Guest Posted May 4, 2015 Share Posted May 4, 2015 am building a workbook on an 8mbit maxflash cart for a mate however, i'm encountering a few games that are stubborn Bounty Bob Strikes Back Crusade In Europe Decision In The Desert Tigers In The Snow Bounty Bob - is a fairly obvious reason as it's a multip-part disk - program load then data the others i have no idea why they won't work does anyone have any versions of the above that they're confident will load into a maxflash cart? ps - i've tried at least 12 versions of BBSB and 3 each of the others thanks Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted May 4, 2015 Share Posted May 4, 2015 I had the same trouble with BBSB. I think I found a working one. Some games only work with certain systems- I have had trouble with Asteroids Emulator as well. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 4, 2015 Share Posted May 4, 2015 Paul i've PMd you Quote Link to comment Share on other sites More sharing options...
Guest Posted May 4, 2015 Share Posted May 4, 2015 well sometimes the solution is so much easier than expected - but only after hours and bl**dy hours of copy after copy after wretched copy of Bounty Bob Strikes (fekkin) Back. my solution? i searched the atarimax forums for an 8mbit maxflash cart file that included BBSB....loaded the compilation into the maxflash programmer, stripped it out as a standalone file then loaded the file into my own compilation....and guess what? it works wahay!!!! Quote Link to comment Share on other sites More sharing options...
