ultima Posted March 18, 2015 Share Posted March 18, 2015 (edited) I was on RT's site looking at the sprite flipping example and got a question about this dim _Bit2_Flip_p1 = a dim _Bit3_Flip_p0 = a player0: %01111110 %11111111 %00011111 %00000111 %00011111 %11111111 %01111110 end player1: %10101010 %11111111 %10000011 %10101011 %11111111 %10010011 %11011011 %10010011 %01111110 end COLUBK = 0 player0x = 68 : player1x = player0x + 20 player0y = 55 : player1y = 55 __Main_Loop COLUP0 = $1E : COLUP1 = $AE if joy0left then _Bit3_Flip_p0{3} = 0 : _Bit2_Flip_p1{2} = 0 if joy0right then _Bit3_Flip_p0{3} = 1 : _Bit2_Flip_p1{2} = 1 rem ```````````````````````````````````````````````````````````````` rem ` Note from SpiceWare: rem ` rem ` REFPx registers ignore everything except the value in bit 3. rem ` REFP0 = _Bit3_Flip_p0 rem ```````````````````````````````````````````````````````````````` rem ` Note from SpiceWare: rem ` rem ` Multiplying by 2 will shift all bits to the left one rem ` position, so what was in bit 2 ends up in bit 3. rem ` REFP1 = _Bit2_Flip_p1 * 2 drawscreen goto __Main_Loop this section: rem ```````````````````````````````````````````````````````````````` rem ` Note from SpiceWare: rem ` rem ` Multiplying by 2 will shift all bits to the left one rem ` position, so what was in bit 2 ends up in bit 3. rem ` REFP1 = _Bit2_Flip_p1 * 2 is using multiplication so my question is would it have any impact on the number of cycles by just adding _Bit2_Flip_p1 to itself? I modified it and compiled it and found it still takes the same amount of bytes and produces the same result via: REFP1 = _Bit2_Flip_p1 + _Bit2_Flip_p1 I also found that by changing this it also produces the same effect and uses 7 bytes less if joy0left then _Bit3_Flip_p0 = %00000000 : _Bit2_Flip_p1 = %00000000 if joy0right then _Bit3_Flip_p0 = %00000100 : _Bit2_Flip_p1 = %00000100 rem ` REFPx registers ignore everything except the value in bit 3. REFP0 = _Bit3_Flip_p0 + _Bit3_Flip_p0 rem ` Multiplying by 2 will shift all bits to the left one rem ` position, so what was in bit 2 ends up in bit 3. REFP1 = _Bit2_Flip_p1 + _Bit2_Flip_p1 although I am not sure if it saves anything on cycle counting Edited March 18, 2015 by ultima Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted March 18, 2015 Share Posted March 18, 2015 I was just looking at that section of the bB page yesterday and wondering if I should replace that program with this: _ dim _Bit6_Flip_P0 = a dim _Bit7_Flip_P1 = a player0: %01111110 %11111111 %00011111 %00000111 %00011111 %11111111 %01111110 end player1: %10101010 %11111111 %10000011 %10101011 %11111111 %10010011 %11011011 %10010011 %01111110 end COLUBK = 0 player0x = 68 : player1x = player0x + 20 player0y = 55 : player1y = 55 __Main_Loop COLUP0 = $1E : COLUP1 = $AE if joy0left then _Bit6_Flip_P0{6} = 0 : _Bit7_Flip_P1{7} = 0 if joy0right then _Bit6_Flip_P0{6} = 1 : _Bit7_Flip_P1{7} = 1 ;**************************************************************** ; ; Flips player0 sprite when necessary. ; REFP0=0 if _Bit6_Flip_P0{6} then REFP0=8 ;**************************************************************** ; ; Flips player1 sprite when necessary. ; REFP1=0 if _Bit7_Flip_P1{7} then REFP1=8 drawscreen goto __Main_Loop _Seems like it might be easier for people to understand Quote Link to comment Share on other sites More sharing options...
ultima Posted March 18, 2015 Author Share Posted March 18, 2015 (edited) sorry I will simplify the question. Is addition faster than multiplication? example: (moosegizzards * 2) is the same as (moosegizzards + moosegizzards) so I am figuring that in 6502 asm that one of these statements will compile a smaller faster solution. Edited March 19, 2015 by ultima Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted March 19, 2015 Share Posted March 19, 2015 Multiplying by 2 can be accomplished by a left shift (ASL) and is most likely faster than adding a memory location to itself. You could verify this with stella by simply implementing both solutions and then comparing the cycle count in the debugger. If you put a label just before and just after each section of code it should be easy to determine which asm instructions correspond to which basic statements. Quote Link to comment Share on other sites More sharing options...
ultima Posted March 19, 2015 Author Share Posted March 19, 2015 thanks I went with the multiplication and the byte saver if joy0left then _Bit3_Flip_p0 = %00000000 : _Bit2_Flip_p1 = %00000000if joy0right then _Bit3_Flip_p0 = %00000100 : _Bit2_Flip_p1 = %00000100 works like a charm and saved a couple bytes too Quote Link to comment Share on other sites More sharing options...
