DSHD Disks in the TI DSSD Drives
bholcomb007
Ok, I just got everything going and got the Disk Manager 2 cart and I attempted to test the old TI Disk Drive in the PEB...and...the manager gave me an I/O Error 16. Wondering what was up, I noticed I had DSHD disks...I know you can format DSDD disks in the DSSD drive, but I am not sure about the DSHD disks? Is that possible and my drive is failing or is it the fact I am not using a DSDD or DSSD disks in the drive?
Would like to know if I just need to get some DSDD/DSSD disks to try out and see if it, in fact, is the drive and not a disk issue.
P.S. - the disks are brand new...just noticed now that I got the HD disks...my bad.
Thanks,
Ben
Edited by bholcomb007
IO 16 usually means no disk in drive or no drive.
are you sure you are inserting the disk correctly? if this is a standard 90k drive from TI the label of the disk would usually face right.
You can always try to flip the disk over and try it again.
I have never tried to format a HD 5.25 in a standard drive, but I would think it would work. I do format 1.44 mb as 720k. I just have to tape over the HD hole..
Have a look at
http://en.wikipedia.org/wiki/List_of_floppy_disk_formats#Physical_composition
The important column in that table is "Coercivity". It is the ability of the magnetic cells to withstand magnetization. The higher the coercivity, the stronger the external magnetic field must be.
Accordingly, a DD floppy drive likely fails to magnetize the cells of a HD floppy disk.
Cool...thanks for the info. I was thinking an SD drive would not work on HD disks...it was an oversight when I bought them.
I have a friend that is going to look for a SD or DD disk so I can try it out and see if it works.
Thanks for all the answers!
I love this forum!
Just got another TI after 30 years because it was the first computer I had and it got me into programming. I am trying to get this one set up so I can start programming on it again and do the things I could not back then. Very exciting times! Also the kids are loving it and that makes it even better to me.
Super thanks all,
Ben
