Itchy_Nipples Posted June 13, 2015 Share Posted June 13, 2015 Hi guys, I just started programming today with Visual bB and I'm getting the hang of it pretty well. (I've programmed before, just nothing like this) and I'm in the middle of making a game, one that I've made before in other IDEs and other platforms, and I'm having some trouble trying to figure out how to make my sprite jump, and how to change playfields. First of all, my game: The idea of the game is that you're controlling a player sprite (a simple square) and you must jump platform to platform in the playfield to get to the goal token (a circle) and once you do, you get a point, and the playfield changes to the next level. The challenge is to not fall, so I would have to implement some sort of action that the sprite is constantly falling and detects collision with the platforms (right?) but how would I have the sprite jump when the fire button is pressed on the joystick? I think I can get the idea down but I can't get it into Visual bB. I also have no idea how I can make the playfield change upon collecting the token (or changing the playfield at all for that matter). Any help given at all would be highly appreciated! I can provide my .bin or .bas if needed but there's no much there besides the basic sprite and having it move back and forth on the screen at the moment. Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted June 13, 2015 Share Posted June 13, 2015 I'd create a state machine with the states jumping falling and onplatform. You can use on gosub to easily implement one. Google Finate State Machine (FSM) if you're not familiar with them. Quote Link to comment Share on other sites More sharing options...
Itchy_Nipples Posted June 13, 2015 Author Share Posted June 13, 2015 I've searched for the topic of Finite States and I couldn't find anything concrete on how to implement one, I did find a page that explained on how I could set one up but I have seemingly lost it... Would you have any examples of how I could use one? It doesn't have to be exactly what I'm looking for, I've just never heard of these and implementing would be even harder if I don't know the syntax of one. Quote Link to comment Share on other sites More sharing options...
bogax Posted June 13, 2015 Share Posted June 13, 2015 I think ZackAttack makes it sound simpler than it's likely to look if you're jumping in to the subject cold (ie with no knowledge at all of state machines). For one thing, state will necessarily include stuff like what platform you're on and whether you've fallen off screen. But to interpret ZackAttack (and risk trying to put words in his mouth) You'd have a state variable who's value reflects the current state and you'll choose which piece of code to run depending on the state variable (maybe) using on-gosub. You don't really need to deal with Y movement at all if you are on platform and you might want to deal with moving up (jumping) and moving down (falling) differently So if you're in the on platform state you don't worry about what happens when you're falling or jumping at all. You will look for stuff that changes state. if fire is pressed change to jump state. if X movement moves you off platform change to falling state (and there will be concomittent stuff that goes with that like Y velocity) (personally I think falling and jumping are likely to be so similar that I'd just have it be moving in the Y direction or not but that would depend on what you want your code to do and how you prefer to deal with it) Quote Link to comment Share on other sites More sharing options...
Itchy_Nipples Posted June 13, 2015 Author Share Posted June 13, 2015 (edited) Would there be a more simple way of implementing jumping and falling off of a platform? Something like having the player sprite constantly falling and having collision detection with the playfield? When it collides with the playfield, have it stop falling. The only problem would be getting the jumping working with that way. Are here examples on the forum that show how to create a FSM? I have the logistics down I'd just need to move it from pseudo-code to Visual bB. Is there an example .bas or some other source code that has one so I can see what it looks like and I can get an idea of what I'd need to do? Edited June 13, 2015 by Itchy_Nipples Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted June 13, 2015 Share Posted June 13, 2015 Don't forget that using collision detection is going to have some issues to work out. Like jumping under a platform and hitting your head on it. You don't want the player getting their head stuck to platforms. Post you bas file and I'll see if I can help you out later. Btw, there's a sub-forum dedicated to batari basic. You'll get more/better responses if you post basic questions there. Quote Link to comment Share on other sites More sharing options...
bogax Posted June 13, 2015 Share Posted June 13, 2015 for one thing the sprite has to overlap the platform in order for there to be a collision for another you don't need to fall at all if you're on the platform so there'd be no point in falling (and presumably then undoing it if you don't want to fall) assuming the platform is a simple horizontal surface, you could test the limits when you move in the x direction something like if !joyright then left x = x + 1 if x = right_limit then fall goto after_x_move left if !joyleft then after_x_move x = x - 1 if x = left_limit then fall after_x_move Quote Link to comment Share on other sites More sharing options...
Itchy_Nipples Posted June 13, 2015 Author Share Posted June 13, 2015 (edited) Don't forget that using collision detection is going to have some issues to work out. Like jumping under a platform and hitting your head on it. You don't want the player getting their head stuck to platforms. Post you bas file and I'll see if I can help you out later. Btw, there's a sub-forum dedicated to batari basic. You'll get more/better responses if you post basic questions there. I've attached my most recent .bas file default.bas Edited June 14, 2015 by Itchy_Nipples Quote Link to comment Share on other sites More sharing options...
bogax Posted June 14, 2015 Share Posted June 14, 2015 Here is a dropbox link to my most current .bas file: https://www.dropbox.com/s/lg4llreg6ljknlh/default.bas?dl=0 jeezus wept 5MB of javascript to download a 1k file? why don't you just post it to the forum either by enclosing it in [_code_] [_/code_] (remove the underscores) tags or attaching it 1 Quote Link to comment Share on other sites More sharing options...
