Altirra 2.60 released
altirra emulation
948 replies to this topic
#451 fujidude OFFLINE
fujidude
  • 5,217 posts
Posted Mon Jun 29, 2015 9:59 AM
You only get the banner in a cold entry.  In SDX with a CAR.SAV, that means only the 1st entry.  Try launching it via:
CAR /I
That will force a cold entry.
#452 morelenmir OFFLINE
morelenmir
  • 1,544 posts
Posted Mon Jun 29, 2015 10:00 AM
CAR /I
Ahhh...  Good to know fujidude!!!
#453 phaeron OFFLINE
phaeron
  • 2,780 posts
Posted Fri Jul 3, 2015 5:18 PM
Update:
http://www.virtualdu...2.70-test16.zip
http://www.virtualdu...-test16-src.zip
  • Altirra BASIC updated to 1.45 (also attached): Adds PMCOLOR statement.
  • Fix for a couple of U1MB emulation bugs: RTC now works in either clock polarity, flash write enable is no longer reset by warm reset, Option key hold delayed until OS boots.
  • Enhanced text screen mode overhaul: now works in full-screen mode, supports margins and cursor repositioning, supports suspend/resume, supports copy/paste.
  • The Generic disk emulation modes now use the 810 drive sound instead of the XF551.
  • Limit disk step sounds with non-standard disk geometry and acceleration modes.
  • Emulation of MyIDE-II w/updated CPLD now supported.
  • Fixed some issues with false stops in the debugger while using tracepoints.
#454 fujidude OFFLINE
fujidude
  • 5,217 posts
Posted Fri Jul 3, 2015 8:13 PM
Thanks Avery!  I see there is PortableApps.com platform app version of VirtualDUB.  Sure would love to see Altirra make that list.  :)  Or at least relative paths for files and folders within the config and corresponding .INI.  I feel like I may have mentioned this before. but I'm not sure.  If I have then sorry for repeating.
I'll try this new version out and see what pops up.
#455 fujidude OFFLINE
fujidude
  • 5,217 posts
Posted Sat Jul 4, 2015 11:26 AM
So far so good phaeron!
#456 mr-atari OFFLINE
mr-atari
    Dragonstomper
  • 587 posts
Posted Sun Jul 5, 2015 12:31 AM
Emulation of MyIDE-II w/updated CPLD: tested and works nicely :-)
Great job, thanks!
#457 Keatah OFFLINE
Keatah
    Missile Commander
  • 22,192 posts
Posted Sun Jul 5, 2015 12:45 AM
@fujidude @phaeron
Maybe a simple switch in the ini file or something could specify to use relative paths?
@phaeron
Thanks for continuing to push back the frontiers of emulation. When I started out getting into emulators years ago I could have hardly dreamed the form they would eventually take. And I could only begin to guess at all the trouble I would have gotten into having this stuff back then. Yup! Had detectives and all come out to the house to investigate the electrical stuff and hacking we were doing as bratty kids.
Edited by Keatah, Sun Jul 5, 2015 1:05 AM.
#458 Philsan OFFLINE
Philsan
  • 3,888 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Sun Jul 5, 2015 12:56 AM
Update:
Thanks for the update!
One question.
When I press RESET button, memory is cleared and my program is deleted.
In Turbo-Basic XL, my program remains in memory.
#459 Mclaneinc OFFLINE
Mclaneinc
    Retro Madman
  • 6,717 posts
Posted Sun Jul 5, 2015 3:44 AM
But did you ever play tic tac toe with Professor Falken...  :)
#460 phaeron OFFLINE
phaeron
  • 2,780 posts
Posted Sun Jul 5, 2015 12:04 PM
This is normal if you are using the executable version. The operating system doesn't have a reset hook that's called before E: is reinitialized, so it stomps the BASIC interpreter on reset. I have an idea about a possible hack to fix this but haven't tried yet.
If you are using the ROM version, this isn't normal and I'd like to know what OS and DOS versions you are using.
