simple programs in lowercase, but, that doesn't seem to be the issue in this case: trying it again with capslock on gave me the same error. I'm assuming it has to do with the fact that I get the disk controller error when I start the emu? Does anyone have any idea why it seg faults when I try to save state? Anyone else running this emu on the Pi in Raspbian? Quote Link to comment Share on other sites More sharing options...
davros4269 Posted May 11, 2021 Share Posted May 11, 2021 I figured out my problem, it was related to the roms I had. I wasn't using the roms that the included setup script downloads, because the setup script failed I wasn't paying enough attention to the output of the script when I initially ran it, and I partially set things up by hand before I realized that there even was a setup script .. The setup script fails because it can't find the "bin" folder that comes with the binary package, which is one directory up from the directory containing "setup". So I ran it successfully by running it from the main install folder like this: <whatever-folder-the-extracted-binary-download-is-in>/ti99sim-0.16.0 $ scripts/setup In other words, my current working directory also had "bin" in it this time like "setup" was expecting, and it worked like a charm. It made a default disk image file for me this time, and save/load state via F2 and F3 as well as the "SAVE" and "OLD" commands, work fine 1 Quote Link to comment Share on other sites More sharing options...
