Atari 2600 VCS PureVideo VEC Professional DIY Composite AV Upgrade Kit
ATARI 2600 VCS PUREVIDEO VCS PROFESSIONAL COMPOSITE AV UPGRADE KIT
REQUIRES GOOD LEVEL OF SOLDERING/TECHNICAL ABILITY TO FIT - READ CAREFULLY BEFORE PURCHASING
The Atari 2600 VCS PureVideo Module is a DIY composite AV kit which allows the 2600 VCS owner to connect to more modern TV's via either composite RCA connectors or SCART (using an adaptor) and thereby removes the need to tune in via the standard RF aerial which can be a real struggle on modern LCD and Plasma displays. Unlike other available mod kits our PureVideo kit requires no cutting of traces or any other deconstruction of the Atari's original circuitry and is therefore totally reversable should you wish to return the system to it's original state
PLEASE NOTE;- This is a self-fit kit which requires some skill and knowledge in both electronics and soldering. A full manual on how to fit this module can be viewed via the following link which you should copy and paste into your web browser;
https://www.dropbox.com/s/76bal44rvp7jfj0/Atari%20Video%20Encoder%20Module%202600VECr52.pdf?dl=0
You can view this manual online or download onto your PC to study at your convenience. Please be sure to read this manual thoroughly BEFORE PURCHASING to ensure you feel comfortable that you have the required level of ability to install this kit as we will not be held responsible for damage caused due to poor installation. If you do not feel you have the required skill level to fit this we can fit it for you for a small fee (please contact for more details)
Each kit comprises of;
  • 1x 2600VEC r5.2 Encoder module
  • 1x Composite AV cable with RCA connection
  • 1x 3.5mm Chassis mount low profile stereo socket
  • 1x 11” length of quality 2 core screened cable for interconnection
Module supports both PAL and NTSC (North America) but does not support SECAM
Don't take my word for how good this module is, check this independant review; https://bytemyvdu.wordpress.com/2015/02/26/interview-with-atari-vcs-2600-purevideo-vec-module-creators/
£15 plus P&P
Edited by EvilDoctorShortCrust
  • 3 weeks later...
  • 11 months later...
