thetallguy24 Posted June 23, 2015 Share Posted June 23, 2015 I have this SMS controller where two pin holes for the plug have metal sticking out in the middle. It takes quite a bit of effort to plug it in to my Genesis, and I'm afraid the break the Genesis' pins. The controller works fine, but I'd like to know if there is a way to fix it. Can I push them back in a certain direction? Here is the attached pic: Quote Link to comment Share on other sites More sharing options...
7800fan Posted June 24, 2015 Share Posted June 24, 2015 I think it's worn out. It looks like the pins are for up and down and when those breaks off, it's gone. You can salvage the controller by getting a generic 9 pin extension cord, cutting off the male end, figuring which wire goes to which pins, and solder those on SMS controller. SMS controller is very simple, just 6 switches and a ground. No chip, no other parts, nothing else. Quote Link to comment Share on other sites More sharing options...
zylon Posted June 24, 2015 Share Posted June 24, 2015 just use a small precision screwdriver to re-shape them. It also helps to hold plug in a vise or good pliers while you do it. Another thing you could do is just plug it into an extension cable and leave it there. Quote Link to comment Share on other sites More sharing options...
