The Asgard Software Archive
ASGARD Software Archive Files Scans
88 replies to this topic
#51 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Mon Jul 20, 2015 1:12 PM
DiskManager1000 v3.1 with Sourcecode
Hi,
maybe (or not?) somehow interesting, so I post it directly:
DiskManager v3.1 with assembler-source
More in the next days :)
#52 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Mon Jul 20, 2015 1:55 PM
ADVENTURE: CARFAX ABBEY
Attached File  CARFAX-ABBEY-TexComp-BestOfUK2-03.JPG   68.88KB   6 downloads
#53 CantStopClicking OFFLINE
CantStopClicking
    Moonsweeper
  • 316 posts
Posted Tue Jul 21, 2015 11:13 AM
Wow, what a cool thing for Chris to provide!  What would it take to get Chris on AtariAge???  and join in on the fun!!!
I've converted hundred's of diskette's to DSK image.  I have one thing to say CLEAN CLEAN CLEAN your drive!  Between every disk swap as any garbage from the current disk will destroy the next one.
Also, I leave a my bare drive out so I can gently flex the disk on troublesome disks (as a extreme last resort).  I found that if I had questionable disk; I would be lucky to get one good read and then fail from then on.  I put those failed ones in a separate stack, and as the last resort use my "flex" method.  I also have about 10 physical disk drives that I cycle through and can general now guess which drive will work best with flaky disks (pun intended).
Anyhow, if you need any help with that process, let me know.  I've got the equipment to do it.
Don't use the TI to do disk images, too slow, to unreliable.  Use a PC with Paoblo's Bagnaresi's TI99PC utility.  Or something on a PC.  The drives are much more forgiving, much quicker, and storage is no problem.  Quicker is important, the longer that a bad disk spins in the drive the less likely it's going to come through.
My $0.02 worth!
THANKS FOR SHARING AND DOING THE COMMUNITY SUCH A HUGE FAVOR!
-Dano
#54 Lee Stewart OFFLINE
Lee Stewart
  • 3,967 posts
Posted Tue Jul 21, 2015 11:19 AM
He's here:  christophlee
...lee
#55 CantStopClicking OFFLINE
CantStopClicking
    Moonsweeper
  • 316 posts
Posted Tue Jul 21, 2015 12:00 PM
...lee
Dude!  Sweet!
In Ω's splashy fashion....
Edited by CantStopClicking, Tue Jul 21, 2015 12:01 PM.
#56 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,924 posts
Posted Tue Jul 21, 2015 12:06 PM
#57 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Tue Jul 21, 2015 12:19 PM
yeeeeeeeea yuuuuu booyzzzz likkkk meeeechiiicoooo ?
#58 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Wed Jul 22, 2015 2:44 AM
Hi all,
here is the next pile of disks :)
These here are ones which came almost without errors
I am going on, but it takes time, and drives :)
I am doing it like Dano tells, just put the erratas away, for later investigations.
And yes, I have to pull out the drives every 4-5 floppies, cleaning the heads manually with some fine Whiskey :)
(means the Disk-Cleaning-Sets do not help in every case, cotton swabs are much more reliable)
schmiddy
#59 ti99iuc OFFLINE
ti99iuc
  • 1,651 posts
Posted Wed Jul 22, 2015 3:02 AM
Nice job Ralf ! :) ...
i will check them in the weekend :)
keep in your mind that if you want some help with the Floppy with errors you can send me after you done your try... i will try again with my hardware too :)
#60 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Wed Jul 22, 2015 9:30 AM
Yes, I put some with errors beside, like Dano told, for later checks.
But if you want I can send you a pile as these are very much floppies.
Walking kneedeep in floppies :)
#61 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Sat Aug 8, 2015 6:36 AM
Hi,
as I am testing a new copy-software for the work, is there anybody outside who just can test these 2 DSK-files ?
They are labelled "PPAnimal-1" and "-2", but I don´t know how to open the files, or to use them.
Maybe you have an idea. TI99DIR works fine on the converted DSKs, but safe is safer :)
thanks a lot
PS: I am testing now with "RapidCopy 1.0" , maybe somebody has a newer version for me, if exists ?
(any other Copy-Tools are very welcome, too, if known as reliable.
 Please just post here or send to me as PM or to 99er@toxic-instruments.com )
#62 Ksarul OFFLINE
Ksarul
  • 5,275 posts
Posted Sat Aug 8, 2015 6:50 AM
These are Page Pro picture files. I can't test the HFE images, but I do know what they are, as I think I bought this set back in the day. . .I'll have to go check my Asgard master disk set to be sure.
#63 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Sat Aug 8, 2015 8:46 AM
Hi, sorry for the naming, these are DSKs, so maybe u can have a look?
#64 ti99iuc OFFLINE
ti99iuc
  • 1,651 posts
Posted Sat Aug 8, 2015 9:02 AM
I can confirm it... they are PagePro Picture Files Ralf :P
Edited by ti99iuc, Sat Aug 8, 2015 9:03 AM.
#65 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Sat Aug 8, 2015 9:15 AM
Yes, but I need a test that the DSKs work, means that this CopyTool works....
But the info that it is PapePro was top, so I´ve pulled an original PagePro99 I´ve bought 10 years ago,
and could start it and open the files  :) :)
Attached File  PPpro.JPG   95.05KB   4 downloadsAttached File  PPpro-loading.JPG   42.66KB   4 downloadsAttached File  PPpro-shy.JPG   55.24KB   4 downloadsAttached File  PPpro-shy-birdie-overlay.JPG   76.97KB   4 downloadsAttached File  PPpro-Duckies.JPG   62KB   4 downloads
#66 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Sat Aug 8, 2015 9:17 AM
Are there any advices (=uploads :) hint hint ) for a better copy-program, or maybe a newer version of Barry´s RapidCopy 1.0 ?
