jdgabbard Posted March 16, 2015 Author Share Posted March 16, 2015 Sweet. I have a XB cart, and the Nano, so I guess I'm set as far as actual hardware. However, I'd probably use it on the PC with C99 to be honest. Mostly because I can copy and paste large portions of code from a text document into the terminal. But I'll take a look at it this afternoon. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 16, 2015 Share Posted March 16, 2015 (edited) Another good resource for sprite programming is Craig Miller’s Smart Programming for Sprites available here. [Edit: It’s also available on this forum in the pinned TI-99/4A development resources thread; but, the Archive.org PDF is much clearer and searchable (@retroclouds, perhaps you could replace the one in the Development Resources thread).] ...lee Edited March 16, 2015 by Lee Stewart Quote Link to comment Share on other sites More sharing options...
+hloberg Posted March 21, 2015 Share Posted March 21, 2015 mentioned`rotating sprites. I need two sets of 5 sprites on the screen simultaneously. I take it this can only be done in assembler. would something like C99 or compiled XB might be too slow? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 22, 2015 Share Posted March 22, 2015 mentioned`rotating sprites. I need two sets of 5 sprites on the screen simultaneously. I take it this can only be done in assembler. would something like C99 or compiled XB might be too slow? You can define 28 sprites in XB and have them all on the screen at once. You just will not see more than the 4 lowest-numbered sprites on any given line. Moving a lot of sprites around the screen will result in sprites blinking off when they are the 5th and higher-numbered sprites on one line and back on when they are not. ...lee Quote Link to comment Share on other sites More sharing options...
Tursi Posted March 22, 2015 Share Posted March 22, 2015 c99 is definitely fast enough for rotating sprites... Compiled XB might be, but I think it'd be fairly inefficient. The best approach for either case would be to write a little assembly language routine called from the user interrupt hook to do the rotation for you, as it needs to happen every frame to work. Quote Link to comment Share on other sites More sharing options...
