[LYNX] Rewritable Multigame Cartridge
228 replies to this topic
#51 jfmateos OFFLINE
jfmateos
    Chopper Commander
  • 106 posts
Posted Thu May 14, 2015 11:26 AM
The first batch has been sent.
I will make a second batch... there are still a couple of cards of this second batch that are not reserved; if someone is interested, please inquiry through my contact form:
http://www.vectrex.h....php/en/contact
It will take at least two weeks to receive all the components.
Thanks for supporting my developments.
#52 Guitari OFFLINE
Guitari
  • 1,719 posts
Posted Thu May 14, 2015 12:02 PM
I'm in for one please.
I thought I was in the first batch.
#53 jfmateos OFFLINE
jfmateos
    Chopper Commander
  • 106 posts
Posted Thu May 14, 2015 1:58 PM
Sorry Guitari... there were only a few available... if you are interested in reserve one in the second batch, there is still one available... please inquiry through my contact form:
#54 vectrexroli OFFLINE
vectrexroli
    Moonsweeper
  • 491 posts
Posted Thu May 14, 2015 10:42 PM
Message sent via your contact form. ;-)
Edited by vectrexroli, Thu May 14, 2015 10:42 PM.
#55 gambler172 OFFLINE
gambler172
  • 3,353 posts
  • none
Posted Fri May 15, 2015 11:01 AM
Hi
hope you got my email?
I want one too.......i sent the mail at 8th may
But i never got an answer :(
greetings Walter
Edited by gambler172, Fri May 15, 2015 11:03 AM.
#56 Stephen OFFLINE
Stephen
  • 7,544 posts
  • A8 Gear Head
Posted Fri May 15, 2015 1:46 PM
Great - I'd like one.
#57 walter_J64bit OFFLINE
walter_J64bit
  • 5,210 posts
Posted Wed May 20, 2015 4:15 AM
Say can we get pics of the cart?
#58 jfmateos OFFLINE
jfmateos
    Chopper Commander
  • 106 posts
Posted Wed May 20, 2015 4:25 AM
Yes walter, I will show pictures tomorrow... I was amazed that nobody asked for pictures :-D
#59 walter_J64bit OFFLINE
walter_J64bit
  • 5,210 posts
Posted Thu May 21, 2015 8:29 PM
bump! :-D
#60 Guitari OFFLINE
Guitari
  • 1,719 posts
Posted Thu May 21, 2015 8:46 PM
Did you get my email? Many thanks :)
#61 jfmateos OFFLINE
jfmateos
    Chopper Commander
  • 106 posts
Posted Fri May 22, 2015 5:17 AM
Excuse me walter... i was a bit busy... here you have a few photos
#62 Joe Stella OFFLINE
Joe Stella
    Moonsweeper
  • 334 posts
Posted Fri May 22, 2015 6:50 AM
That's awesome! love the dial.
#63 GadgetUK OFFLINE
GadgetUK
  • 1,946 posts
Posted Fri May 22, 2015 6:53 AM
Great stuff!  Hoping mine arrives tomorrow!
#64 walter_J64bit OFFLINE
walter_J64bit
  • 5,210 posts
Posted Fri May 22, 2015 9:54 AM
Awesome! Thanks!
#65 7800fan OFFLINE
7800fan
  • 5,606 posts
Posted Fri May 22, 2015 7:37 PM
Looks good!  Using rotary encoder rather than dip switch seems interesting.
#66 mvirtuale OFFLINE
mvirtuale
    Chopper Commander
  • 175 posts
Posted Sat May 23, 2015 2:24 AM
#67 GadgetUK OFFLINE
GadgetUK
  • 1,946 posts
Posted Sat May 23, 2015 4:22 AM
Got mine today!  Works great!  Note with 512Kb images you need to use the link on Mateos website in order for it to structure the bytes correctly:- http://www.vectrex.h...alynxconverter/
I did try writting standard 512Kb .lyx files but I guess since there's only one way the flash ROM is wired up that's why they need reformatting using his link.  256Kb ROMs work as straight .lyx files I think.
#68 GadgetUK OFFLINE
GadgetUK
  • 1,946 posts
Posted Sat May 23, 2015 5:43 AM
Just looking at how he's restructured the 512Kb ROMs here - the first 1024 bytes (minus 64 byte header obviously) match the same.  Then the data beyond $400 is completely different.
eg. 8F 04 FB 09 becomes 73 33 55 A2
I guess that makes sense, bits must be transposed somewhere.  I've never really looked at the 512Kb layout much.
