The official 4 switch woody serial number thread.
4 switch woody serial number atari 2600
37 replies to this topic
#1 Nutsy Doodleheimer OFFLINE
Nutsy Doodleheimer
    Total Retard
  • 5,615 posts
Posted Mon Aug 3, 2015 7:29 PM
Hello guys!! I thought I'd make the official Atari 2600 4 switch woody serial number thread. There is a serial number thread for the Heavy Sixer, Light Sixer, Vader, and Junior models. After extensive searching, there is none for the CX-2600A 4 switch woodies manufactuted from 1980-1982. Share your 4 switch woody consoles and their serial numbers. I'll lead off with mine. And the one out of my 5 different 2600's that get the most play time. My official game room system.
The 4 switch woody 2600 and Sears Tele-Games serial number list as of 8/30/15
#81019322 Sramirez2008 Atari 2600 NTSC Taiwan
#81134671 spawnshop Atari 2600 NTSC Taiwan
#81205352 hookem Atari 2600 NTSC Taiwan
#81914252 Sramirez2008 Atari 2600 NTSC Taiwan
#82281004 zylon Sears Tele-Games NTSC Taiwan
#82506814 BurritoBeans Atari 2600 NTSC Taiwan
#549274883 High Voltage Atari 2600 PAL Hong Kong
#827821160 SonicSageGamer Atari 2600 NTSC Taiwan
#828289936 Retrogamer81081 Atari 2600 NTSC Taiwan
#828368579 opry99er Atari 2600 NTSC Taiwan
Manufactured in Taiwan
S.N. 828289936
#2 BurritoBeans ONLINE
BurritoBeans
    Moonsweeper
  • 432 posts
Posted Mon Aug 3, 2015 8:09 PM
Finally! A thread about the only model I have...
S/N - 82506814
#3 SSG OFFLINE
SSG
    Dragonstomper
  • 742 posts
  • Live Long, And Prosper.
Posted Mon Aug 3, 2015 8:42 PM
S/N 827821160
IMAG0010
IMAG0011
#4 RichG1972 OFFLINE
RichG1972
    Dragonstomper
  • 644 posts
  • I've played Atari today.....have you?
Posted Mon Aug 3, 2015 9:04 PM
I have 4 of them does that mean I have to list all the bottom certificate numbers?
#5 DrVenkman OFFLINE
DrVenkman
  • 3,552 posts
  • Back off, man! I'm a scientist.
Posted Mon Aug 3, 2015 9:23 PM
Mine has no label, alas.
#6 Nutsy Doodleheimer OFFLINE
Nutsy Doodleheimer
    Total Retard
  • 5,615 posts
Posted Mon Aug 3, 2015 10:00 PM
Yes. Post them on here so we can see you're four switchers. :)
#7 zylon OFFLINE
zylon
  • 6,659 posts
  • 5200 OE HSC Mod
Posted Tue Aug 4, 2015 9:47 AM
and what about the sears models then? The sears 4sw was produced from the last woodies to the vader era.
#8 Nutsy Doodleheimer OFFLINE
Nutsy Doodleheimer
    Total Retard
  • 5,615 posts
Posted Tue Aug 4, 2015 9:53 AM
Sure. You are more than welcome to post any Sears Tele-Games 4 switcher S.N. :)
#9 zylon OFFLINE
zylon
  • 6,659 posts
  • 5200 OE HSC Mod
Posted Tue Aug 4, 2015 4:24 PM
have 3 of these, but only one with SN still attached.
82281004
#10 Opry99er ONLINE
Opry99er
  • 9,913 posts
Posted Tue Aug 4, 2015 4:56 PM
That is is an extremely clean and nice looking system there,zylon!!!
Almost makes me want a 4 banger woody instead of the 6 pack!
#11 zylon OFFLINE
zylon
  • 6,659 posts
  • 5200 OE HSC Mod
Posted Tue Aug 4, 2015 5:06 PM
They're a great find when you can. They only had rev-14 and 16 boards in them so all had good color.
#12 Opry99er ONLINE
Opry99er
  • 9,913 posts
Posted Tue Aug 4, 2015 5:07 PM
Well... Sounds like I should be on the lookout then. Thank you!
#13 zylon OFFLINE
zylon
  • 6,659 posts
  • 5200 OE HSC Mod
Posted Tue Aug 4, 2015 5:20 PM
Yep. Woody's are 25% with rev-14. 13 and under had the really washed out color. Vaders are all good color, but 25% had soldered Ic's on rev-18 and some 17's. 14 through 16 give your best results.
Edited by zylon, Tue Aug 4, 2015 5:20 PM.
