New 7800 S-Video Board available
s-video composite
74 replies to this topic
#1 Magic Knight OFFLINE
Magic Knight
    Dragonstomper
  • 539 posts
  • Waiting for SHATRON to be released...
Posted Sun Mar 15, 2015 2:35 PM
Hi All
After taking a break from Atari for a year or so, im happy to offer a new product to the community which may be of interest,
Im  pleased to offer a S-video card which i have designed and optimised for CRT monitors, which has excellent quality video compaired to Composite and of course standard TV/Coax.   The card is compatible with both NTSC and PAL Ataris and comes pre-wired and with Full color instructions and fittings.
Both 7800 and TIA output is catered for and there is an adjustment pot for quality can be adjusted to ensure best results for your monitor.
I have listed the features/parts here:
Features:
* 7800 & 2600 TIA compatible
* Works on PAL and NTSC units
* Sound Filter
* Onboard adjustment for sharpening results
* Easy Install with Step-by-Step color photos (separate sections for both PAL and NTSC)
Kit Includes:
* S-Video Module card - pre-wired and color coded
* 4 Pin S-Video DIn Socket (for fitting to side if desired)
* RCA Socket - for Audio output
* Link wires
* Easy Install Instructions with colour photos showing step by step from start to Finish.
As some new LCD monitors may vary, im pitching this to be used for CRT monitors as to both ensure compatibility and also to keep the original feel of the 7800.
Some shots ive taken are:
PAL - Xenophobe, Sirius, Choplifter
NTSC - Intro screen, Winter Games, Plutos.
IMG_0207.JPG IMG_0208.JPG IMG_0213.JPG IMG_0214.JPG IMG_0217.JPG IMG_0219.JPG IMG_0221.JPG
Im sure you will agree that although composite is a good departure from standard TV, the quality that the 7800 can give out is worth the effort!
Ive listed these on Ebay here for general release and what the cost/rates are.
UK - http://www.ebay.co.u...984.m1555.l2649
ROW - http://www.ebay.com/...=item1c4fbdecd9
Please let me know if you have any questions or feel free to PM me if you are interested but dont use ebay etc.
Richard
#2 KevinMos3 OFFLINE
KevinMos3
  • 1,590 posts
  • Founder of the Timothy Dalton as Bond fan club
Posted Sun Mar 15, 2015 3:21 PM
Looks good, but I'd only be up for it if you develop one that has both s-video and composite, since many many many many TVs don't have s-video inputs.  I prefer s-video when available, but often I'm stuck using composite.
If you develop one with both, I'm definitely in.
Also, does installing this disable use of the RF output?
#3 gambler172 OFFLINE
gambler172
  • 3,336 posts
  • none
Posted Sun Mar 15, 2015 3:30 PM
Hi
i submit every new 7800 development
Ordered mine :)
greetings Walter
#4 Jinks OFFLINE
Jinks
  • 4,582 posts
Posted Sun Mar 15, 2015 3:35 PM
I would buy one but I am an idiot with soldering on boards. My 7800 would then be a door stop.
#5 7800fan OFFLINE
7800fan
  • 5,606 posts
Posted Sun Mar 15, 2015 8:08 PM
How does this compare to the longhorn style mod?  It does look easier to install.
#6 Magic Knight OFFLINE
Magic Knight
    Dragonstomper
  • 539 posts
Posted Mon Mar 16, 2015 12:54 AM
Kevin, thats right, the TV out put is disabled by cutting links to the modulator without removal.
Edited by Magic Knight, Mon Mar 16, 2015 12:55 AM.
#7 Magic Knight OFFLINE
Magic Knight
    Dragonstomper
  • 539 posts
Posted Mon Mar 16, 2015 1:11 AM
The main difference compared with the MK board is that the longhorn process requires the tricky removal of a whole chip from the board and soldering a socket.  Then adding chip and soldering around 10 or so wires.
The MK one just requires placement of around the same qty of wires, but the chip isnt removed.  With just cutting of the RF wires and a couple of snips here and there, the jobs done with the ease of being able to reverse the process if you had the requirement in the future. (not a critisim of the LH, but from doing similar with 600xls and 800xls, i appreciate how fiddly and potentially fatal chip removal can be if not done correctly).
