ivop Posted August 1, 2015 Author Share Posted August 1, 2015 (edited) This is just great. Small request: Please add auto-disabling BASIC to the XEX. They fail to load with BASIC enabled and that's pitty for such cool code. > inc IRQEN Why that?Does it effectively clear the IRQ (dummy read to $FF writing $00?) bit so no new IRQ is trigger after RTI? INC is a Read-Modify-Write instruction. It first reads a zero at bit 0, it writes a zero when it is modifying the value internally (increase by one) and then it finally writes a one to bit 0. Edited August 1, 2015 by ivop Quote Link to comment Share on other sites More sharing options...
+JAC! Posted August 2, 2015 Share Posted August 2, 2015 Isn't the INC standard? Nevery actually used in IRQ in 30 years for something reasonabe in my code. "NMI should be enought for everyone" - Billy Gates 1985 or so, I think :-) Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 5, 2016 Share Posted April 5, 2016 A little bit of shoe-horning has got Martin Galway's Hyper-Sports music and sounds into the player. This I've put into an AtariMax 128KB image so best run under emulation using PAL at this point. The C64 SID player routines use a fair chunk of zero-page and so that had to be catered for. Overall doesn't sound too bad. There is an issue when cycling through the tunes, via console key, as one effect (a repeating click resulting in a sound like a train) doesn't get cleared for the following 3 samples. hs_sid.rom 2 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 5, 2016 Share Posted April 5, 2016 Executable version attached... plus I liked the tape loader music used on the game too so have included those. HyperSportsSid.xex OceanLoader1Sid.xex OceanLoader2Sid.xex 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 6, 2016 Share Posted April 6, 2016 mixing both methods in a tracker is a cool idea emkay... that would make a lot of sense... the either or all or nothing thing really does hold things back... wouldn't it be cool to have the best of both worlds? I think you are right! A fusion of the two would really shine! Quote Link to comment Share on other sites More sharing options...
