budz2355 Posted May 31, 2015 Share Posted May 31, 2015 Is there a program a person would use to write an XB program on a modern PC? This way I could have all the conveniences of copy/paste, mouse use, quick save to hard drive, edit a single character easily, etc. etc. I am looking to write a fairly simple program in XB. Could I just write the program in Word and then somehow turn it into a TI file? Thanks in advance for any insight. Quote Link to comment Share on other sites More sharing options...
Gazoo Posted May 31, 2015 Share Posted May 31, 2015 (edited) Is there a program a person would use to write an XB program on a modern PC? This way I could have all the conveniences of copy/paste, mouse use, quick save to hard drive, edit a single character easily, etc. etc. I am looking to write a fairly simple program in XB. Could I just write the program in Word and then somehow turn it into a TI file? Thanks in advance for any insight. I use Wordpad for most things (use a fixed width font like Courier), and import the file to a TI disk image using TIimagetool. Gazoo Edited May 31, 2015 by Gazoo 3 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted May 31, 2015 Share Posted May 31, 2015 Reeeeal simple. Write it in Notepad++, or Word, or whatever you want. Select and Copy the entire program Open Classic99 Edit menu (Paste XB) Save to DSK1. I could not work without my Notepad++ and Classic99... Assuming you make adjustments while in Classic99, you can simply type "LIST CLIP" and it will copy your newly changed program to your clipboard. Then just paste back over your Word or Notepad document. Simple and Amazing 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted June 1, 2015 Share Posted June 1, 2015 Reeeeal simple. Write it in Notepad++, or Word, or whatever you want. Select and Copy the entire program Open Classic99 Edit menu (Paste XB) Save to DSK1. I could not work without my Notepad++ and Classic99... Assuming you make adjustments while in Classic99, you can simply type "LIST CLIP" and it will copy your newly changed program to your clipboard. Then just paste back over your Word or Notepad document. Simple and Amazing i use Classic99 to code a lot and test my code then I transfer it to the real TI via Magic FM or other methods. 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted June 1, 2015 Share Posted June 1, 2015 These days, there is little reason to program on the real machine unless it's a hardware project or you have masochistic tendencies. 1 Quote Link to comment Share on other sites More sharing options...
Gazoo Posted June 1, 2015 Share Posted June 1, 2015 These days, there is little reason to program on the real machine unless it's a hardware project or you have masochistic tendencies. Sometimes if I don't feel like going back to the PC to change something, I'll just use Funnelweb to make the change. I haven't been able to create source code large enough yet that it can't load in Funnelweb. Gazoo 3 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 1, 2015 Share Posted June 1, 2015 << THIS VIDEO >> by another user shows how the HDX These days, there is little reason to program on the real machine unless it's a hardware project or you have masochistic tendencies. Thanks to another Atari Age users video, << HERE >>, I started using both since the PC and the TI can share the same files via the HDX. You can program on either machine, save, run and test using either Classic99 or R.I. Heck, for debugging you can even dump a file listing to your PC's printer! I'm not the worlds best programmer, so a printout gives me time to ponder my mistakes. 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted June 1, 2015 Share Posted June 1, 2015 There's also TidBit (http://codehackcreate.com/archives/237) which allows an Extended BASIC without line numbers and with a few other formatting options. You paste into the web form and get out Extended BASIC ready for pasting into an emulator or other tool. 1 Quote Link to comment Share on other sites More sharing options...
Fredrik Öhrström Posted June 1, 2015 Share Posted June 1, 2015 Is there a program a person would use to write an XB program on a modern PC? This way I could have all the conveniences of copy/paste, mouse use, quick save to hard drive, edit a single character easily, etc. etc. I am looking to write a fairly simple program in XB. Could I just write the program in Word and then somehow turn it into a TI file? Thanks in advance for any insight. http://nivelleringslikaren.eu/ti994a_basic/ upload/download TIFILES 1 Quote Link to comment Share on other sites More sharing options...
