Ultimate Cart (SD multicart) - preorders thread
multicart sd fpga
263 replies to this topic
#226 mulcmu OFFLINE
mulcmu
    Space Invader
  • 14 posts
Posted Wed Mar 23, 2016 7:34 PM
I took the plunge and attempted to build some myself.  This was my first attempt at SMD soldering using solder paste.  It went much better than I had expected. I highly recommend using the stencil and solder paste method.  The stencil adds some extra cost, but is well worth the investment.  Electrotrain’s assembly notes on the github page give a good overview.  The stencil is only needed for the side with the FPGA.  For the other side applying the solder paste from the syringe or using a toothpick by hand will work well.  I would recommend having a solder wick/braid on hand (with a very fine braid) even if using the stencil as 2 of my 3 boards had bridged pins on the FPGA.  I found having a magnifying glass and eye loupe necessary to inspect the solder paste and finished solder joints.  I would also spend some time watching the eevblog youtube videos on smd/smt reflow soldering before getting started.
I found that using the stencil was pretty forgiving.  If you mess up applying the solder paste you can wipe it off and start over.  When placing the parts on the solder paste some fine adjustment could be done to get it aligned correctly before pressing it down into the paste to hold it in place.
The PCBs, stencil, and parts to build 3 boards cost about 200 USD.  All of the parts were available from Mouser.com (quick and reasonable shipping in the US at least).  The PCB was easily ordered from Oshpark with the eagle .brd file.  I ordered a mylar stencil from Oshstencil, again all that was needed was the eagle .brd file.
I tested operation of the oven several times with junk boards and some ebay smd breakout boards to get a feel for the operation.  For the cost of a new toaster oven and the solder paste you might be able to join a local hackerspace/makerspace for access to a proper reflow oven.  If they have a laser cutter you could even make the stencil there instead of ordering.
PCB in jig to hold in place
Stencil aligned over pcb and taped in place
FPGA side with paste
Close up of FPGA with paste
Bridged pins after reflow, used the cut end of solder braid to wick out the excess with soldering iron.
Closeup of FPGA and clock oscillator.  Clock does not have exposed pins so need to use oven or hot air.
Front with paste applied by hand
Front with paste and parts
Front reflowed with hot air gun.
(I modified the PCB eagle file to add the pull up resistor on the SD card.  In the process I deleted the power trace to the SD card.  Fixed with the black jumper wire.)
#227 pjbramley OFFLINE
pjbramley
    Star Raider
  • 82 posts
Posted Thu Mar 24, 2016 5:51 AM
How do we get payment details?
#228 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,232 posts
Posted Thu Mar 24, 2016 11:31 AM
hmm.... I was told to do all the parts that need baking first then hot air followed by the drag and finally conventional connections.... The only time that order was altered was when using infra red.... it seems nobody does thru the hole wave soldering anymore...
#229 TechCowboy OFFLINE
TechCowboy
    Space Invader
  • 26 posts
Posted Sat Mar 26, 2016 2:32 PM
Is there any plans for another run?
#230 Bikerbob OFFLINE
Bikerbob
    Dragonstomper
  • 630 posts
Posted Tue Mar 29, 2016 11:00 PM
I could be very insterested in this if more become available.
I am not interested in building the board.. if I can get a finished unit? or someone finish it for me.
James
#231 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 331 posts
  • Mr Ziggy loves to extend the 1050 heatsink!
Posted Tue Apr 5, 2016 11:23 AM
i am very interested in one of these
please let me know if available
thanks
#232 santosp OFFLINE
santosp
    Dragonstomper
  • 790 posts
Posted Wed Apr 6, 2016 9:49 PM
thanks
P.M. sent. :)
#233 Scooter83 OFFLINE
Scooter83
    Dragonstomper
  • 671 posts
Posted Wed Apr 6, 2016 10:16 PM
2 for me
#234 Allan OFFLINE
Allan
  • 6,281 posts
Posted Thu Apr 7, 2016 6:09 AM
I'm interested in one of these also.
