+acadiel Posted April 12, 2015 Share Posted April 12, 2015 Every game is a little different. Take, for example, the Vita MMORPG type game Sword Art Online, Hollow Fragment. (Guide is here.) There's a long winded discussion at the first URL linked about someone wanting to know how DPS Total, DMG, ATK and STR all factored into the game... for example: "The axe esoteric skill has a (+STR180% & VIT180% & DEX100%) adjustment value, which is calculated as (+DMG10% & STR190% & VIT180% & DEX100%). In terms of damage increases for that esoteric skill, 1 STR = 1.05 VIT = 1.9 DEX = 19 DMG. If you are using an axe, weapon parameters to prioritise would be would be STR > VIT > DEX > DMG. When casting the esoteric skill, an axe with 100 DMG and 50 STR would deal the same damage as an axe with 1050 DMG and 0 STR." So, mapping to skills and items is one thing - how many different assets are you going to have that will modify damage stats? Some other things (just thinking out loud): You can even minimize damage by applying a divider if you have a "block" or "dodge" move. Also, take into account a "miss" being completely random, and causing 0 damage. You could miss swinging a weapon, or you can even miss dodging (which means you get whatever damage you were intended to anyway). I can't wait to see your game! Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 15, 2015 Author Share Posted April 15, 2015 (edited) Here's a bare-bones tester (RANDOMIZED) to test out some of the formula ideas from Ksarul.... Seems to work really well. I played it 6 times, won 4 lost 2. Thanks for the formula, Jim! I needed to tweak the variable values a little bit to create parity, but the equation works nicely! Paste into Classic99 and RUN to whack a skeleton with a tree branch! 100 RANDOMIZE 110 HEROHP=20 :: HEROMHP=20 120 HEROATK=5 :: HEROATKMOD=4 130 HERODEF=5 :: HERODEFMOD=2 140 SKHP=15 150 SKATK=5 :: SKATKMOD=4 160 SKDEF=3 :: SKDEFMOD=2 170 TURN=0 180 CALL CLEAR 190 DISPLAY AT(1,5):"BATTLE TEST"; 200 DISPLAY AT(3,1):"HERO HP:";HEROHP;"/";HEROMHP 210 DISPLAY AT(4,1):"SKELETON HP:";SKHP 220 DISPLAY AT(10,1):" " :: DISPLAY AT(12,1):" " 230 IF TURN=1 THEN GOSUB 350 240 DISPLAY AT(6,1):"PRESS 1 TO ATTACK" 250 CALL KEY(0,K,S):: IF S=0 THEN GOTO 250 260 ON K-48 GOSUB 270 270 DISPLAY AT(10,1):"HERO ATTACKS!" :: DISPLAY AT(6,1):" " :: GOSUB 470 280 DAM=(INT(RND*HEROATK)+HEROATKMOD)-(INT(RND*SKDEF)+SKDEFMOD) 290 IF DAM<1 THEN DAM=0 :: DISPLAY AT(12,1):"MISS!" :: GOSUB 470 300 IF DAM>0 THEN DISPLAY AT(12,1):"DIRECT HIT!" :: GOSUB 470 310 SKHP=SKHP-DAM :: IF SKHP<1 THEN GOSUB 430 320 TURN=1 330 GOTO 200 340 RETURN 350 DISPLAY AT(10,1):"SKELETON ATTACKS!" :: GOSUB 470 360 DAM=(INT(RND*SKATK)+SKATKMOD)-(INT(RND*HERODEF)+HERODEFMOD) 370 IF DAM<1 THEN DAM=0 :: DISPLAY AT(12,1):"MISS!" :: GOSUB 470 380 IF DAM>0 THEN DISPLAY AT(12,1):"DIRECT HIT!" :: GOSUB 470 390 HEROHP=HEROHP-DAM :: IF HEROHP<1 THEN GOSUB 450 400 TURN=0 410 GOTO 200 420 RETURN 430 DISPLAY AT(20,1):"SKELETON IS DEAD!" 440 END 450 DISPLAY AT(20,1):"HERO IS DEAD!" 460 END 470 FOR I=1 TO 300 :: NEXT I 480 RETURN Edited April 15, 2015 by Opry99er Quote Link to comment Share on other sites More sharing options...
unhuman Posted April 15, 2015 Share Posted April 15, 2015 You could easily wrap this in another loop and run X iterations to ensure you get a distribution you like. Quote Link to comment Share on other sites More sharing options...