For the level of soldering required, its a matter of tacking on each wire to the specific part of the board without removing parts.  Any disection is the odd snip of a resitor leg to cut the circuit.  The whole process should take around 15-20 minutes for an expreienced user and 30 minutes for a newbie once the instructions have been read.(including removing the cover and back etc)
#8 RevEng ONLINE
RevEng
    Bit Player
  • 5,105 posts
Posted Mon Mar 16, 2015 7:35 AM
Seconded. This product is reasonably priced, and the screenshots looks top notch. I understand s-video provides the superior signal, but the lack of a composite out option is a deal breaker for me.
That aside, thank-you for bringing this to the community! :thumbsup:
#9 78001987 OFFLINE
78001987
  • 1,230 posts
Posted Mon Mar 16, 2015 8:04 AM
Yeah - not to sound like a broken record, but making s-video mods for any old console in 2015 is a losing gamble. S-Video has been universally dropped by nearly every TV maker. The default standard for legacy TV formats is composite. and really - the quality difference between a good composite signal and your average s-video mod is negligible at best, especially on a TV that is in good shape and doesn't have color convergence issues.
Edited by 78001987, Mon Mar 16, 2015 8:05 AM.
#10 Magic Knight OFFLINE
Magic Knight
    Dragonstomper
  • 539 posts
Posted Mon Mar 16, 2015 10:21 AM
Thanks for the support,
The convenience of composite is something that is easily embraced by todays equipment for sure.  Im making a 7800 laptop for for which uses a LCD (composite only) screen and its awesome on the native NES composite and reasonable on a 7800 composite mod ive done also.
The way i see is that there are 4 options for the user these days:
1. UHF/TV output(through the modulator)  - fuzzy and not great.
2. Composite - (luma and chroma combined)  reasonably fair, with odd ghosting and stuff depending on filters used.
3. S-Video - (luma and chroma seperated and amplified accordignly) - clear quality and about the closest to crisp whilst retianing the 'charm' of the old way of presenting a picture.  Equipment with S-video, not readily avialable compaired to composite.
4. Digital/emulated - crisp graphics, but can be a little sobering for some with a lack of 'warmth' to the experience.
I may look to see if a composite version (with less wires indeed) is something viable, but im sure there is quite a few offerings already that do the job good.
For personal use, i use a CRT monitor that would have cost around $800 in the 90's and can be picked up for a round $15 on Ebay. JVC/Sony etc ones that were expesive are now peanuts for nostalgic gaming!
#11 thecrypticodor OFFLINE
thecrypticodor
    Chopper Commander
  • 137 posts
Posted Mon Mar 16, 2015 11:07 AM
You can easily convert S-Video to composite.
There exist adapters that do exactly this. http://www.ebay.com/...=item2c831c111f
Edited by thecrypticodor, Mon Mar 16, 2015 11:08 AM.
#12 Magic Knight OFFLINE
Magic Knight
    Dragonstomper
  • 539 posts
Posted Mon Mar 16, 2015 4:09 PM
Due to a particular individual with issues against my offering modder type electronic boards on Ebay (and sending me implied messages) -  to avoid the bs. i have decided to withdraw using Ebay for offering these electronic units boards. Issue isn't a function/techical one I must make clear.
Appears this may be a familiar locked topic going back over a year or go's conversations here on AA that wont go away.
My drive belts  for 8-bit drives are unaffected and will stay listed as and when stock is avialable for the foreseeable future!
If you are still interested in the 7800 S-video boards and/or have any questions , then i kindly please ask you PM me for further details for which i will be glad to assist,
Richard
Edited by Magic Knight, Mon Mar 16, 2015 4:28 PM.
#13 2600 Forever OFFLINE
2600 Forever
    Moonsweeper
  • 413 posts
Posted Mon Mar 16, 2015 5:05 PM
Richard
I swear, that guy is mentally ill.  Unbelievable.
#14 Trebor OFFLINE
Trebor
  • 4,698 posts
Posted Mon Mar 16, 2015 5:31 PM
I sure hope this isn't the same guy who had issues with the Anniversary carts.  :roll:
I already have plenty of systems and respective mods to keep me content.  Regardless, congrats to whomever the troublemaker is as they just created another sale for you.
Magic Knight, from the ebay auctions I'm seeing:
$24.34 for the mod and another $8.90 (6 GBP to US $) for shipping...So a total of roughly $25+9 = $34.  Minus paypal fees, but add for your aggrivation...
So, I'll send you $35 via PayPal.
Shoot me a PM with your PayPal address, you just earned another sale...Thanks to the individual with "issues", regardless of personal or with what you are, or/and how you were providing (it).
