copper20 Posted April 18, 2015 Share Posted April 18, 2015 When I eject the disc drive on my PS2 without any discs inside it, it makes a weird scratchy sound when I'm ejecting the drive. Is this normal for it? If not, how do I fix this? Quote Link to comment Share on other sites More sharing options...
Tempest Posted April 19, 2015 Share Posted April 19, 2015 Put some lithium grease on the teeth on the bottom of the tray. That should fix it. Quote Link to comment Share on other sites More sharing options...
copper20 Posted April 19, 2015 Author Share Posted April 19, 2015 So does this mean I have to take the PS2 apart again, and if I don't bother fixing this, will it damage my games? Quote Link to comment Share on other sites More sharing options...
Tempest Posted April 19, 2015 Share Posted April 19, 2015 No, just slide the tray out and look underneath. No it won't damage your games either. It's just a gear sticking. Quote Link to comment Share on other sites More sharing options...
copper20 Posted April 19, 2015 Author Share Posted April 19, 2015 Oh man that's simple then. Thanks. In either case as long as it isn't damaging my stuff it's insignificant. Quote Link to comment Share on other sites More sharing options...
Tempest Posted April 20, 2015 Share Posted April 20, 2015 Oh man that's simple then. Thanks. In either case as long as it isn't damaging my stuff it's insignificant. True, but it's a simple fix so I'd recommend doing it. Over the long term it can't be good for the tray to keep grinding like that. Quote Link to comment Share on other sites More sharing options...
copper20 Posted April 20, 2015 Author Share Posted April 20, 2015 (edited) Ok I checked and I don't have lithium grease. What other types work? And can I use q-tips or does it have to be applied a different way? Also how much do I use from a measurement? Edited April 20, 2015 by copper20 Quote Link to comment Share on other sites More sharing options...
Tempest Posted April 20, 2015 Share Posted April 20, 2015 I just lightly coated it with my finger. You can get lithium grease from a hardware store for $3-$5. I'm not sure what else you could use, some other type I grease I suppose. Quote Link to comment Share on other sites More sharing options...
fujidude Posted April 20, 2015 Share Posted April 20, 2015 Ok I checked and I don't have lithium grease. What other types work? And can I use q-tips or does it have to be applied a different way? Also how much do I use from a measurement? Silicone based grease should be highly compatible with plastic parts too. I'm sure there is a good chance that petroleum based greases would work out okay, but there is always some chance it will attack the plastic too much depending on what's in there. Petroleum also can attack rubber, as in belts, if it were to make contact inadvertently. Quote Link to comment Share on other sites More sharing options...
