Sword of Surtr
Sword of Surtr
156 replies to this topic
#151 bogax ONLINE
bogax
    Dragonstomper
  • 758 posts
Posted Tue Mar 27, 2018 8:19 PM
  Here I've done some code with tables
  First is 22 of your if statements (put in to a more tabular form)
  then the same thing with tables.
  Each if statement takes a minimum of 7 cycles so if you fall through
  all 22 that by it self takes 154 cycles.
  If the if statements represent 1/3 of the possible rooms and the
  rooms come up at random (they probably don't) 2/3 of the time you'll
  spend 154 cycles just to decide you don't want to do anything.
  If you do take the if statement then on average you'll do half of them
  or about 77 cycles (again if the rooms are random which they probably aren't)
  plus the 50 cycles or so that it takes for the rest it.
  In the case of the tables it does a look up to decide if it needs to do
  anything, that takes about nine cycles (versus 154).
  The rest of the table code takes 180 cycles or so (versus the 77 + 50)
  But that's all sort of worst case.  It might be faster it might not.
  I don't think it would be much worse.
  It takes about 1/3 the ROM
  Of course, it's not tested but it does compile.
   set romsize 32k
   set optimization noinlinedata
   dim _Room = r
   dim _Bit5_Frozen = f
 bank 2
dispatch2
 bank 3
dispatch3
DS7
mk1
   if _Room =  2 && player1x >  72 && player1x <  85 &&                  player1y < 55 then _Room = 46 :                  player1y = 85 : _Bit5_Frozen{5} = 0 : goto DS46 bank5  ; 01  1
   if _Room =  4 && player1x >  66 && player1x <  86 && player1y > 45 && player1y < 55 then _Room = 42 : player1x = 117 : player1y = 85 : _Bit5_Frozen{5} = 0 : goto DS42 bank5  ; 02  0
   if _Room =  5 && player1x > 108 && player1x < 118 &&                  player1y < 65 then _Room = 39 :                  player1y = 84 : _Bit5_Frozen{5} = 0 : goto DS39 bank4  ; 03 10
   if _Room =  6 && player1x >  44 && player1x <  56 &&                  player1y < 71 then _Room = 27 : player1x =  78 : player1y = 85 : _Bit5_Frozen{5} = 0 : goto DS27 bank4  ; 04  3
   if _Room =  7 && player1x > 114 && player1x < 134 &&                  player1y < 25 then _Room = 37 :                  player1y = 18 : _Bit5_Frozen{5} = 0 : goto DS37 bank4  ; 05  8
   if _Room =  8 && player1x >  62 && player1x <  77 && player1y > 52 && player1y < 62 then _Room = 40 : player1x =  21 : player1y = 85 : _Bit5_Frozen{5} = 0 : goto DS40 bank4  ; 06 11
   if _Room =  9 && player1x >  49 && player1x <  70 &&                  player1y < 24 then _Room = 66 :                  player1y = 84 : _Bit5_Frozen{5} = 0 : goto DS66 bank5  ; 07  7
   if _Room = 10 && player1x >  80 && player1x <  91 && player1y > 55 && player1y < 63 then _Room = 31 : player1x =  77 : player1y = 77 : _Bit5_Frozen{5} = 0 : goto DS31 bank4  ; 08  4
   if _Room = 13 && player1x >  46 && player1x <  66 && player1y > 40 && player1y < 46 then _Room = 37 :                  player1y = 84 : _Bit5_Frozen{5} = 0 : goto DS37 bank4  ; 09  8
   if _Room = 15 && player1x >  87 && player1x <  96 && player1y > 60 && player1y < 77 then _Room = 25 : player1x =  78 :                 _Bit5_Frozen{5} = 0 : goto DS25 bank4  ; 10  1
   if _Room = 18 && player1x >  99 && player1x < 113 && player1y > 40 && player1y < 47 then _Room = 38 :                  player1y = 84 : _Bit5_Frozen{5} = 0 : goto DS38 bank4  ; 11  9