#67 ti99iuc OFFLINE
ti99iuc
  • 1,651 posts
Posted Sat Aug 8, 2015 9:51 AM
Rapidcopy i have the 1.0 version too...
about copy programs i like a lot this, you could try :)
Edited by ti99iuc, Sat Aug 8, 2015 9:51 AM.
#68 globeron OFFLINE
globeron
    Dragonstomper
  • 838 posts
Posted Sun Aug 9, 2015 3:18 AM
Not too sure if you are looking for this one, but
I remember this one  from the past  "Copy-C", but have not tried it recently:
http://home.arcor.de...til/index_e.htm
http://home.arcor.de.../copyc_pd_e.pdf
and German version: http://home.arcor.de.../util/index.htm
EDIT:
Attached File  copy-c.jpg   73.25KB   4 downloads   (this is on your CF-card image already (see other Atari-post)
Now I remember, the benefit is that it can copy non-standard disks, like UCSD-Pascal disks or  PR-BASE disks
and a few more  (but any other bit-per-bit or sector copier should be able to do that as well).
Other utilities are Disk Utilities 4.2 from John Birdwell
Edited by globeron, Sun Aug 9, 2015 3:26 AM.
#69 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Sat Mar 26, 2016 8:16 AM
One more found from what Chris Bobbitt has sent. As Omega asked for it I rescanned it, I hope the quality is OK.
I also have the original 600dpi-scans, if somebody likes.....
Attached File  TI-ARTIST-2.0-Insecbot-Chris-Faherty_Asgard-SWA-OCR-RMS01.pdf   4.61MB   40 downloads
have fun :)
#70 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Sun Mar 27, 2016 6:39 PM
Hi, here´s the same version, with the blank side #2, for a better printing.
OCR got lost, sorry, but I think just for printing should be OK
thx
xXx
Attached File  TI-ARTIST-2.0-Insecbot-Chris-Faherty_Asgard-SWA-OCR-RMS02-P2-NOOCR.pdf   4.64MB   25 downloads
#71 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,924 posts
Posted Sun Mar 27, 2016 9:11 PM
One more found from what Chris Bobbit has sent. As Omega asked for it I rescanned it, I hope the quality is OK.
attachicon.gifTI-ARTIST-2.0-Insecbot-Chris-Faherty_Asgard-SWA-OCR-RMS01.pdf
have fun :)
Schmitzi,
  I found that if I print out pages 2-25 in booklet form on standard paper, then print out the edited cover on colored cardstock it looks great when completed.
 I've taken the liberty of attaching the edited & enlarged front page (hope you don't mind).
#72 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Mon Mar 28, 2016 4:29 AM
uuh this looks really good :)
#73 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,924 posts
Posted Mon Mar 28, 2016 8:44 AM
Schmitzi, it's all because of YOUR hard work, which I have to tell you, I really, REALLY appreciate. :thumbsup:   With all the TI goodness floating around here at Atari Age, I suppose it's possible to take it all for granted, but every program being written, every piece of hardware being created or every manual like the one you just brought back to life takes quite an investment in time and energy.  We are truly fortunate to have someone like you in our little TI community.
Thanks Schmitzi!
#74 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Mon Mar 28, 2016 1:02 PM
thank you for the flowers, Omega   :) :)
#75 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Fri Apr 14, 2017 4:35 AM
Hi, here - maybe - is another special from the
ASGARD / WINFRIED WINKLER: XB3 - Extended Basic III
Attached File  XB3_Eproms-small.jpg   38.46KB   11 downloads
At Birkenau´s Meeting, Bernhard and I, we could read out the XB3 cartridge with the Wiesbaden Supermodule II v2.1
using this special Widget I brought along. OK, Bernhard did ;)
I think, Rudi gave this widget to me, some years ago.
Attached File  TI-ModulAdapter-Used-to-readout--RMS-04.jpg   139.42KB   13 downloads Attached File  TI-ModulAdapter-Used-to-readout--RMS-06.jpg   152.85KB   10 downloads
I am not sure if I understood that correct, but up to now it was a problem to read out the XB3 (and carts like this?) because of "the widgets" ?
By the way, so or so, with this widget we could switch that cartridges while reading out, without getting any errors.
Attached File  SuperModul2.0-Wiese-RMS-02-IMG_0193-AUSSCHNITT.JPG   67.96KB   12 downloads
(stock photo)    >>:0)
And Bernhard also did more some work on that in the past, reading out the Eproms and so. I don´t know. You will know :)
In advance, I have also unpacked his DSK-files with TI99DIR, but I am not sure if this was really needed :0)
So here are the results now, maybe some of you wizards can use that to get it running on the UberGROM, FinalGROM´99, Emus,
or whatever, or can use that in any way, if not given   :)
Have fun
xXx
FULL FILE: Attached File  XB3_Asgard-Winkler-Birkenau-2017.zip   6.77MB   50 downloads
And a manual: Attached File  Asgard-XB3-SuperModule--Supplemental-Manual-1993.pdf   7.32MB   48 downloads
#Tags:
Horst Wiese TI-Workshop Wiesbaden Supercart Extended Basic 3 Expanded Basic 3 XB3 Super Module Supermodule Sven Dyroff
Update: the XB3-files here are same version as the well-known ones, so the  "Call Coinc"  crashes too...
               Maybe this can be fixed ?
Edited by schmitzi, Fri Apr 14, 2017 9:40 AM.
Also tagged with one or more of these keywords: ASGARD, Software, Archive, Files, Scans
