New (alt) BIOS for Ultimate 1MB/Incognito
Ultimate 1MB Incognito APT PBI
1443 replies to this topic
#1326 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 630 posts
Posted Wed Aug 30, 2017 1:58 AM
prior to their addition, RD4/RD5 resistors were required on the MMU cable itself to protect the CPLD from 5V
Do I understand right that the cable connectors from the new Ultimate boards to the MMU socket are different from the old ones?
I thought that they are just 1:1 cables...
#1327 mytek OFFLINE
mytek
  • 3,060 posts
Posted Wed Aug 30, 2017 9:42 AM
Yes the cables are the same as to what signal goes where, but the Candle vs Lotharek U1MB boards are different concerning the RD4 and RD5 connections. With the Candle 'black' board requiring the insertion of 180 ohm resistors inline between the A8 motherboard and the U1MB, whereas the Lotharek board has these resistors built-in.
For those that don't know, the RD4 and RD5 signals tell the system whether an inserted cartridge is either 8k or 16k by simply routing 5vdc to the MMU. And as Jon already stated, without the resistors inline this voltage can damage the CPLD inputs on the U1MB.
- Michael
#1328 Faicuai OFFLINE
Faicuai
    Dragonstomper
  • 905 posts
Posted Wed Aug 30, 2017 10:33 AM
Well I have no idea - I'm pretty sure that I ordered it via lotharek but in any case it looks exactly like this:
(verified by popping the lid and taking a look inside.
I need a spare board EXACTLY like this one (initial Candle version that required in-line resistors on connecting ribbon-cable).
If anyone reading has an extra one (in perfect working order), please, let me know.
Cheers!
#1329 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 630 posts
Posted Wed Aug 30, 2017 10:57 AM
Thank you for the explanation. Now I got it. Jon wrote about MMU cable, so I was a little bit confused.
I remember that the cart could damage Candle's Ultimate boards, so Candle has eventually described in the installation manual additional change with 2 resisitors on the mainboard.
#1330 flashjazzcat OFFLINE
flashjazzcat
  • 13,908 posts
Posted Wed Aug 30, 2017 11:21 AM
I used to put the resistors in the cable itself. Xilinx CPLD was supposed to be 5V tolerant, but it was discovered the hard way that it wasn't after all.
#1331 gozar OFFLINE
gozar
    Dragonstomper
  • 909 posts
Posted Tue Jan 2, 2018 4:24 PM
I went to upgrade my Incognito 800 today, and am running into "Cannot identify hardware". I've tried booting off a disk image and using the Side loader to run uflash, but end up with the same issues each time.
The PBI Bios is showing as 1.61 and the Incognito BIOS is showing as 1.00. Any ideas on where to start troubleshooting? The machine appears to be working fine, except for the fact that I can't run almost anything from the NYD2018 set of discs. That's the reason I started down the path to upgrade.
I'm using Incognito_Firmware_Update_071216 from Jon's site.
#1332 flashjazzcat OFFLINE
flashjazzcat
  • 13,908 posts
Posted Tue Jan 2, 2018 5:08 PM
Probably the BIOS is sufficiently old that UFLASH doesn't recognize it. I'll see about fixing that up in the next few days, since there's a major update due anyway.
#1333 rdea6 OFFLINE
rdea6
  • 2,744 posts
Posted Sat Feb 3, 2018 11:40 PM
Bump--to remind you that a few days is over.
#1334 flashjazzcat OFFLINE
flashjazzcat
  • 13,908 posts
Posted Sun Feb 4, 2018 8:06 AM
So it is, but unfortunately getting the firmware ready and tested for three completely different platforms is taking longer than hoped. :) Regarding UFLASH: I have just about given up fully supporting these ancient BIOS revisions, but I'll PM Gozar to try and work through his issues. ;)
#1335 fujidude OFFLINE
fujidude
  • 5,091 posts
Posted Sun Feb 4, 2018 2:14 PM
Please don't be demanding of developers, lest their labor of love starts to feel more like a job; a job for which they do not demand money for. :)
#1336 _The Doctor__ ONLINE
_The Doctor__
  • 5,558 posts
Posted Mon Feb 5, 2018 12:53 AM
I think the posted bump was to be cheerful in nature and to follow up on the remind me's that are often posted or the I forgot's because of so many irons in the fire. I'm taking it in that fashion. I little jovial quip would have set the tone and mood and it would be okay... I'm guilty of coming off wrongly plenty of times myself...
#1337 flashjazzcat OFFLINE
flashjazzcat
  • 13,908 posts
Posted Mon Feb 5, 2018 3:47 AM
Implicit joviality is very difficult to convey in economically written forum posts without the use of emoticons, so we must rely on context and what we know of the character of the author. I guessed Roy's post was friendly and responded accordingly, even using two emoticons, so it should be clear that there is no problem at all.
EDIT: Regarding Gozar's issue: he was already running the alt firmware so my guesses about ROM signature detection problems were way off the mark. Eventually we figured out that SDX was disabled in the settings, making ROM identification and flashing impossible (since the banking register is taken off the bus). I'll add a note to the manual that SDX must be enabled in the BIOS for flashing purposes, since this is by no means obvious to the user.
Edited by flashjazzcat, Mon Feb 5, 2018 4:18 AM.