   if _Room = 19 && player1x >  51 && player1x <  64 &&                  player1y < 63 then _Room = 26 : player1x =  78 : player1y = 85 : _Bit5_Frozen{5} = 0 : goto DS26 bank4  ; 12  2
   if _Room = 24 && player1x >  58 && player1x <  78 &&                  player1y < 62 then _Room = 32 : player1x =  46 : player1y = 85 : _Bit5_Frozen{5} = 0 : goto DS32 bank4  ; 13  5
   if _Room = 32 && player1x >  88 && player1x < 104 &&                  player1y < 31 then _Room = 34 :                  player1y = 85 : _Bit5_Frozen{5} = 0 : goto DS34 bank4  ; 14  6
   if _Room = 35 && player1x >  96 && player1x < 106 &&                  player1y < 62 then _Room = 36 :                  player1y = 85 : _Bit5_Frozen{5} = 0 : goto DS36 bank4  ; 15  7
   if _Room = 37 && player1x > 124 && player1x < 134 && player1y > 28                  then _Room =  7 :                  player1y = 34 : _Bit5_Frozen{5} = 0 : goto  DS7 bank3  ; 16
   if _Room = 41 &&                                                      player1y < 55 then _Room = 56 : player1x =  25 : player1y = 84 : _Bit5_Frozen{5} = 0 : goto DS56 bank5  ; 17  5
   if _Room = 47 && player1x >  32 && player1x <  52 &&                  player1y < 47 then _Room = 48 :                  player1y = 75 : _Bit5_Frozen{5} = 0 : goto DS48 bank5  ; 18  2
   if _Room = 51 && player1x > 114 && player1x < 134 &&                  player1y < 47 then _Room = 50 :                  player1y = 75 : _Bit5_Frozen{5} = 0 : goto DS50 bank5  ; 19  3
   if _Room = 52 && player1x >  71 && player1x <  90 &&                  player1y < 47 then _Room = 51 :                  player1y = 84 : _Bit5_Frozen{5} = 0 : goto DS51 bank5  ; 20  4
   if _Room = 54 && player1x >  77 && player1x <  90 &&                  player1y < 40 then _Room = 64 :                  player1y = 84 : _Bit5_Frozen{5} = 0 : goto DS64 bank5  ; 21  6
   if _Room = 59 && player1x >  84 && player1x < 101 && player1y > 59 && player1y < 76 then _Room = 23 :                  player1y = 84 : _Bit5_Frozen{5} = 0 : goto DS23 bank4  ; 22  0
mk2
   dim  room_index = temp1
   dim target_bank = temp2
   dim   DS_target = temp3
   if !ridat[_Room] then skip
   room_index = ridat[_Room]-1
   if player1x < P1xlo[room_index]  || player1x > P1xhi[room_index] then skip
   if player1y < P1ylo[room_index]  || player1y > P1yhi[room_index] then skip
   _Bit5_Frozen{5} = 0
   if newxdat[room_index] then player1x = newxdat[room_index]
   if newydat[room_index] then player1y = newydat[room_index]
   _Room  = new_room[room_index]
   DS_target = DStdat[room_index]
   target_bank = tbnkdat[room_index]
   on target_bank goto bnk3 bnk4 bnk5 bnk6
skip
bnk3 goto dispatch3
bnk4 goto dispatch4 bank4
bnk5 goto dispatch5 bank5
bnk6 goto dispatch6 bank6
  ; 00   01   02   03   04   05   06   07   08   09   10   11   12   13   14   15   16   17   18   19   20   21
   data newydat
    85,  85,  84,  85,  18,  85,  84,  77,  84,   0,  84,  85,  85,  85,  85,  34, 84,  75,  75,  84,  84,  84
end
   data newxdat
     0, 117,   0,  78,   0,  21,   0,  77,   0,  78,   0,  78,  46,   0,   0,   0,  25,   0,   0,   0,   0,   0
end
   data P1xlo
    73,  67, 109,  45, 115,  63,  50,  81,  47,  88, 100,  52,  59,  89,  97, 125,   0,  33, 115,  72,  78,  85
end
   data P1xhi
    84,  85, 117,  55, 133,  76,  69,  90,  65,  95, 112,  63,  77, 103, 105, 133, 255, 51, 133,  89,  89, 100
end
   data P1ylo
   255,  46, 255, 255, 255,  53, 255,  56,  41,  61,  41, 255, 255, 255, 255,  29, 255, 255, 255, 255, 255,  60