Thank you for supporting the 7800 community!
#15 ApolloBoy OFFLINE
ApolloBoy
  • 5,739 posts
Posted Tue Mar 17, 2015 12:49 AM
If this doesn't have the same issues that the LHE board has, I'd definitely be up for one of these.
#16 Magic Knight OFFLINE
Magic Knight
    Dragonstomper
  • 539 posts
Posted Tue Mar 17, 2015 12:58 AM
Many thanks for the show of faith guys.  Its communitys like these that make modding and sharing worthwhile!
#17 Smoke Monster OFFLINE
Smoke Monster
    Chopper Commander
  • 108 posts
  • Puzzle Bobbling
Posted Tue Mar 17, 2015 8:10 PM
Awesome product! This definitely looks easier to install than other methods. Is the s-video quality the same?
#18 Magic Knight OFFLINE
Magic Knight
    Dragonstomper
  • 539 posts
Posted Wed Mar 18, 2015 11:30 AM
From what i understand the quality of any product of this kind - Ensuring that  the raw source of graphics from the graphics chip is kept as intact as possible and de-grading avoided and conditioned to suit the display being used. My own does this method and the results are fairly clear.
The others ive seen recently and from before have similar results from screen shots ive seen.  I dont think theres been any degrading on signals on the other either (and have their own unique ways to preocess the signal) , so the level of standard for the 7800 user appears to be a consistant high standard for all to enjoy!
Its a pity atari didnt build in a decent output for either S-video or Composite at least, as they missed a trick - especially where Nintendo's NES has the best built in Composite ive seen on any 8-bit machine. Users familiar with the atari 8-bit computers will know how Atari mucked-up on the XL/XE range on composite/s-video to the monitor/rca ports and only on the earlier(!) 800 did they get this right.
#19 Lendorien OFFLINE
Lendorien
  • 1,284 posts
Posted Wed Mar 18, 2015 9:58 PM
Yeah. I had a hell of a time with mine. In my case, the board also had a short i it I had to try to fix. Gave me fits as my solder-foo is not so great.
#20 Guitari OFFLINE
Guitari
  • 1,710 posts
Posted Sun Apr 5, 2015 2:46 PM
Ordered. Can anyone advise on the best position for the new outputs?
#21 Magic Knight OFFLINE
Magic Knight
    Dragonstomper
  • 539 posts
Posted Tue Apr 7, 2015 10:23 AM
Im installing the din & audio socket this weekend, so i can post some photos here when i finish the install.  Its basically on the left side and under the atari main board height so its out the way,
#22 Guitari OFFLINE
Guitari
  • 1,710 posts
Posted Wed Apr 8, 2015 3:14 PM
Thankyou MK. My package arrived today but I won't get chance to install it until late may.
#23 Roy OFFLINE
Roy
    Star Raider
  • 55 posts
  • Self-Proclaimed 7800 Developer
Posted Wed Apr 15, 2015 3:37 PM
Got my package yesterday and finally installed it. Worked right off the bat, and looks great. Pics soon once I mount everything. :) Thanks for the kit!
#24 Magic Knight OFFLINE
Magic Knight
    Dragonstomper
  • 539 posts
Posted Fri Apr 17, 2015 7:17 AM
Thanks for the positive feedback and glad it got installed without issue.  Happy gaming!
#25 Magic Knight OFFLINE
Magic Knight
    Dragonstomper
  • 539 posts
Posted Sat Apr 18, 2015 6:11 AM
Hi All
Following quite a bit of interest about this S-Video board being used on modern LCD tvs etc with HDMI, i ran some tests to see how to go about this.
I acquired a inexpensive HDMI upscaler for around 20 bucks and as a result it shows some fairly impressive results at 1080 resolution.
I used this:
and obtained this:
I was expecting some issues with upscaling, however the source signal from the board is unterred by filtering, and was surprised how much it blows the socks off composite. SO much so, i may have to hustle to get use of my main tv to play this when the missus is in....
As this is likley a PAL upscaler, similar low cost ones will be avialable for NTSC also, as they can retail down very cheap if you shop around.
Hope this helps anyone looking for a safe way to get high def from the Atari and i still have some Boards still avialable if anyones interested!
Edited by Magic Knight, Sat Apr 18, 2015 6:12 AM.
Also tagged with one or more of these keywords: s-video, composite
