snicklin Posted May 4, 2015 Share Posted May 4, 2015 Two questions in one here: a) I would like to be able to have high speed disk access using xBios 4.1. I see that there are two definitions made with respect to speed: xSPEED equ xBIOS+$3e6 ; STD SPEEDxHSPEED equ xBIOS+$3e7 ; ULTRA SPEED 1) Can I use these to have high speed disk access to conventional floppy disks on a real Atari? 2) If the answer to (1) is "yes", how do I use these to get high speed disk access? b) How can I use files on disk drive 2/3/4/5 etc? Quote Link to comment Share on other sites More sharing options...
xxl Posted May 4, 2015 Share Posted May 4, 2015 when you load xBIOS, library check if your drive has ultraSpeed, if so it save proper value to xHSPEED. so. if drive has ultraspeed (knows "HIGH SPEED INDEX" SIO command) you can use: lda xHSPEED bmi no_hispeed sta xSPEED it works if you use SIO I/O module: "jsr xBIOS_SET_DEFAULT_DEVICE" using AtariOS I/O module do not think about speed control. B: yes, use: xDEVICE equ xBIOS+$3fc ; Device ID Quote Link to comment Share on other sites More sharing options...
snicklin Posted May 4, 2015 Author Share Posted May 4, 2015 Thank you so much for your quick reply. This will help me in what I am doing. Would it be ok if I wrote an xBIOS manual/document in English? I would like one document with lots of information in. I am not the most knowledgeable person on xBIOS, so I will need help from yourself and other people. I will use some of your examples in the document if that is OK? I am finding that there are posts to different places (your website, various Atariage posts, other sites) and it would be good if they were all in one place. --- Different question : Is there a way to know which drives have high speed? Is there one way of doing this for ALL high speed drives? Or are there different ways for different drives? 1 Quote Link to comment Share on other sites More sharing options...
xxl Posted May 8, 2015 Share Posted May 8, 2015 > Would it be ok if I wrote an xBIOS manual/document in English? wow! yes, of course, great :-) > Different question : Is there a way to know which drives have high speed? Is there one way of doing this for ALL high speed drives? Or are there different ways for different drives? why not. ask drive if could work with hi speed and what speed: xBIOS_SET_DEFAULT_DEVICE equ xBIOS+$2A xBUFSIZE equ xBIOS+$3f1 ; Buffer size lo byte $100-SIZE (1 byte) xDEVICE equ xBIOS+$3fc ; Device ID xIOV equ xBIOS+$3ee ; I/O module entry (2 bytes) xBSIO jmp (xIOV) start jsr xBIOS_SET_DEFAULT_DEVICE ; I want to use xB SIO I/O lda #$100-$01 ; set buffer size sta xBUFSIZE lda #'1' ; AtariOS device '1' = DOS device D1: sta xDEVICE ; you can use '2', '3' and so for D2: D3: ... ldx #$3F ; set command GET HI SPEED FROM DRIVE jsr xBSIO bcs DRIVE_HAS_NO_ULTRA_SPEED_NO_HAPPY_WARP_NO_US_DOUBLER_ETC lda $7ff ; get HiSpeedIndex byte from buffer (xBUFSIZE = lo byte,xBUFFERH = hi byte) remember to preserve old xBUFSIZE and xDEVICE value... if you want ofcourse. 1 Quote Link to comment Share on other sites More sharing options...
fujidude Posted May 8, 2015 Share Posted May 8, 2015 What is xBIOS? Quote Link to comment Share on other sites More sharing options...
xxl Posted May 8, 2015 Share Posted May 8, 2015 What is xBIOS? http://xxl.atari.pl/ 1 Quote Link to comment Share on other sites More sharing options...
fujidude Posted May 8, 2015 Share Posted May 8, 2015 I used Google translate. I think I get the gist of it. Quote Link to comment Share on other sites More sharing options...
snicklin Posted May 10, 2015 Author Share Posted May 10, 2015 The first version (0.1.0) of the xBIOS document has now been delivered for checking. When I get the feedback to the document, I will update the document (in Beta!) for others to review. I also put a plea out to other people to send me some code examples for some of the less obvious features. I will then incorporate these into the document and add you as a code author. I am no xBIOS expert and do not pretend to be. I use it a bit but I need the assistance of others in order to produce the document. It will be a constant "working document" and so it will not have a final version. Help may be required for anything using different cartridge formats or RAM disks. I have no examples there. 1 Quote Link to comment Share on other sites More sharing options...
rensoup Posted July 26, 2019 Share Posted July 26, 2019 On 5/4/2015 at 10:52 PM, xxl said: lda xHSPEED bmi no_hispeed sta xSPEED On 5/8/2015 at 1:21 PM, xxl said: lda $7ff ; get HiSpeedIndex byte from buffer (xBUFSIZE = lo byte,xBUFFERH = hi byte) remember to preserve old xBUFSIZE and xDEVICE value... if you want ofcourse. Is it possible to get a full example of this because this is a little confusing? What is $7ff ? is it the end of the IO Buffer ? ( .byte >$0700 ; xB buffer adress for relocator in the .cfg file ) Thanks Quote Link to comment Share on other sites More sharing options...
