STGraves Posted June 16, 2015 Share Posted June 16, 2015 In my code I created a sort of an animation/transition that has to be called in between the 2 current screens, but I can't get it to work properly with gosub it kind of works but the sprites are there and with goto not at all, what I want is: if the player touches the left edge of the path call the animation/transition, once the frame counter reaches 4 (ends the 4 frame animation) then it goes to the other screen which is the left path. Can anyone take a look at it please? etsrevstg.bas Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted June 16, 2015 Share Posted June 16, 2015 Is that the same code you posted here or is it different? atariage.com/forums/topic/239396-help-with-either-ball-or-missile0-movement/?p=3258097 Quote Link to comment Share on other sites More sharing options...
STGraves Posted June 16, 2015 Author Share Posted June 16, 2015 (edited) The same, except that this one does work. Edited June 16, 2015 by STGraves Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted June 16, 2015 Share Posted June 16, 2015 The same, except that this one does work. Then I'm glad I didn't waste time trying to fix the other version since you already fixed it. Quote Link to comment Share on other sites More sharing options...
STGraves Posted June 16, 2015 Author Share Posted June 16, 2015 Yeah well, I didn't fixed it, I just returned it to it's original state, but could you help me with the transition please? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted June 16, 2015 Share Posted June 16, 2015 Yeah well, I didn't fixed it, I just returned it to it's original state, but could you help me with the transition please? Looks like this version isn't even ready to compile. bblint found the following errors . . . warning(2086): The "return" command appears to be missing indentation. warning(): Found 40 commands that use end, and 39 "end" commands. Quote Link to comment Share on other sites More sharing options...
STGraves Posted June 16, 2015 Author Share Posted June 16, 2015 Ok tomorrow morning I'll check it out Quote Link to comment Share on other sites More sharing options...
STGraves Posted June 16, 2015 Author Share Posted June 16, 2015 Sorry I've been busy updating my computer, I found the return without indentation but not the missing end, can bblint say where is it? Quote Link to comment Share on other sites More sharing options...