#69 jfmateos OFFLINE
jfmateos
    Chopper Commander
  • 106 posts
Posted Sat May 23, 2015 5:59 AM
Thank you very much GadgetUK,
This is the pseudocode I use to rewrite the 512kb.
  • Ignore 64 bytes header
  • do i=0;i<256
    • read 1024 bytes from source file and write them in the output file
    • read 1024 bytes just to forward the index inside the file
  • enddo
  • rewind the source file to start
  • do i=0;i<256
  • enddo
And this is the soruce code in php:
//Desechar la cabecera de 64 bytes
fread ( $rh , 64 );
//Escribir los primeros semi-bloques
for($i=0;$i<256;$i++){
	$cadena=fread($rh,1024);
	echo $cadena;
	fread($rh,1024);
//Escribir los segundos semi-bloques
rewind($rh);
fread ( $rh , 64 );
	fread($rh,1024);
	echo $cadena;
#70 GadgetUK OFFLINE
GadgetUK
  • 1,946 posts
Posted Sat May 23, 2015 6:05 AM
Thanks for sharing this! I will update my utility to handle this format! Great work, it's a sweet little cart - very clever using mountable drive via that PIC chip! Very elegant design!
#71 GadgetUK OFFLINE
GadgetUK
  • 1,946 posts
Posted Sat May 23, 2015 8:20 AM
Thanks, I've added the option into my utility and tested other size of ROMs.  It looks like 256Kb EPYX type 'just work' without any issues.  In order to get 128Kb ROMs working I use the mode in my util to convert 128Kb -> 256Kb (EPYX), then they work fine.  Now has the 512Kb -> 512Kb (Mateos) option as well.
https://www.dropbox.....0.0.1.zip?dl=0
EDIT: Can I ask a question - how does the 512Kb thing work regards the rotary switch?  For example I have a 512Kb game in the 0 slot, and that works.  In slot 1 I have a 256Kb game and that works OK - this is NOT what I would have expected, I assumed that in 512Kb setting the first game would fill slots 0 (lower 256Kb) and slot 1 (upper 256Kb).  Does 512Kb in the first slot mean that 0 and 8 are used?
Edited by GadgetUK, Sat May 23, 2015 8:29 AM.
#72 karri OFFLINE
karri
  • 2,592 posts
Posted Sat May 23, 2015 9:41 AM
Yes! I got my copy also.
In order to program a lnx file you need to strip the first 64 bytes. For Linux people this is simply
tail -c 262144 mygame.lnx > mygame.lyx
Then you just connect your card using USB and drag the lyx file to the cart. Eject the drive and enjoy the game :)
Edit: In order to write games with 512 bytes/block you need to do this:
tail -c 131072 mygame.lnx > mygame.tmp
split -b 512 mygame.tmp
for fn in `ls x??`; do
cat $fn >> mygame.lyx
done
rm x?? mygame.tmp
Edited by karri, Sat May 23, 2015 10:00 AM.
#73 StijnDW OFFLINE
StijnDW
    Star Raider
  • 63 posts
Posted Sat May 23, 2015 10:08 AM
GadgetUK,
I also asked jfmateos.
For the 512k roms slots 0 and 8 / 1 and 9 / 2 and a /... are used in pairs so for selecting the games use 0 up to 7.
Also for quickly loading multiple games there is no need to disconect the USB cable.
Use this procedure
  1. Select first slot to load and connect USB Cable
  2. Copy over the ROM file.
  3. Delete the ROM file (Shift-Del)
  4. Select new slot with switch
  5. Continue from step 2 onwards until all slots are loaded.
For making 128K ROMs work just double them up and load them up to the cartridge.
Edited by StijnDW, Sat May 23, 2015 10:12 AM.
#74 jp48 OFFLINE
jp48
    Chopper Commander
  • 103 posts
Posted Sat May 23, 2015 10:12 AM
I am interested of this, still any left ? Works with homebrew stuff as well ? Just got my first ever Lynx today :) !
#75 jfmateos OFFLINE
jfmateos
    Chopper Commander
  • 106 posts
Posted Sat May 23, 2015 10:13 AM
¡Guauuuuu! Thank you very much for your video-review...
The instructions can be found in my website: http://www.vectrex.h.../howto-burn-rom
If you select 512kb mode, the slots are combined in pairs: 0 and 8, 1 and 9, 2 and A, and so on.
If you write a 512kb in slot 0 it will also extend into slot 8... so be carefull; if you had a 256kb game in slot 8 it would be overwritten by the 512kb game.
thank you very much Gadgetuk