#1338 _The Doctor__ ONLINE
_The Doctor__
  • 5,558 posts
Posted Mon Feb 5, 2018 4:56 AM
We are all emoji!
#1339 fujidude OFFLINE
fujidude
  • 5,091 posts
Posted Tue Feb 6, 2018 2:24 PM
In that case it's all good.
#1340 tep392 OFFLINE
tep392
  • 3,093 posts
Posted Sat Feb 10, 2018 7:41 PM
I wasn't sure where to post this question, but thought someone reading this would be able to help. I just installed a new U1MB in my 800XL and seems to work fine, other than I can't seem to see more than 4 banks available in SDX.  The expanded RAM works because applications can use it, but I can't seem to get SDX to see it.  The MEM command shows 4 banks available.  I've tried every memory config from the configuration menu.
#1341 gozar OFFLINE
gozar
    Dragonstomper
  • 909 posts
Posted Sat Feb 10, 2018 7:55 PM
Have you modified your config.sys? If I remember correctly, SDX by default will only set up for 128K of RAM.
#1342 tep392 OFFLINE
tep392
  • 3,093 posts
Posted Sat Feb 10, 2018 8:07 PM
Nope.  Can someone post a sample of what needs to change?  Am I supposed to put the modified config.sys on D1:?  I didn't think I could modify the CAR: file.
#1343 DrVenkman OFFLINE
DrVenkman
  • 3,552 posts
  • Back off, man! I'm a scientist.
Posted Sat Feb 10, 2018 8:15 PM
You can modify the SDX rom file using the Windows-only SDX Imager tool. Once you've modified the file, you can use Jon's UFLASH tool to re-flash the modified rom to the U1MB. The better solution is to use the option in his current BIOS versions to set CONFIG.SYS to whatever drive you want. I usually point mine to D5:. On my systems with a SIDE2 cart, that's the first partition on my CF card. Same thing with my current 1088XEL and XEL-CF adapter. The copy of CONFIG.SYS on D5: can be edited and saved as necessary.
#1344 tep392 OFFLINE
tep392
  • 3,093 posts
Posted Sat Feb 10, 2018 9:34 PM
Thanks for the advice.  I flashed the new BIOS but I think you are talking about changing the boot drive in the PBI menu.  I don't have a PBI device.  In fact, I don't have a way to load a file larger than 90K so I can't re-flash SDX with a modified config.sys.  I'm an SDX novice though so I need help on how to boot with a config.sys on D1:, if that's even possible.
#1345 DrVenkman OFFLINE
DrVenkman
  • 3,552 posts
Posted Sat Feb 10, 2018 9:43 PM
In Jon's current BIOS options for the U1MB, there's a PBI BIOS. You don't need to have a PBI device to use these options. On that screen, if you enable the PBI BIOS, you'll be able to specify the drive you want CONFIG.SYS to reside upon. See p. 11 of Jon's documentation here:
http://atari8.co.uk/...-XEX-Loader.pdf
#1346 tep392 OFFLINE
tep392
  • 3,093 posts
Posted Sat Feb 10, 2018 10:16 PM
I set config.sys to D1: but it didn't use the file I have on D1:.  I'm going to have to dig into the SDX manual to see if there's something else I can do after it's booted.
#1347 tep392 OFFLINE
tep392
  • 3,093 posts
Posted Sun Feb 11, 2018 9:11 AM
I took another look at it this morning and figured it out.  Working well now. Thanks!
#1348 DrVenkman OFFLINE
DrVenkman
  • 3,552 posts
Posted Sun Feb 11, 2018 9:15 AM
Great! Can you explain what you were doing wrong and what you did to correct it? Might help others in the future. :)
#1349 tep392 OFFLINE
tep392
  • 3,093 posts
Posted Sun Feb 11, 2018 9:51 AM
:dunce: It's actually quite dumb.  I didn't realize the ramdrive is D0: by default.  In the past I've configured it as D8: using SDX on an atarimax cart.  So I really had the drive configured the whole time.
I figured out a way to flash SDX448 using my sdrive2 that's limited to 90k atr's.  I split the 256k rom into 4 parts and put it on 4 atr's.  I then copied the files to the ramdrive and put them back together.  I was able to flash the u1mb from the file on the ramdrive. :)  Hopefully the sdrive2 firmware get's updated someday to properly support large atr's.
#1350 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 630 posts
Posted Wed Feb 21, 2018 9:45 AM
Hi Jon,
what resistor values do you use?
My Atari with the UItimate 1MB and with VBXE (both from Candle) is dead since a few months and I recently decided to take a new motherboard and upgrade it with the extensions taken away from the dead Atari.
Luckily everything seems to work well, besides the issue, that I already experienced with the old machine (when it was still working).
The following carts do not work properly: The!Cart and MyIDE II (all others do). Back in time Jürgen (tfhh) was looking at the cart signals of my Atari with an oscilloscope and pointed out that some of them were not stable, meaning that my Ultimate 1MB was not be working perfectly...
Maybe it is related to those resistors? I simply took them over (didn't even measured them). If I remember well, they were originally provided by Candle.
Regards
Marcin
Also tagged with one or more of these keywords: Ultimate 1MB, Incognito, APT, PBI