end
   data P1yhi
    54,  54,  64,  70,  24,  61,  23,  62,  45,  76,  46,  62,  61,  30,  61,   0,  54,  46,  46,  46,  39,  75
end
   data new_room
    46,  42,  39,  27,  37,  40,  66,  31,  37,  25,  38,  26,  32,  34,  36,   7,  56,  48,  50,  51,  64,  23
end
   data DStdat
     1,   0,  10,   3,   8,  11,   7,   4,   8,   1,   9,   2,   5,   6,   7,   0,   5,   2,   3,   4,   6,   0
end
   data tbnkdat
     3,   3,   2,   2,   2,   2,   3,   2,   2,   2,   2,   2,   2,   2,   2,   1,   3,   3,   3,   3,   3,   2
end
   data ridat
     0,   0,   1,   0,   2,   3,   4,   5,   6,   7,   8,   0,   0,   9,   0,  10
     0,   0,  11,  12,   0,   0,   0,   0,  13,   0,   0,   0,   0,   0,   0,   0
    14,   0,   0,  15,   0,  16,   0,   0,   0,  17,   0,   0,   0,   0,   0,  18
     0,   0,   0,  19,  20,   0,  21,   0,   0,   0,   0,  22,   0,   0,   0,   0
end
mk3
 bank 4
dispatch4 on DS_target goto DS23 DS25 DS26 DS27 DS31 DS32 DS34 DS36 DS37 DS38 DS39 DS40 DS37
DS23
DS25
DS26
DS27
DS31
DS32
DS34
DS36
DS37
DS38
DS39
DS40
 bank 5
dispatch5  on DS_target goto DS42 DS46 DS48 DS50 DS51 DS56 DS64 DS66
DS42
DS46
DS48
DS50
DS51
DS56
DS64
DS66
 bank 6
dispatch6
  asm
  echo (.mk2 - .mk1)d
  echo (.mk3 - .mk2)d
end
#152 Lillapojkenpćön OFFLINE
Lillapojkenpćön
    Star Raider
  • 73 posts
Posted Wed Mar 28, 2018 3:10 PM
 ie they produce the same code
Oh, I saw that in the saving cycles thread a long time ago and assumed that was how it worked  :dunce:
#153 bogax ONLINE
bogax
    Dragonstomper
  • 758 posts
Posted Wed Mar 28, 2018 5:08 PM
  A couple more things.
  First I didn't really mention it 'cause it doesn't really pertain
  to tables
  If eg you take the room 2 branch and fall through you go on and
  spend another 150 cycles or so testing a bunch of rooms you already
  know you're not in.
  Second the 180 cycles v 77 + 50 is worst case and only if you change rooms
  If you ran through that code every frame and changed rooms three times
  a second that would still only be 5% of the time
  If you fall through after, say, the two x position tests then break even
  is at about 5 room tests.
  The table code always (potentially) does four tests (not counting the room test)
  Only a few of the string of if tests do that many.
#154 ultima OFFLINE
ultima
    Chopper Commander
  • 155 posts
Posted Sat May 12, 2018 4:48 PM
 I'm wasting my time trying to fix this so I'm just going to kill it here. Maybe I'll start a new project. Maybe I won't.
#155 StanJr OFFLINE
StanJr
    Web-slinger
  • 15,274 posts
  • fun or bust
Posted Sat May 12, 2018 6:24 PM
:-o  :_(  :-o  :_(  :-o  :_(  :-o  :_(
I blame myself.  I asked too much.  This is very distressing news to hear.  Honestly, if you released the last version you uploaded I would buy that on a cart.  This is an incredibly well done game.
#156 kdgarris OFFLINE
kdgarris
    Moonsweeper
  • 292 posts
Posted Sat May 12, 2018 8:23 PM
I worry that I may have inadvertently been discouraging as well. Overcycling was a bit noticeable in spots when I tried it on real hardware, but nothing that makes it unplayable. You have created a pretty awesome game. Put me down for a cart, too, if you choose to publish it.
#157 MrBeefy OFFLINE
MrBeefy
    Dragonstomper
  • 774 posts
Posted Sat May 12, 2018 8:35 PM
Dude this was looking great! Don't kill it! Maybe someone can help you with whatever is causing the problem?
