Issues with 'Bounty Bob' on a modified 130XE
10 replies to this topic
#1 PlayingTheAngel OFFLINE
PlayingTheAngel
    Space Invader
  • 16 posts
  • Just hang on and Suffer Well
Posted Fri Mar 13, 2015 8:17 PM
Hi all,
I don't know how many of you have 1mb Ultimate and VBXE installed into your XL/XE computers but I had one of my 130XE's modified recently. I have to say that I was quite excited  :) It's been fun and it's certainly re-energised my enthusiasm for the 8 Bit Atari computer.
Recently I've been using the following Utilities and Menu Makers that I've had on disk for years:
Alpha Menu Maker
Ian K Menu Maker
Rob C Musical Menu Maker
MultiBoot
When it came to putting 'Bounty Bob Strikes Back' onto a menu, it read from high speed menu (Ian K) to normal 1050 speed menu (Rob C) without issues. When the data loaded and the game begins I cannot control anything with the joystick and he will only jump which is rather bizarre. I unplugged my modified 130XE and plugged my stock 65XE into my 1050 and the game wouldn't even load or work at all and then I tried my stock 130XE and the game worked fine. How can it be that it won't work at all on my modded 130XE with all the extra ram onboard? I tried all different settings on the BIOS and still it wouldn't work  :?
I would be interested to hear your thoughts.
Rachel  ;-)
Edited by PlayingTheAngel, Fri Mar 13, 2015 8:18 PM.
#2 phaeron OFFLINE
phaeron
  • 2,738 posts
Posted Fri Mar 13, 2015 9:21 PM
Ultimate1MB takes over some memory locations in the computer that are normally used by the chip that's connected to the joysticks (PIA). Software that uses the official methods of reading the joystick are OK, but Bounty Bob uses one of these unusual locations to read the joystick ($D3F0), and so it doesn't work with U1MB installed.
#3 Stefan Both OFFLINE
Stefan Both
    Moonsweeper
  • 451 posts
Posted Sat Mar 14, 2015 6:03 AM
I also own an ultimate, that's why
i ask for a better understanding.
The problem still exist, when you switch
off (set everything to STOCK) in ultimate menu?
Stefan
#4 PlayingTheAngel OFFLINE
PlayingTheAngel
    Space Invader
  • 16 posts
Posted Sat Mar 14, 2015 10:18 AM
I've changed all BIOS settings before Stefan and switched everything to stock and still doesn't work. Thanks for the explanation Phaeron
#5 Stefan Both OFFLINE
Stefan Both
    Moonsweeper
  • 451 posts
Posted Sat Mar 14, 2015 2:58 PM
Agree. You are right. Tested it myselfe.
Strange thing. Thanks to Phaeron also.
Stefan
#6 nobody OFFLINE
nobody
    Space Invader
  • 23 posts
Posted Sat Mar 14, 2015 4:18 PM
Try this version - it should work...
Edited by nobody, Sat Mar 14, 2015 4:20 PM.
#7 nobody OFFLINE
nobody
    Space Invader
  • 23 posts
Posted Sun Mar 15, 2015 2:34 AM
Ok... Now with correct sound, i think... This Game is tricky...
#8 Stefan Both OFFLINE
Stefan Both
    Moonsweeper
  • 451 posts
Posted Sun Mar 15, 2015 2:57 PM
Thank you! I'll try it.
Stefan
#9 FULS OFFLINE
FULS
    Moonsweeper
  • 344 posts
Posted Mon Mar 16, 2015 3:52 PM
Thank You very much!!!
Haven't tried all the levels yet, but I did notice this version fixed the SYSTEM RESET bug on screen #2.
This looks like it might be the best file version of BBSB I've seen.
#10 bandit OFFLINE
bandit
    Chopper Commander
  • 201 posts
Posted Wed Mar 18, 2015 9:54 AM
This also works on the Incognito Board which the Cartridge DID not and the many different Files of bounty bob
Also Had the basic issue, NO JOYSTICK always ran to the left of the screen.
So, this file now works !! Thanks!!
#11 MrMartian OFFLINE
MrMartian
    Moonsweeper
  • 303 posts
Posted Wed Mar 18, 2015 5:54 PM
Exactly! That's where I was having a problem now that I have an Incognito, and BBSB didn't work at all! Hooray for nobody! (Hmm, that sounds odd....)