#461 Philsan OFFLINE
Philsan
  • 3,888 posts
Posted Sun Jul 5, 2015 1:22 PM
Yes, I have that problem with Altirra Basic xex version only.
With Turbo-Basic XL I don't have that problem.
#462 phaeron OFFLINE
phaeron
  • 2,780 posts
Posted Sun Jul 5, 2015 1:41 PM
Yeah, that's because TurboBasic XL loads low in memory instead of high where cartridges are, so it doesn't get overwritten by the screen on reset.
#463 gozar OFFLINE
gozar
    Dragonstomper
  • 992 posts
Posted Wed Jul 8, 2015 9:24 PM
It already is a portable app with altirra.ini in the same folder as the executable. I keep it in an Atari8 folder in Owncloud, so I have the same set up no matter what machine I'm on.
#464 fujidude OFFLINE
fujidude
  • 5,217 posts
Posted Wed Jul 8, 2015 10:34 PM
But it's not a PortableApp.com app, like VirtualDub is.  Let me explain my request a little.  I already exclusively use .INI files with Altirra, and I run it on a flash drive.  The .INI option makes it almost portable.  The main reason I can think of that it isn't truly portable, is because it has absolute path references.  This means that if you plug your flash drive into another computer, Altirra will only work right if you are lucky enough to have the flash drive assigned the same drive letter.  Don't even come back with the... but you can force the drive letter you want.  Yes you can.  But it takes bit of configuring, and more importantly, it may not be reasonable to do on a system if that letter is already used for something else, you don't have admin rights on the other computer, or the like.  Relative paths solve all that.  PortableApps.com has a few requirements for software to be published via their repository.  Relative paths is one of those requirements.  I would be tickled pink if Altirra adopted relative paths, at least for the .INI files.  Once that's done, there isn't a lot more to do to satisfy the portableapps.com requirements (at least I don't think so).  There's just stuff like which folder the docs are in etc.  Also, it would some pretty awesome icing on the cake to have it in their repository.  Upgrades are simplicity itself.  Also, there is the ability to set whether you want to get beta level releases of software or not.  So for people like me that like the test versions, I can opt in.  For those that choose not to enable beta level, they would just be offered the stable releases as they come out.  Anyway, since VirtualDub is already on there, I assume Avery is already familiar with making something that would be accepted.
#465 phaeron OFFLINE
phaeron
  • 2,780 posts
Posted Thu Jul 9, 2015 12:19 AM
Actually, the only thing I've ever done to make VirtualDub "portable"... is to integrate over the INI registry code from Altirra. The distinction is a bit silly because presumably the only reason that VirtualDub might satisfy the requirements and Altirra not is that the former never saved its settings automatically.
Altirra does store its paths as relative for files under the program directory.
I would prefer that people get test versions from here and not from a third party site. When people get them externally, they tend not to see any of the notes I attach to the test release.
#466 fujidude OFFLINE
fujidude
  • 5,217 posts
Posted Thu Jul 9, 2015 12:38 AM
I can certainly understand the bit about wanting people to get it here where they can read more info and hopefully provide bug reports more conveniently.  All my ROMS, disk images etc. are not stored under the Altirra folder.  I do sometime run other software which uses some of the same files (including older test versions and the last stable version of Altirra), so to structure all of those kinds of files under one single Altirra folder causes other issues for me.  If Altirra could accept paths such as "\Atari\Disks\ATR" or perhapps "..\..\..\Atari\Disks\ATR" life would be simpler.
Still, I get by.  And as is it is still my favorite A8 emu by far.
#467 gozar OFFLINE
gozar
    Dragonstomper
  • 992 posts
Posted Fri Jul 10, 2015 7:52 AM
Yes, I had to move Altirra out of a folder and put it in my main Atari8 folder. Since everything it accesses will be in the same folder or lower, it uses relative paths for the files, and can transport between machines/drive letters.
