Any Love For Early IBM PC/Compatibles?
84 replies to this topic
#76 Keatah OFFLINE
Keatah
    Missile Commander
  • 22,191 posts
Posted Sat May 30, 2015 2:07 PM
Should be simple. 99% of the DIP switches I've seen are wired like that. All you'll need are 2 wires for each switch.
#77 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,165 posts
Posted Sat May 30, 2015 2:22 PM
That's what I kind of figured.  The real question is can I wire it up without shorting something.  I assume if I take out the motherboard I'll see some points I can solder to on the back, I'd rather not have to desolder the dip switches themselves as that is a bit beyond my pay grade.
#78 Keatah OFFLINE
Keatah
    Missile Commander
  • 22,191 posts
Posted Sat May 30, 2015 2:43 PM
Most likely yes. Count the number of pins, 2 per switch. If it matches then you're good to go. You can always verify open and closed positions with a basic multimeter, which is what I do all the time.
#79 boxpressed ONLINE
boxpressed
  • 3,081 posts
Posted Sat May 30, 2015 2:59 PM
May not be worth the trouble if you can disable cache from the BIOS.
#80 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,165 posts
Posted Sat May 30, 2015 3:47 PM
You think that would make that big of a difference?  A Pentium 200MHz is pretty damn fast for 486 type games.  I was thinking that being able to bring it down to 100Mhz would make it more than compatible.
#81 boxpressed ONLINE
boxpressed
  • 3,081 posts
Posted Sat May 30, 2015 4:19 PM
I think that killing the cache would take performance below 100MHz levels. You can try a DOS program called Topbench that compares your system to ones in its database. For instance, my Dell GX1 has a unique "turbo" key combo (Ctrl-Alt-\) that really slows things down. I'm not sure if it is killing the cache or what, but it makes my 700MHz PIII perform like 386-33, according to Topbench.
#82 Keatah OFFLINE
Keatah
    Missile Commander
  • 22,191 posts
Posted Sat May 30, 2015 4:39 PM
Killing the cache causes slowdowns by memory thrashing and slow access.
#83 gozar OFFLINE
gozar
    Dragonstomper
  • 992 posts
Posted Thu Jun 25, 2015 4:55 PM
I started setting up my Gateway 2000 from '94, and can't find my Ensoniq sound card. :-( I did replace the hard drive with a Transcend IDE module, which quieted the machine immensely.
#84 Osgeld OFFLINE
Osgeld
  • 5,983 posts
Posted Thu Jun 25, 2015 6:02 PM
im 50/50 on old hard drives
yea they are loud, especially SCSI, but nothing says 90's than your machine sounding like a feaking transformer powering up for the first time
#85 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,167 posts
  • Technology Samurai
Posted Thu Jun 25, 2015 8:44 PM
Or causing an entire desk to wobble while it spins up and create vibrations you can feel through the entire house :)
