my diy multicart works with some eeproms but not another?
multicart eeprom homebrew diy
5 replies to this topic
#1 Javaman OFFLINE
Javaman
    Space Invader
  • 10 posts
Posted Wed Jul 1, 2015 7:49 AM
Hi everyone,
I wired up a little 2k/4k multicart that uses a 74LS04 for a CE hex inverter.
It works with the AMD 29F010A-90PC and with some minor wiring changes, the smaller Atmel 28C64-15PC
However, it will NOT work with the Atmel 29C010A-12PC and I've tried several.
Sometimes I get a glimpse of the game screen before it blanks out.
An older post http://atariage.com/...ri/#entry240804
describes a similar problem (though I have a 4 switcher) and he solved it by using a 7406 inverter.
Before I take a chance on that inverter does anyone know what might be causing this problem?
I'm trying to understand why it would effect the 120ns chip but not the 90 or 150?
I really would like to use these chips since I have a few lying around.
Many thanks.
#2 Javaman OFFLINE
Javaman
    Space Invader
  • 10 posts
Posted Tue Jul 14, 2015 7:11 PM
I fixed my problem. Sounds strange but by disconnecting the ground wire from the ground pin of the eeprom all glitches & flickering disappeared. It had nothing to do with the inverter or speed of the chips. All my Atmel and AMD eeproms work perfectly without a ground wire attached. I even tried this on my handmade 8k multicart based on the pixelspast schematic. That also works better now. Maybe someone has an explanation but I'm glad to have it working.
#3 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 300 posts
Posted Fri Jul 17, 2015 7:51 AM
Javaman,
Are you using a decoupling (0.1uF) capacitor across the +5V/GND of the EEPROMs? I had similar issues when developing a multicart for the atari 8-bit.
On a breadboard, I also found that I sometimes also needed an additional 10uF capacitor too.
Robin
#4 Javaman OFFLINE
Javaman
    Space Invader
  • 10 posts
Posted Fri Jul 17, 2015 8:45 PM
Javaman,
Robin
Yes, I had the 0.1uf cap connected to the 5v & GND pins. Honestly, I tried it both with and without the cap & never noticed a difference.
It was only after removing the wire from eeprom GND pin to the GND on the cart that my problem was fixed.
I still have the decoupling cap but it's connected to 5V on the eeprom with the other leg directly to ground on the cart. Nothing connected to GND on the eeprom.
#5 Shawn OFFLINE
Shawn
    As Above
  • 18,764 posts
  • So Below
Posted Sun Jul 19, 2015 12:56 AM
pictures?
#6 Javaman OFFLINE
Javaman
    Space Invader
  • 10 posts
Posted Mon Jul 20, 2015 10:33 PM
pictures?
First one is the bank switching cart based on the PixelsPast schematic. EEPROM on top, GAL20V8B underneath.
Got a bit messy tearing it down looking for the original problem. A jungle of wires but amazingly it all fits inside the case.
I added extra DIP switches so I could turn on/off the address lines depending on whether there's a F8/F6/F4 GAL in the socket
or just running a chip with 2k/4k games. Game selection just uses one DIP. They hold 128k so its (32) 4k games or (16) 8k games, etc.
The second board is the first I made. It's a 2k/4k with inverter for chip enable plus an LED just for fun.
Also tagged with one or more of these keywords: multicart, eeprom, homebrew, diy