#14 Opry99er ONLINE
Opry99er
  • 9,913 posts
Posted Tue Aug 4, 2015 5:26 PM
Learn something new every day. :)
Guess I need to do some research and ask questions about stuff before I buy. :)
#15 Nutsy Doodleheimer OFFLINE
Nutsy Doodleheimer
    Total Retard
  • 5,615 posts
Posted Tue Aug 4, 2015 5:30 PM
82281004
Very nice Sears 4 switcher! I always admired the walnut finish. Need to snag some Tele-Games systems. If I recall correctly. The 4 switch Sears models are the rarest along with the Heavy Sixer? (In terms of the Tele-Games toggle switchers).
#16 DrVenkman OFFLINE
DrVenkman
  • 3,552 posts
Posted Tue Aug 4, 2015 6:16 PM
That's interesting to know. My Rev 14 has fairly poor color, all things considered - certainly much worse than my Light Sixer. I got it super cheap and when I opened up the case, I see where someone had stuck a piece of masking tape over the RF modulator with the worlds "No video" scrawled on it. Clearly it does have a picture now, just not great - I presume someone found a bad solder joint or something and fixed it at one point. Do you think there's anything I could do to improve the color aside from replacing the RF modulator?
#17 zylon OFFLINE
zylon
  • 6,659 posts
  • 5200 OE HSC Mod
Posted Tue Aug 4, 2015 6:59 PM
see page 1-6.
Rev14 is either the last bad one or first good one depending on your point of view. There are also early 14's and late 14's. early 14's had the ceramic caps behind the control ports while later ones had the resistor looking style. 6ers do have better color for the most part, but some 4's get close.
Some did not have the added resistor mentioned in the pdf manual. Just add it and it will be much better. Strangely, I have never had a rev-15 in front of me.
Edited by zylon, Tue Aug 4, 2015 7:00 PM.
#18 DrVenkman OFFLINE
DrVenkman
  • 3,552 posts
Posted Tue Aug 4, 2015 7:26 PM
see page 1-6.
Mine has caps that look like small resistors. I see the Tech Tip you're talking about:  "Some 2600A PCBs have an 820 1/4 W 5% resistor (P/N 14-5821) installed on the solder side (bottom). The resistor is located between pins 6 and 9 of A201 (TIA) and improves the color reproduction of the unit."
I'd love to see a photo of that to make sure I don't mis-identify the pins when I get around to trying this on mine. :)
#19 zylon OFFLINE
zylon
  • 6,659 posts
  • 5200 OE HSC Mod
Posted Tue Aug 4, 2015 7:53 PM
;) This is from the system pictured earlier. it is an early 14 and resistor is not built in yet. Some later ones had it on top right below tia socket. A few had it under the TIA inside the socket so look before you do it.
i think we've done enough hi-jacking here. apologies to OP
Edited by zylon, Tue Aug 4, 2015 8:15 PM.
#20 DrVenkman OFFLINE
DrVenkman
  • 3,552 posts
Posted Tue Aug 4, 2015 8:02 PM
Ah, thanks for that. My Rev 14 looks later than that based on the caps below the difficulty switches. It doesn't have the color boosting resistor added, however. I think I'll do that tomorrow. :)
#21 hookem OFFLINE
hookem
    Moonsweeper
  • 379 posts
  • Patron Saint of Quality Footwear
Posted Thu Aug 20, 2015 12:31 AM
My 4-switch woody promo console:
81205352
Edited by hookem, Thu Aug 20, 2015 12:37 AM.
#22 sramirez2008 OFFLINE
sramirez2008
  • 2,538 posts
  • Stella Foreva
Posted Fri Aug 21, 2015 7:45 PM
I have two 4 Switch Woody's
S/N 81914252 - Modded Console:
S/N 81019322
#23 Opry99er ONLINE
Opry99er
  • 9,913 posts
Posted Sun Aug 23, 2015 11:55 AM
S/N: 811861708
Edited by Opry99er, Sun Aug 23, 2015 11:56 AM.
#24 Opry99er ONLINE
Opry99er
  • 9,913 posts
Posted Sat Aug 29, 2015 6:40 PM
Traded the 811 serial number in for this one. Much nicer system. :)
#25 spawnshop OFFLINE
spawnshop
    Chopper Commander
  • 228 posts
Posted Sat Aug 29, 2015 7:27 PM
I grabbed an un-working 4-switch woody for a mod - here's some images after an LED install.   It just needed some cleaning on the switches and an AV cable replacement, and it works great.
Just waiting for the new A/V and Pause kits to come in!!
S/N: 81134671
It's funny though, all of the earlier posts say that the 4-switch woody's are REV-14 and up, but mine is a REV-12.    Any significance there??
Edited by spawnshop, Sat Aug 29, 2015 7:34 PM.
Also tagged with one or more of these keywords: 4 switch woody, serial, number, atari, 2600