My setup:
owncloud
  Atari8
    Support
      ATARIXL.ROM
      ATARIBAS.ROM
    Disks
    ROMS
  Altirra64.exe
  altirra.ini
Hopefully that makes sense. :-)
#468 fujidude OFFLINE
fujidude
  • 5,217 posts
Posted Fri Jul 10, 2015 9:10 AM
Yes, it makes sense (and did before).  But I not only have the latest test version of Altirra going, but also one previous test version and the last stable version as well.  Sure, I could pile all the Altirra executables into one directory, but it would be some work to manage renaming them to unique names and also the various .ini files I use for each as well.
I do find that I really never use the stable version because I like the fixes and features of the newer versions.  However, if I grab a new test version and something gets broken, I like to be able to fall back to the last test version that worked better.  I suppose I could just keep one version out there on top and just replace it with an older one if it comes to that.  Then again, I hope it makes sense why it would just be fantastic to have fully capable relative paths.  :)
Edited by fujidude, Fri Jul 10, 2015 9:11 AM.
#469 fujidude OFFLINE
fujidude
  • 5,217 posts
Posted Fri Jul 10, 2015 9:14 AM
BTW, how do you like that OwnCloud?  I was looking at that back in 2013 and thought it looked cool.  I never bothered to set one up on my VSphere yet though.  Perhaps I should revisit that.
#470 flashjazzcat OFFLINE
flashjazzcat
  • 14,611 posts
Posted Fri Jul 10, 2015 10:46 AM
I have a folder called "Altirra" in program files, and it contains the current test version (named "Altirra.exe") and the previous test version (named "Altirra_old.exe", which has usually been well tested by the time it's replaced). If I find anything got broken in the most recent test, I just delete "Altirra.exe" and rename "Altirra_old.exe" to "Altirra.exe". Seems to work remarkably well.
#471 fujidude OFFLINE
fujidude
  • 5,217 posts
Posted Fri Jul 10, 2015 1:10 PM
Perhaps you might have read where I mentioned that I have already thought of that.  I could put a posting reference in for you if it would help. :P   And also that I have 3 Altirra versions, and potentially multiple .INI files for each (since not all .INI files are compatible between revisions), managing the task of renaming the executables and the sets of .INIs might work well from a functionality aspect, but would be remarkably tedious when it needs to be done.  Sometimes Avery is very fast on his development cycle, and new versions are popping out somewhat rapidly.  It is during those times that fully relative paths would be a great help.  The rest of the time it would still be appreciated, just for file organization purposes if nothing else.  You may recall that in my use case, many of the same files are used by programs other than Altirra.
Anyway, you can poo on my suggestion all day long as unworthy, unnecessary, or what have you, but so far you have not been persuasive.  The part of the equation I don't know is how much trouble it would be for Avery to make it that way, or if he may have specific reasons why he would not want it that way.  So thanks for sharing how much you don't mind manually renaming files, I do appreciate it.  But I'm standing by my suggestion/request. :thumbsup:
Edited by fujidude, Fri Jul 10, 2015 1:10 PM.
#472 flashjazzcat OFFLINE
flashjazzcat
  • 14,611 posts
Posted Fri Jul 10, 2015 5:56 PM
Erm... OK.
#473 fujidude OFFLINE
fujidude
  • 5,217 posts
Posted Fri Jul 10, 2015 5:58 PM
Erm... OK.
Yep, it is.
#474 flashjazzcat OFFLINE
flashjazzcat
  • 14,611 posts
Posted Fri Jul 10, 2015 6:10 PM
What exactly is your problem? Don't answer that here, BTW: please shoot me a PM if you have an issue.
#475 fujidude OFFLINE
fujidude
  • 5,217 posts
Posted Fri Jul 10, 2015 6:18 PM
Says the person who chose to write that in here, rather than following his own advice. :twisted:  PM in a bit.
Edited by fujidude, Fri Jul 10, 2015 6:21 PM.
Also tagged with one or more of these keywords: altirra, emulation
