bugbiter Posted July 29, 2015 Share Posted July 29, 2015 (edited) I'm constantly getting strange read errors at irregular intervals in APE when using it with a real 130XE on SpartaDOSx (Lotharek's SIDE2 cartridge) " ** PC-MIRROR Unrecognized read (Try MyDos or Atari DOS) ** " I never encountered something like that before. This is the first time I'm coding for use with SpartaDOSx though. My code is using CIO as usual. Is there something I have do do differently with SpartaDOSx? Here's the disk reading routine of my code. I'm loading in a Windows BMP file one line at a time. What's wrong with that? Thanks for your help! . . . ;---------------------------------------load_raw ; load one raw line with 3*bmp_xsize bytes lda #<rawline sta dest lda #>rawline sta dest+1 lda bmp_xsize sta value1 lda bmp_xsize+1 sta value1+1 lda #3 sta value2 lda #0 sta value2+1 jsr mult16 lda result sta lenlo lda result+1 sta lenhi jsr bget ; load raw line rts;-------------------------------------;#################################; GENERIC BGET ROUTINE;#################################;; Bget Routine - load data block;;Parameters:;DEST;LENLO/LENHI;BGET ; bget routine LDX #diskread_chan ;Channel 1; LDA #7 ; Command: get characters STA ICCMD,X; LDA DEST ; Destination STA ICBAL,X ; where to load LDA DEST+1 ; stuff STA ICBAH,X; LDA LENLO ; LENGTH STA ICBLL,X ; of data block LDA LENHI ; to read STA ICBLH,X; JSR CIOV; RTS Edited July 29, 2015 by bugbiter Quote Link to comment Share on other sites More sharing options...
bugbiter Posted July 29, 2015 Author Share Posted July 29, 2015 just discovered that it doesn't run good on DOS 2.5 either. No APE errors, but strange output. Maybe there's more wrong at other places of my code... Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 29, 2015 Share Posted July 29, 2015 SDX does sector caching and thus issues reads in unexpected orders. Never had any luck using it with mirrored APE folders. 1 Quote Link to comment Share on other sites More sharing options...
bugbiter Posted July 30, 2015 Author Share Posted July 30, 2015 Hmm.. So it is not my fault. I have never seen that error with sdx before. This is the first time I am using one mirror for read and one for write. Maybe that triggers it. Will use Aspeqt and see if it has the same problem with sdx. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 30, 2015 Share Posted July 30, 2015 Later versions of AspeQt work fine, but mirrors are read-only. Quote Link to comment Share on other sites More sharing options...
bugbiter Posted January 30, 2016 Author Share Posted January 30, 2016 (edited) Hi Guys, for my BGP Picture converter assembler version I would like to be able to use a real Atari with a mirrored folder in APE. (using Atari DOS, as SDX has serious issues in combination with APE, see above) The converter runs fine in emulation, also on a real atari with a 1050 drive but I have problems with real Iron and APE. During the conversion, my code first writes the Brightness values in one tmp file and Hue values into another. Both files are being filled up simultaneously. After that the two temporary files are being unified into the final BGP picture file. Sadly however, APE seems to fail writing to two files open at one time. One is ok and the other is empty. For this reason I changed my code so that the Brightnes and Hue values get written to only one single tmp file. Strangely, now even the write to one file doesn't work right. (although in the first version one of two files was written correctly) The bad thing is that I cannot reproduce the failure in emulation, so I don't know what's going on. My latest theory is that APE always has a problem with the write channel that has been opened last, so I would introduce a dummy open write file which has the only purpose of attracting the evil bug spirits to itself.. :-) Edit: dummy write file open doesn't prevent the malfunction, I'll try around with different IOCB channel orders ... Any help on the topic of APE write instances with ATARI DOS 2.5 is much appreciated... Edited January 30, 2016 by bugbiter Quote Link to comment Share on other sites More sharing options...
