bikeguychicago Posted August 6, 2015 Share Posted August 6, 2015 I struck retro-gaming gold today and found a Sears-branded Hockey Pong (still made by Atari) at Goodwill for $5! Needless to say, it was an easy purchase decision. I figured that even if it didn't work, it would still look cool in the game room. I got it home and briefly hooked it up to find that it console, surprisingly, actually worked! However, the picture from the console was very snowy. I was unable to find a TV selector switch on it so it looks like it only outputs to channel 4. I'm using a standard RF to Coax converter to hook it up to my Sony Trinitron TV. Using the same connector on the same station, my Intellivision looks nearly flawless. My questions are the following: Is there a way to switch the channel input on these devices? If not, is there a way to improve the output coming from the device? Thanks! Quote Link to comment Share on other sites More sharing options...
atari-dna Posted August 6, 2015 Share Posted August 6, 2015 You can adjust the R/F modulator, which might be off frequency. Try Channel 2 and 3 (not sure 4 was utilized?). Getting the unit apart will be the first priority, pics will help. Also, you may have damaged / crimped points in your RF cord that could be contributing to the poor picture. The cable may need to be replaced, but likely a tuning adjustment if you have picture and just interference / stabilization issue. Does the speaker in the unit emit sounds? Quote Link to comment Share on other sites More sharing options...
chas10e Posted August 6, 2015 Share Posted August 6, 2015 the channel selector switch is most likley inside the console , if odd security screws are there , look under the battery tray , guessing Phillips screws there .... use a flashlight to see if a rectangle hole to access switch turn TV volume off !!! Quote Link to comment Share on other sites More sharing options...
bikeguychicago Posted August 6, 2015 Author Share Posted August 6, 2015 (edited) The console does emit the game sounds fine. I'll check for the switch/battery door when I get home. Edited August 6, 2015 by bikeguychicago Quote Link to comment Share on other sites More sharing options...
atari-dna Posted August 6, 2015 Share Posted August 6, 2015 You'll likely want to open the console. Check for good continuity (multimeter, Ω setting, or continuity "beep" test) and make sure the cable itself passes. I had a Video Pinball that had horrible picture, turned out the cable had tons of resistance and must have had internal breaks, etc which rendered it useless. Replaced the RF cable and the system is clear as a bell. YMMV Quote Link to comment Share on other sites More sharing options...
bikeguychicago Posted August 7, 2015 Author Share Posted August 7, 2015 (edited) So I did a little more investigation and eventually found the channel selector under the battery retainer. It's weird that the switch for changing the channels didn't stick out like it does with every other console (unless the switch is broken). However, i was able to get it switched from channel 4 to channel 3 using a flat blade screwdriver. Channel 3 produced an improved picture over 4. It's not perfect, but for a 40 year-old console (youch) I'm impressed that I got it to work at all. The funny thing is: the original box, in which the game was sitting loose, included a set of C batteries that were new in the cellophane wrap. Each battery has a paper strip covering the positive terminal. I'd never seen that before so I have no idea how old those batteries actually are. On a whim, I installed them all and, what do you know, the console worked! Amazing! Edited August 7, 2015 by bikeguychicago Quote Link to comment Share on other sites More sharing options...
chas10e Posted August 8, 2015 Share Posted August 8, 2015 (edited) You'll likely want to open the console. Check for good continuity (multimeter, Ω setting, or continuity "beep" test) and make sure the cable itself passes. I had a Video Pinball that had horrible picture, turned out the cable had tons of resistance and must have had internal breaks, etc which rendered it useless. Replaced the RF cable and the system is clear as a bell. YMMV you can clean the ends of the RF cable also or try any RCA cable to see if picture improves .... also an old CRT TV might help as well getting inside a console required some ingenuity but made myself an ok tool to do so http://atariage.com/forums/topic/208849-holt-security-screw-removal-sears-pong-sega-ea-carts/ .. I think mine came with original batteries as well , but they were installed & all corroded Edited August 8, 2015 by chas10e Quote Link to comment Share on other sites More sharing options...
atari-dna Posted August 8, 2015 Share Posted August 8, 2015 Is the RF cord itself bent badly, cut or frayed? You may have internal issues with the cable, or the RF modulator may require adjustment. Nice that it's working though; make sure you do *not* forget about those 1973 NiCad batteries though, when packing up the unit for storage... Quote Link to comment Share on other sites More sharing options...