RXB Posted April 15, 2015 Share Posted April 15, 2015 Hmmm played it with Classic99 on XB, RXB 2012, RXB 2015 and did not win once? Played 10 games each, the XB one was the only one I got close for the Skeleton won. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 15, 2015 Author Share Posted April 15, 2015 Got waxed, eh Rich? LOL!! Maybe youre not holding your tongue right or something, I dont know. Ill give it another spin... But I did win 4 of 6 last night... Ill check to make sure I posted the most recent code (with updated DEF and ATK values) Thanks for giving it a shot. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 15, 2015 Author Share Posted April 15, 2015 Played it one time just now. One victory. Don't know, Rich.. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 15, 2015 Author Share Posted April 15, 2015 You could change line 130 to SKDEFMOD=1. Thatll tip the scales some. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 15, 2015 Author Share Posted April 15, 2015 Every game is a little different. Take, for example, the Vita MMORPG type game Sword Art Online, Hollow Fragment. (Guide is here.) There's a long winded discussion at the first URL linked about someone wanting to know how DPS Total, DMG, ATK and STR all factored into the game... for example: "The axe esoteric skill has a (+STR180% & VIT180% & DEX100%) adjustment value, which is calculated as (+DMG10% & STR190% & VIT180% & DEX100%). In terms of damage increases for that esoteric skill, 1 STR = 1.05 VIT = 1.9 DEX = 19 DMG. If you are using an axe, weapon parameters to prioritise would be would be STR > VIT > DEX > DMG. When casting the esoteric skill, an axe with 100 DMG and 50 STR would deal the same damage as an axe with 1050 DMG and 0 STR." So, mapping to skills and items is one thing - how many different assets are you going to have that will modify damage stats? Some other things (just thinking out loud): You can even minimize damage by applying a divider if you have a "block" or "dodge" move. Also, take into account a "miss" being completely random, and causing 0 damage. You could miss swinging a weapon, or you can even miss dodging (which means you get whatever damage you were intended to anyway). I can't wait to see your game! I somehow missed this post, Jon! Thanks for posting that link... Some cool info there, for sure. As far as the melee attacks in my own battle engine, really only focusing on the ATK value, the modifier(s) of that value (as I believe STR is simply a part of the ATK value as a whole and I really do not see any need for it in battle) and DEF and it's modifier(s). Magic will be a little more detailed, by necessity... It is in this field I will be focusing a good chunk of my attention on study and research. MATK and MDEF are primaries, but Class and level will also come into play. Elemental considerations will also be factored... If you are facing an Ice Golem and you cast FireSlash, you will do significant damage, because of the elemental differences. Conversely, IceBlast will do next to nothing. Much of the elemental stuff will be tied into what is equipped to a specific party member... If you're facing a Flame Wraith and you have a FireShield equipped, damage from melee attacks from the Wraith will be significantly lessened. There is still much reaearch and testing to do, but I feel I have a pretty good feel on what I am HOPING to accomplish. Will take work, time, study, coding, debugging, and a ton of testing and adjusting to get it where I want it. Thanks for responding, bud. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 16, 2015 Author Share Posted April 16, 2015 Looks like I WILL need some additional modifiers. LOL!! For class differentiation, I would like for stats to grow at differing levels. It is easy to differentiate class at low levels, as I can just have different starting values which distinguish party members from one another... In this way, a Level 1 thief could have an ATK value if 1, and a Level 1 fighter could have an ATK value of 5. Good separation there. However, if both members increase levels simultaneously and their stats increase at the same rate, a Level 20 thief and a Level 20 fighter would have relatively identical ATK values when it comes to combat. Basically I am saying, without additional modifiers, the higher the level, the less the classes matter. I do not want that. I need to study some more, obviously... At LEAST I will need modifiers like STR, INT, and AGI. (INT more for the magic casting and defense in battle) Ya know... It pays to study the wheel before trying to reinvent it. LOL!! Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 16, 2015 Author Share Posted April 16, 2015 The more I think about this, ATK and DEF should be derived variables... Maybe, something like: ATK=STR+VIT :: DEF=AGI+VIT ATKMOD=WEAPVAL :: DEFMOD=ARMORVAL Then... DAM=(INT(RND*ATK)+ATKMOD)-(INT(RND*DEF)+DEFMOD) In this way, the algorith stays the same, but the variables used can be modified properly with level gains.. FIGHTER LEVEL UP: STR=STR+2 :: AGI=AGI+1 :: VIT=VIT+1 THIEF LEVEL UP: STR=STR+1 :: AGI=AGI+2 :: VIT=VIT+1 This brings the question... Should VITality ALSO be derived? It can be modified based on condition (poisoned, burdoned, etc) but should it be derived in some regard from the difference between MAX HP and CURRENT HP? For instance, if your party member has a max health of 40, but is beat up to sh** and has a current HP is 5, should VITality not decrease? This would make melee attacks while injured less effective... Seems realistic to me. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted April 16, 2015 Author Share Posted April 16, 2015 Okay... In my insanity, I attempted to come up with a way to weight the character's physical "state" into the effectiveness (or lack thereof) of attack and defend. What resulted was a bloody mess.... I was able to get something to work, though... I had to drop the priority of that factor down quite a bit, but here's one way to make it work. Notice this code is slightly different than the last incarnation I posted. ATK and DEF are now "derived" variables, STRength, AGIlity, and VITality have been added. VIT is a derived variable, one which attempts to determine the character's physical state by dividing his HP by his MHP... Them multiplying by 5 to give a vitality rating. ( I initially multiplied by 10, but this was madness)... This is added to STR (for attack) and AGI (for defense)... Notice that ATKMOD and DEFMOD have been replaced by more concrete values, WEPVAL (the +rating of the weapon equipped) and ARMVAL (the +rating of the armor equipped)..... It is a work-in-progress, but I think I'm at least getting SOMEWHERE in the melee portion of the battle sequence. Tweaking needs to occur, but if you play through this a few times, you will see that the power of the attacks and the effectiveness of the defense decrease as the player "weakens"... The farther the HP drops from the MHP, the more "tired" the character becomes. If you want to REALLY see this in action, change the values in LINE 110 to "100" and "100" and change the value in LINE 180 to "100"... This will give both the hero and the skeleton much higher starting health points, letting the demo run a bit longer so you can observe the changes in effectiveness. This will not affect VITality, as it is simply a calculation of percentage of health... wouldn't matter if you changed the value to 1,000,000, the number would be the same. 100 RANDOMIZE //REM STATS 110 HEROHP=30 :: HEROMHP=30 120 HEROSTR=4 :: HEROAGI=4 130 HEROVIT=(INT(HEROHP/HEROMHP)*5) 140 HEROATK=HEROSTR+HEROVIT 150 HERODEF=HEROAGI+HEROVIT 160 HEROWEPVAL=3 170 HEROARMVAL=2 180 SKHP=30 190 SKATK=6 :: SKWEPVAL=6 200 SKDEF=5 :: SKARMVAL=3 210 TURN=0 //REM START 220 CALL CLEAR 230 DISPLAY AT(1,5):"BATTLE TEST"; 240 DISPLAY AT(3,1):"HERO HP:";HEROHP;"/";HEROMHP 250 DISPLAY AT(4,1):"SKELETON HP:";SKHP 260 DISPLAY AT(10,1):" " :: DISPLAY AT(12,1):" " 270 IF TURN=1 THEN GOSUB 390 //REM Hero Attack 280 DISPLAY AT(6,1):"PRESS 1 TO ATTACK" 290 CALL KEY(0,K,S):: IF S=0 THEN GOTO 290 300 ON K-48 GOSUB 310 310 DISPLAY AT(10,1):"HERO ATTACKS!" :: DISPLAY AT(6,1):" " :: GOSUB 510 320 DAM=(INT(RND*HEROATK)+HEROWEPVAL)-(INT(RND*SKDEF)+SKARMVAL) 330 IF DAM<1 THEN DAM=0 :: DISPLAY AT(12,1):"MISS!" :: GOSUB 510 340 IF DAM>0 THEN DISPLAY AT(12,1):"DIRECT HIT!" :: GOSUB 510 350 SKHP=SKHP-DAM :: IF SKHP<1 THEN GOSUB 470 360 TURN=1 370 GOTO 240 380 RETURN //REM Skeleton Attack 390 DISPLAY AT(10,1):"SKELETON ATTACKS!" :: GOSUB 510 400 DAM=(INT(RND*SKATK)+SKWEPVAL)-(INT(RND*HERODEF)+HEROARMVAL) 410 IF DAM<1 THEN DAM=0 :: DISPLAY AT(12,1):"MISS!" :: GOSUB 510 420 IF DAM>0 THEN DISPLAY AT(12,1):"DIRECT HIT!" :: GOSUB 510 430 HEROHP=HEROHP-DAM :: IF HEROHP<1 THEN GOSUB 490 440 TURN=0 450 GOTO 240 460 RETURN //REM DeadSkeleton 470 DISPLAY AT(20,1):"SKELETON IS DEAD!" 480 END //REM DeadHero 490 DISPLAY AT(20,1):"HERO IS DEAD!" 500 END 510 FOR I=1 TO 300 :: NEXT I 520 RETURN Quote Link to comment Share on other sites More sharing options...
