Asmusr Posted May 14, 2015 Author Share Posted May 14, 2015 Here is another small demo of software sprites, where they are moving around. Note that I'm drawing to a CPU RAM buffer and copying the whole thing to the VDP. The speed is not impressive, but perhaps it could be used for something? SOFTSPRITE.dsk SoftSprites.a99 3 Quote Link to comment Share on other sites More sharing options...
artrag Posted May 14, 2015 Share Posted May 14, 2015 how to load it i classic 99 ? Quote Link to comment Share on other sites More sharing options...
Opry99er Posted May 14, 2015 Share Posted May 14, 2015 (edited) You will need ti either mount the .dsk file into the DSK1 slot, or you can break the files out into FIAD format and put them into the DSK1 folder in the Classic99 subdirectory. Then I think it is an EA3 file... Editor Assembler option 3... But I have not tried it yet... Edited May 14, 2015 by Opry99er Quote Link to comment Share on other sites More sharing options...
Opry99er Posted May 14, 2015 Share Posted May 14, 2015 (edited) Rasmus, I could see a very cool war simulation game using this effect. Risk meets 3-D chess meets Age of Empires. Edited May 14, 2015 by Opry99er Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted May 14, 2015 Share Posted May 14, 2015 You will need ti either mount the .dsk file into the DSK1 slot, or you can break the files out into FIAD format and put them into the DSK1 folder in the Classic99 subdirectory. Then I think it is an EA3 file... Editor Assembler option 3... But I have not tried it yet... It is, in fact, an EA3 file. ...lee Quote Link to comment Share on other sites More sharing options...
artrag Posted May 29, 2015 Share Posted May 29, 2015 General question: how do I know what is the name of the file to be used for loading a EA3 file? After having typed 3 in the editor/assembler, I try to type DSK1.SOMENAME but I haven't the faintest idea of how to get this "somename" from the dsk file. Is there a DIR command or something similar ? Quote Link to comment Share on other sites More sharing options...
Asmusr Posted May 29, 2015 Author Share Posted May 29, 2015 The file is called: SOFT It's an absolute mystery for me why Texas Instruments did not provide a DIR/CAT command in Extended Basic, or at least in Editor/Assembler. There is a BASIC program you can load, but it's really lame that you have to change the disk to see what's on another disk. With emulation you can use TI99Dir or TIImageTool on the host system (both, I think, are linked from the development resources thread). If you use my emulator, Js99er.net, you can just go to the Disk Manager tab. On the TI you have to open Disk Manager 2000 or equivalent (that has a a catalog command) and then remember the name and go back to Editor/Assembler to run it Gazoo has added a CAT command to the menu of the XB 2.7 cartridge - probably the most useful utility ever. You can just press 1-9 to catalog disk DSK1-9. (Js99er.net contains an older version of the XB27 cartridge without this feature). Quote Link to comment Share on other sites More sharing options...
+mizapf Posted May 29, 2015 Share Posted May 29, 2015 The HFDC offers a CALL DIR which produces a catalog listing. I don't know of other controllers, though. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted May 29, 2015 Share Posted May 29, 2015 The file is called: SOFT It's an absolute mystery for me why Texas Instruments did not provide a DIR/CAT command in Extended Basic, or at least in Editor/Assembler. There is a BASIC program you can load, but it's really lame that you have to change the disk to see what's on another disk. With emulation you can use TI99Dir or TIImageTool on the host system (both, I think, are linked from the development resources thread). If you use my emulator, Js99er.net, you can just go to the Disk Manager tab. On the TI you have to open Disk Manager 2000 or equivalent (that has a a catalog command) and then remember the name and go back to Editor/Assembler to run it Gazoo has added a CAT command to the menu of the XB 2.7 cartridge - probably the most useful utility ever (Js99er.net contains an older version of the XB27 cartridge without this feature). Course in RXB/REA you get a directory function and if you hit enter on a program it loads it into the proper load screen.. EA3 EAprog or XB Greg 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted May 30, 2015 Share Posted May 30, 2015 I certainly agree that TI should have built in a directory/catalog function into TI Basic and TI Extended Basic; but, you can build your own routine quite easily. The directory or catalog is a function of the DSR and can be reached by opening “DSKn.”, where ‘n’ is the disk number, or “DSK.diskname.” for INPUT as an INTERNAL, RELATIVE file. Each record is exactly 38 bytes long and contains one string (10 chars max) and three floating point numbers (8 bytes each). Each entry is preceded by a byte count, which is the reason for the 38-byte record size: 1 + 10 + 3 * ( 1 + 8 ) = 38. For a catalog of “DSK1” in TI Basic and TI Extended Basic, you can open the directory listing with OPEN #1:"DSK1.",INPUT,INTERNAL,RELATIVE and get the information for each entry with INPUT #1:FNAME$,FTYPE,FSECTORS,RECBYTES The first record (record 0) is the volume inforamtion for the disk: FNAME$ = diskname, FTYPE = 0, FSECTORS = sectors on disk excluding VIB and FDIR sectors, RECBYTES = free sectors on disk Each record thereafter is FNAME$ = filename, FTYPE = filetype number FSECTORS = sectors occupied by the file on disk, including the FDR sector, RECBYTES = bytes per record (0 for memory image files) You can read until FNAME$ has zero length, indicating no more file entries in the FDIR. It's a little more difficult in Assembly Language because of the floating-point format of the numbers in each record. Both @Willsy (TurboForth) and I (fbForth 2.0) have provided loadable DIR words for a directory/catalog listing in Forth. Note: The above information was extracted from Functional Specification for the 99_4 Disk Peripheral V3.0 03-28-1983.pdf and Thierry Nouspikel's site's Device Service Routines page (scroll down to “0 Open directory”). ...lee Quote Link to comment Share on other sites More sharing options...