Itchy_Nipples Posted June 14, 2015 Author Share Posted June 14, 2015 jeezus wept 5MB of javascript to download a 1k file? why don't you just post it to the forum either by enclosing it in [_code_] [_/code_] (remove the underscores) tags or attaching it I attached the file to my original post Quote Link to comment Share on other sites More sharing options...
bogax Posted June 14, 2015 Share Posted June 14, 2015 are you trying to simulate gravity? or do you just want to go up and down between platforms? Quote Link to comment Share on other sites More sharing options...
Itchy_Nipples Posted June 14, 2015 Author Share Posted June 14, 2015 are you trying to simulate gravity? or do you just want to go up and down between platforms? Simulating gravity. Having that constant pull towards the playfield and being able to jump platform to platform to get to the goal token (which I didn't put into the level yet) Quote Link to comment Share on other sites More sharing options...
Papa Posted June 14, 2015 Share Posted June 14, 2015 Here's an easy way... rem Generated 6/12/2015 11:34:52 PM by Visual bB Version 1.0.0.548 rem ********************************** rem *<filename> * rem *<description> * rem *<author> * rem *<contact info> * rem *<license> * rem ********************************** set tv ntsctitle player0x=50 : player0y=50 goto main2main2 player0y=player0y+1 if collision(player0,playfield) then player0y=player0y-1 : b=0 COLUP0=28 COLUBK=02 playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX ................................ ................................ ................................ ...........................XXXXX ......................XXXXXX.... ................XXXXXX.......... .........XXXXXXX................ XXXXXXXXX....................... ................................ XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXend player0: %00000000 %00000000 %00000000 %00011000 %00011000 %00000000 %00000000 %00000000end drawscreen if joy0right then player0x=player0x+1 if joy0left then player0x=player0x-1 if joy0fire then a=a+1 : b=b+1 if b>12 then a=0 if b>48 then b=0 if a>=1 then player0y=player0y-2 if !joy0fire then a=0 goto main2 Gravity included!! Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted June 14, 2015 Share Posted June 14, 2015 Here's an easy way... ... Gravity included!! This wouldn't compile for me. Perhaps the formatting got messed up because you forgot to enclose it in code tags? Quote Link to comment Share on other sites More sharing options...
Papa Posted June 14, 2015 Share Posted June 14, 2015 (edited) Well, don't include the "Gravity Included!!" line or the "Here's an easy way..." part. It worked fine for me, as I just deleted it all and then pasted it. Here's the dl, though. default.bas Edited June 14, 2015 by Papa Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted June 14, 2015 Share Posted June 14, 2015 For the jumping stuff, this might be helpful: atariage.com/forums/topic/179473-fake-gravity-platformer-test/ I need to go back and clean up the code one of these days. youtube.com/watch?v=Hy5_K2oUprY https://www.youtube.com/watch?v=Hy5_K2oUprY You might also want to post batari Basic questions in the batari Basic forum from now on: atariage.com/forums/forum/65-batari-basic/ Quote Link to comment Share on other sites More sharing options...
ZackAttack Posted June 14, 2015 Share Posted June 14, 2015 Here's the solution that I came up with. It uses collision detection with PF too, which as I already mentioned introduces some issues. Papa's solution would probably run a little faster because it doesn't use any gosubs. The downside to his solution is that it's harder to read and maintain, and it doesn't properly handle when you jump off a ledge and continue to hold the fire button. A nice enhancement to either solution would be to add a lookup table so the player slows at the peak of the jump and then gains speed again as he starts falling. rem Generated 6/12/2015 11:34:52 PM by Visual bB Version 1.0.0.548 rem ********************************** rem *<filename> * rem *<description> * rem *<author> * rem *<contact info> * rem *<license> * rem ********************************** ;alias variables a so it's easier to read the code ;It's best to alias them all in one place so you can keep track of which variable have been used already dim jumpState = a dim jumpHeightRemaining = b ;define constants for each state, again this will help readability const jumping = 0 const falling = 1 const standing = 2 ;How many pixels to jump vertically before you start falling const JumpHeight = 20 const JumpVelocity = 1 const FallVelocity = 1 ;initialize state machine to standing. jumpState = standing player0x = 50 player0y = 28 main2 COLUP0=28 COLUBK=02 playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX ................................ ................................ ................................ ...........................XXXXX ......................XXXXXX.... ................XXXXXX.......... .........XXXXXXX................ XXXXXXXXX....................... ................................ XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end player0: %00011000 %00011000 end drawscreen ;TODO use var0-var43 to determine if player0 is adjacent to the playfield horizontally if joy0right then player0x = player0x + 1 if joy0left then player0x = player0x - 1 on jumpState gosub OnJump OnFall OnStand goto main2 OnJump ;Output condition logic player0y = player0y - JumpVelocity jumpHeightRemaining = jumpHeightRemaining - JumpVelocity ;Next state conditioning logic if !joy0fire || jumpHeightRemaining{7} then jumpState = falling return OnFall ;Next state conditioning logic ;TODO use var0-var43 to determine if player0 is adjacent to the playfield vertically if collision(player0,playfield) then jumpState = standing : return ;Output condition logic player0y = player0y + FallVelocity return OnStand ;Output condition logic ;Next state conditioning logic if joy0fire then gosub StartJump if !collision(player0,playfield) then jumpState = falling return StartJump jumpHeightRemaining = JumpHeight jumpState = jumping return Quote Link to comment Share on other sites More sharing options...
Papa Posted June 14, 2015 Share Posted June 14, 2015 adjusting b> to something like 78-99 will fix the auto-jump problem. if b>99 then b=0 Quote Link to comment Share on other sites More sharing options...