Allan
#235 retrobits OFFLINE
retrobits
    Chopper Commander
  • 114 posts
Posted Thu Apr 7, 2016 10:14 AM
I would buy a completed cart board.  No smd soldering for me.
#236 TechCowboy OFFLINE
TechCowboy
    Space Invader
  • 26 posts
Posted Thu Apr 7, 2016 2:42 PM
If the complete cart board becomes available, I would like one as well.
#237 AtariSociety OFFLINE
AtariSociety
    Moonsweeper
  • 300 posts
Posted Thu Apr 7, 2016 10:15 PM
Completed Cart for me if they can ship to USA.  Qty 1.  TJ
#238 Foxbat OFFLINE
Foxbat
    Combat Commando
  • 4 posts
Posted Mon Apr 11, 2016 5:19 PM
I would be up for a cart as well. Qty 1
#239 bakerb316 OFFLINE
bakerb316
    Combat Commando
  • 3 posts
Posted Tue Apr 12, 2016 10:02 AM
I would love one as well.  I'd prefer a complteted cartridge but might have a source which could handle surface mount soldering one for me if a parts kit were available to purchase.  If either of these are availabe, please let me know the costs.  Thanks you.  From an avid Atarian since the 2600 but spent most of my time on my 800 & 130XE.
#240 jcbstein OFFLINE
jcbstein
    Space Invader
  • 21 posts
Posted Mon Apr 18, 2016 2:07 PM
I too would be interested in purchasing a completed Ultimate Cartridge as well.
Hopefully there will be a second run of these.
#241 576XE OFFLINE
576XE
    Dragonstomper
  • 770 posts
Posted Tue Apr 26, 2016 12:39 AM
I simply NEED one completed of this.
Please!
Best Wishes!
#242 IndusGT OFFLINE
IndusGT
    Moonsweeper
  • 397 posts
Posted Tue Apr 26, 2016 3:28 PM
Been looking for one too thanks
#243 AA737 OFFLINE
AA737
    Space Invader
  • 10 posts
Posted Wed May 4, 2016 7:19 PM
Interested in one!
#244 davidcalgary29 ONLINE
davidcalgary29
  • 6,149 posts
Posted Mon Jun 6, 2016 11:13 AM
I'm in for two!
#245 SEADRIVE OFFLINE
SEADRIVE
    Combat Commando
  • 5 posts
Posted Thu Jul 14, 2016 5:27 PM
I love to see items like this available...please put me down for one too...as long as it will work on NTSC, for I am from Canada...thanks!
#246 venom4728a OFFLINE
venom4728a
    Dragonstomper
  • 615 posts
Posted Thu Jul 14, 2016 9:09 PM
i WOULD LIKE ONE.
#247 tuf OFFLINE
tuf
    Chopper Commander
  • 245 posts
Posted Sun Jul 24, 2016 12:46 AM
Add me to the list for 1!!
#248 Serblander OFFLINE
Serblander
    Dragonstomper
  • 805 posts
Posted Sun Jul 24, 2016 9:09 AM
+1 No Returns! :D
Just got the Lynx SD cart and would love to finally have something like this for my XEGS!!!
Cheers!
#249 Zoyx OFFLINE
Zoyx
  • 1,581 posts
  • Prominent Internet User
Posted Thu Aug 18, 2016 3:25 PM
If this works with the XEGS, I would like to be added to the list. Thanks.
#250 orpheuswaking OFFLINE
orpheuswaking
  • 5,767 posts
  • Lone Raider Time!
Posted Fri Aug 19, 2016 7:05 AM
Preorders happening in the thread by Santosp, need at least 20 orders... so get over there ;-)
http://atariage.com/...-2#entry3574141
Edited by orpheuswaking, Fri Aug 19, 2016 7:06 AM.
Also tagged with one or more of these keywords: multicart, sd, fpga