artrag Posted May 30, 2015 Share Posted May 30, 2015 Not very user friendly... Quote Link to comment Share on other sites More sharing options...
Opry99er Posted May 30, 2015 Share Posted May 30, 2015 Who wants to bang out the XB cataloguing proggy based on the above info? I am sure some already exist... But it would be fun to write another. Quote Link to comment Share on other sites More sharing options...
RXB Posted May 30, 2015 Share Posted May 30, 2015 Course in RXB/REA you get a directory function and if you hit enter on a program it loads it into the proper load screen.. EA3 EAprog or XB Greg https://youtu.be/Tv3rVe4ZVQY RXB 2015 D is done. 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 30, 2015 Share Posted May 30, 2015 Not very user friendly... About as friendly as on the Commodore. You do pretty much the same thing in BASIC, or you LOAD"$",8 which is destructive to the program in memory. This is where I think systems of the era with a DOS (Apple, Atari, etc.) or BASIC DOS commands (Apple, Atari, Commodore 128, etc.) really shined. Commodore systems have numerous different DOS wedges, in the form of software wedges, "overlay" ROMs like JiffyDOS, or fast load cartridges (Warp Speed being my favorite,) each providing a special command for directory listing. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted May 31, 2015 Share Posted May 31, 2015 Who wants to bang out the XB cataloguing proggy based on the above info? I am sure some already exist... But it would be fun to write another. The following program works in both TI Basic and XB. It can, of course, be reworked into a subroutine or subprogram: 100 FTYPE$(1)=" D/F" 110 FTYPE$(2)=" D/V" 120 FTYPE$(3)=" I/F" 130 FTYPE$(4)=" I/V" 140 FTYPE$(5)=" PRG" 150 FTYPE$(6)=" ???" 160 SPACE$=" " 170 CALL CLEAR 180 INPUT "Disk number: ":D$ 190 IF LEN(D$) = 0 THEN 1000 200 D$=SEG$(D$,1,1) 210 FILE$="DSK"&D$&"." 220 OPEN #1:FILE$,INPUT,INTERNAL,RELATIVE 230 INPUT #1:FN$,FT,SEC,BPR 235 LCT=7 240 PRINT "Disk Name: ";FN$ 250 PRINT " ";SEC;"sectors ";BPR;"free" 260 PRINT 270 PRINT "Filename Secs Type B/R P" 280 PRINT "---------- ---- ---- --- -" 290 INPUT #1:FN$,FT,SEC,BPR 300 IF LEN(FN$) = 0 THEN 1000 310 P$=" " 320 IF FT >= 0 THEN 350 330 P$=" P" 340 FT=ABS(FT) 350 FT$=FTYPE$(6) 360 IF FT > 5 THEN 380 370 FT$=FTYPE$(FT) 380 SEC$=STR$(SEC) 390 BPR$=" " 400 IF BPR = 0 THEN 420 410 BPR$=STR$(BPR) 420 LN$=FN$&SEG$(SPACE$,1,10-LEN(FN$))&SEG$(SPACE$,1,5-LEN(SEC$))&SEC$&FT$&SEG$(SPACE$,1,5-LEN(BPR$))&BPR$&P$ 430 PRINT LN$ 440 LCT=LCT+1 450 IF LCT < 23 THEN 290 460 PRINT "..tap <enter> for next page" 470 CALL KEY(0,K,S) 480 IF S = 0 THEN 470 490 LCT = 3 500 CALL CLEAR 510 GOTO 270 1000 CLOSE #1 1010 END ...lee Quote Link to comment Share on other sites More sharing options...
artrag Posted May 31, 2015 Share Posted May 31, 2015 Msx basic has the command files Msx dos has the command dir Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted June 2, 2015 Share Posted June 2, 2015 There was no reason to have a DIR command as standard on the TI99, as 'disks' came later on. the system shipped with 'cassette tape' not like you can do a 'catalog' on a tape! All tho when TI released their 'disk controller' they should had added a CALL CAT or CALL DIR command in the DSR, but space was tight, and they thought have a few lines in basic was good enough and more useful, a basic program could expand on the listing, format it the way it wants, allow you to view or load a file afterwards, etc. if the programmer was willing to add the extra lines to the sample code in the manual. Quote Link to comment Share on other sites More sharing options...
Willsy Posted June 2, 2015 Share Posted June 2, 2015 They could have also added the commands as GPL code to selected cartridges, such as ED/AS. This would also have been usable from BASIC. Shame they didn't add it. 2 Quote Link to comment Share on other sites More sharing options...
