CoolCV emulator for Mac OS X, Linux, Windows and Raspberry
Colecovision Emulator Mac Windows
497 replies to this topic
#401 nanochess ONLINE
nanochess
  • 5,067 posts
  • Coding something good
Posted Tue Feb 7, 2017 9:51 PM
Can someone help me figure out what I'm doing wrong? I'm trying to configure my USB joystick to work with CoolCV, but am not having much luck with the directional pad.
These are CoolCV's default settings:
up_1    key1073741906
right_1    key1073741903
down_1    key1073741905
left_1    key1073741904
When I do F7 so I can see the codes for my joystick I get this:
up - Axis4 Key-32768
right - Axis3 Key32767
down - Axis4 Key32767
left - Axis3 Key-32768
Not sure how to plug those in.
Oddly enough, I have left and right movement on my joystick with the default settings, but not up and down.
I hope to make CoolCV use configurable joystick axis in next version, currently these are fixed at 0 and 1.
#402 jblenkle OFFLINE
jblenkle
  • 4,300 posts
Posted Tue Feb 7, 2017 11:18 PM
Ah, would that explain why I can get some joystick movement, but not in all directions? I mentioned it here once before, but don't remember exactly...like pressing right would go right and down, but pressing left would do nothing.
#403 the_xman OFFLINE
the_xman
    Combat Commando
  • 3 posts
Posted Fri Feb 10, 2017 3:27 PM
@EVEGames Thanks for the consolidated write-up on the update of coolcv_pi for my retropie.  I haven't tested it yet but will when I get a chance.
Has anyone applied an overlay or shader to the coolcv_pi emulator, or is it possible in the emulator.cfg?
#404 MediaMogul OFFLINE
MediaMogul
    Combat Commando
  • 3 posts
Posted Thu Feb 16, 2017 4:35 PM
@the_xman
Shaders and overlays are a feature of the libretro cores. Being a standalone emulator, CoolCV would have to implement something similar separately.
@nanochess
I really have to compliment you on CoolCV. I've been enjoying it immensely on my Raspberry Pi 3 since it was included in RetroPie last year. Unfortunately, as mentioned earlier, it is currently all but unplayable there now due to a mysterious slow down issue. As also mentioned, the project leader at RetroPie has been made aware of the problem, but depending on the cause, it might be that very little can be done on RetroPie's end to solve the issue. I've personally tried many things to alleviate the problem, such as setting the framebuffer to lower color depths, as well as testing multiple resolutions and overclock settings. All the while CoolCV, never takes up more than 30% of the CPU while performing so slowly.
I noticed above that you're already considering certain features for your next version. My hope here is that you consider including RetroPie specifically as a testing bed for the Raspberry Pi version in the future if you are not already doing so, as it will be where countless people will come into contact with the software. In whatever way this project progresses, I'd just like to thank you for the many hours I was able to enjoy the software in the past year. 'Princess Quest' was a particular treat to play and I look forward to seeing anything else you produce going forward. Thanks again for all your hard work and for your time here.
Edited by MediaMogul, Thu Feb 16, 2017 4:41 PM.
#405 KevinMos3 OFFLINE
KevinMos3
  • 1,506 posts
  • Founder of the Timothy Dalton as Bond fan club
Posted Sun Feb 19, 2017 12:10 PM
I really appreciate your work on this emulator.  I may be wishing for the moon here, but since you've already done a raspberry pi version, I'm wondering how difficult it would be to tailor it to the ARM of the 3DS.  The 3DS already has a lot of great systems emulated on it via libretro (and a handful of standalones), but one that is sorely missing is a Coleco emulator.  It's got a port of fMSX, which I would think could be made to work with Coleco games, but CoolCV just blows everything else away.
Regardless, thanks so much for all you've done so far.
#406 nanochess ONLINE
nanochess
  • 5,067 posts
Posted Sun Feb 19, 2017 12:44 PM
Thanks, currently I've no idea whether 3DS development is easy or complicated, or development toolkits available.
#407 youki OFFLINE
youki
  • 2,288 posts
Posted Sun Feb 19, 2017 5:45 PM
There is a  good coleco Emulator for Nintendo DS.   I never tested it on 3DS , but could work in theory , i think.
#408 MediaMogul OFFLINE
MediaMogul
    Combat Commando
  • 3 posts
Posted Thu Mar 2, 2017 10:32 AM
@nanochess
I have an update to the slow down issue in RetroPie. The project leader has discovered that the problem was introduced with the sdl2.0.5 update. His findings in his own words can be found below.
https://retropie.org...und-stutters/26
#409 MediaMogul OFFLINE
MediaMogul
    Combat Commando
  • 3 posts
Posted Fri Mar 3, 2017 12:00 PM
@nanochess
The issue has been fixed and has been reported accordingly to sdl. Colecovision is now blipping and bleeping again on RetroPie. More information below:
https://retropie.org...und-stutters/33
#410 gameblabla OFFLINE
gameblabla
    Space Invader
  • 12 posts
Posted Fri Mar 3, 2017 5:05 PM
Has anyone managed to run CoolCV on Ubuntu ?
Because I am unable to run the linux versions, both 32-bits and 64-bits version on Ubuntu 16.04.
Both versions fade from white to black and then absolute nothingness : it freezes.
Using GDB does not tell me much, apparently it's stuck at nanosleep. (does it sleep for way too much ?)
I was able to run the Windows version via Wine but it's pretty slow on my AMD FX.
For comparison, i compiled MAME for my processor and it's able to run Colecovision games fullspeed unlike CoolCV.
(Too bad MAME does not support Megacart games...)
I sadly can't do that, nor that i can fix my Linux issues myself, because CoolCV is closed source, which is extremely disappointing.
What's causing the freezing ?
Edited by gameblabla, Fri Mar 3, 2017 5:09 PM.
#411 nanochess ONLINE
nanochess
  • 5,067 posts
Posted Fri Mar 3, 2017 6:40 PM
I'm compiling and testing in Fedora.
I'll need to give a look.
#412 gameblabla OFFLINE
gameblabla
    Space Invader
  • 12 posts
Posted Sun Mar 5, 2017 11:57 PM
So i switched Ubuntu from ALSA to OSSv4 and now CoolCV (the linux version) works properly on my PC
Wine is not compatible with OSS but i did try CoolCV.exe again with Wine and i noticed it does the same thing than what it did on Linux :
Fades from white to black and then nothing.
Wine was spamming my terminal with the fact i had no sound devices.
I think you should handle errors better (even for the Raspberry Pi) than just having a black screen : some error reporting would be nice.
Anyway, it works now and it runs fullspeed, pretty cool emulator !
Edited by gameblabla, Mon Mar 6, 2017 12:20 AM.
#413 theborga OFFLINE
theborga
    Combat Commando
  • 9 posts
Posted Wed Mar 15, 2017 5:40 AM
Hi all! Just want to say that now my qamba q1 harware (in my retropie homemade cabinet) works flawless with coolcv.
It was a joystick setting the problem. Just have to switch between the compatibility mode (PC/PS3/Xbox) whith the appropriate button and... bingo! Now I can play this wonderful emulator without any problem!
btw: GREAT work with coolcv.... superb emu!
Edited by theborga, Wed Mar 15, 2017 5:46 AM.
#414 Ducky01 OFFLINE
Ducky01
    Combat Commando
  • 3 posts
Posted Thu Mar 16, 2017 12:45 PM
Did anyone ever figure out how to get an XBOX360 controller, specifically the joystick and/or d-pad to work with Coolcv on retropie? I'm starting to bang my head against the controller...
#415 theborga OFFLINE
theborga
    Combat Commando
  • 9 posts
Posted Thu Mar 16, 2017 2:16 PM
To play with my xbox360 controller I have to plug it and to choose the right buttons (by pressing F7 in Coolcv) and then put it on the "coolcv_mapping.txt" in home/pi.
the joystick work itself by doing nothing... I mean, plug and move on the games!
maybe some compatibilty problem? like the one that has make my qamba q1 NOT working on joy until i have realized that i have to push the "MODE" to choose PC instead PS?
Edited by theborga, Thu Mar 16, 2017 2:19 PM.
#416 Keatah OFFLINE
Keatah
  • 19,184 posts
Posted Wed Mar 29, 2017 2:18 PM
How does one select full-screen mode in coolcv? This for windows version.
Edited by Keatah, Wed Mar 29, 2017 2:20 PM.
#417 nanochess ONLINE
nanochess
  • 5,067 posts
Posted Wed Mar 29, 2017 4:04 PM
I'm afraid there is no full screen yet for Windows. SDL works just fine in Linux and Mac but in Windows only makes the window full-screen, I'll be researching this soon.
#418 ColecoJoe OFFLINE
ColecoJoe
    Star Raider
  • 71 posts
Posted Wed Mar 29, 2017 11:59 PM
Is there a way to start in fullscreen mode on the mac?
#419 Keatah OFFLINE
Keatah
  • 19,184 posts
Posted Thu Mar 30, 2017 1:29 AM
Very good..
#420 nanochess ONLINE
nanochess
  • 5,067 posts
Posted Thu Mar 30, 2017 6:47 AM
Not yet. Good suggestion :)
#421 intvdave OFFLINE
intvdave
    Dragonstomper
  • 701 posts
Posted Thu Mar 30, 2017 6:58 AM
Is there a possibility for command line switches? :)
#422 nanochess ONLINE
nanochess
  • 5,067 posts
Posted Thu Mar 30, 2017 10:41 AM
Not easily portable between platforms but I'll check.
#423 Pbrook67 OFFLINE
Pbrook67
    Space Invader
  • 28 posts
Posted Sun Apr 9, 2017 10:26 PM
I have a stupid question. I have a usb cable that allows me to use joysticks from different systems. I cannot seem to get my super action controller to work. any helpful hints???
#424 intvdave OFFLINE
intvdave
    Dragonstomper
  • 701 posts
Posted Sun Apr 9, 2017 10:37 PM
What USB cable do you have? Is it the Ultimate Interface?
#425 Mad-Mega OFFLINE
Mad-Mega
    Combat Commando
  • 1 posts
Posted Thu Apr 13, 2017 12:45 PM
Hi, i am new here, and probably my question is a dumb one, but i will ask it.
A lot of people are using Hakchi2 for their NES Mini, they also are using RetroArch to load their emulators.
Is there someone willing to convert or reprogram CoolCV to be used with RetroArch, convert it to a libretro core.
Currently the only chance to play ColecoVision games is to convert them to a GBA (GameBoy Advance) and run that in a GBA emulator on a NES Mini.
Edited by Mad-Mega, Thu Apr 13, 2017 1:42 PM.
Also tagged with one or more of these keywords: Colecovision, Emulator, Mac, Windows
2 user(s) are browsing this forum
0 members, 2 guests, 0 anonymous users
