Ultimate Cart (SD multicart) - preorders thread
multicart sd fpga
257 replies to this topic
#51 gozar OFFLINE
gozar
    Dragonstomper
  • 868 posts
Posted Thu Aug 20, 2015 5:01 AM
Is there a way to change the SD slot to one like on the older Raspberry Pis? The current slot won't let you use a micro SD to SD adapter:
At the top is the adapter. You can see it is a little thicker than an SD card.
Sent from my iPhone using Tapatalk
#52 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 290 posts
Posted Thu Aug 20, 2015 5:09 AM
Sorry Gozar - I've got no intention of changing the PCB at this point, though I do quite like the look of the SD card slot in your picture - it would have given me a bit more room on the PCB!
However, the current slot *does* support microsd in an adapter - in fact all the pictures I've posted of the new board are using micro sd in an adapter - just not the adapter pictured. I've been using the kind of adapters you get in the package whenever you buy a microsd card.
#53 Firedawg OFFLINE
Firedawg
    Dragonstomper
  • 518 posts
Posted Thu Aug 20, 2015 9:21 AM
I would be interested in obtaining 5 of just the PCBs and building them myself.  Thx Robin!
Mike
#54 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 290 posts
Posted Thu Aug 20, 2015 9:49 AM
Mike
I like your attitude :-)
I'll PM you a link to the board files (I'm planning to start a technical thread soon, but haven't got all the files uploaded to github yet).
Edited by electrotrains, Thu Aug 20, 2015 9:49 AM.
#55 gozar OFFLINE
gozar
    Dragonstomper
  • 868 posts
Posted Thu Aug 20, 2015 2:03 PM
I didn't think it would require a redesign of the PCB, just the purchase of a different SD slot (I have no idea what the name of the slot that is soldered onto the board is called). :-)
#56 Gandor OFFLINE
Gandor
    Moonsweeper
  • 347 posts
Posted Thu Aug 20, 2015 8:51 PM
I would be interested in one
#57 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 617 posts
Posted Fri Aug 21, 2015 2:29 AM
I would be interested in a cased one (depending on the final price).
#58 flashjazzcat ONLINE
flashjazzcat
  • 13,356 posts
Posted Fri Aug 21, 2015 4:38 AM
Note: happy to report that the production cart fits into an 800 with the lid closed and SD card present without any difficulty, although my 800 has the metal shield missing from inside the door. Clearance is very good, though. :)
#59 kenjennings OFFLINE
kenjennings
    Dragonstomper
  • 787 posts
  • Me + sio2pc-usb + 70 old floppies
Posted Fri Aug 21, 2015 4:49 AM
That's different.   All the microSD to SD card adapters I have look like SD cards.  the MicroSD card slides into the top of the SD-like card, and then it goes into any SD card slot.
#60 Firedawg OFFLINE
Firedawg
    Dragonstomper
  • 518 posts
Posted Fri Aug 21, 2015 5:46 AM
Thanks brother! Your hard work is very much appreciated.
Mike
#61 gozar OFFLINE
gozar
    Dragonstomper
  • 868 posts
Posted Fri Aug 21, 2015 5:48 AM
I think there is some confusion. The micro SD to SD adapter I showed is for the older Raspberry Pi so the SD card doesn't hang out by 1/2", and instead, is flush with the motherboard. Unfortunately, the SD slot in the Ultimate cart is enclosed, which doesn't allow you to use the Pi micro SD adapter. If we could use the Pi micro SD adapter, then the SD card would not be hanging out. :-)
It's more of an aesthetic issue at this point, since FJC confirmed the Ultimate Cart does fit in the 800.
Edited by gozar, Fri Aug 21, 2015 5:49 AM.
#62 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 290 posts
Posted Fri Aug 21, 2015 5:56 AM
If you case your board though (which does look much nicer), there would be no easy way to get the adapter card out again if it was flush with the board....
#63 flashjazzcat ONLINE
flashjazzcat
  • 13,356 posts
Posted Fri Aug 21, 2015 6:31 AM
Just properly tested the production cart with an Incognito 800 as well, and everything appears to work. :)
#64 orpheuswaking OFFLINE
orpheuswaking
  • 5,678 posts
  • Lone Raider Time!
Posted Fri Aug 21, 2015 7:24 AM
Cheers, Robin.
Definitely interested and probably up for buying one...
8Bit Baz
Love the New Atari User profile pic
#65 gozar OFFLINE
gozar
    Dragonstomper
  • 868 posts
Posted Fri Aug 21, 2015 10:31 AM
That is a good point!
#66 dragos OFFLINE
dragos
    Moonsweeper
  • 280 posts
Posted Fri Aug 21, 2015 7:13 PM
Please put me down for one!
Thanks
#67 billysastard OFFLINE
billysastard
    Chopper Commander
  • 113 posts
Posted Sat Aug 22, 2015 5:51 PM
please add me to the list :D
#68 retango OFFLINE
retango
    Space Invader
  • 43 posts
Posted Sat Aug 22, 2015 7:38 PM
I'm in for one, please. If you offer cased, I'll take the case too.. Thanks!
#69 ivop OFFLINE
ivop
    Dragonstomper
  • 624 posts
Posted Mon Aug 24, 2015 10:13 AM
I'd like one, too. Thanks, ehm, too! :)
#70 Savetz OFFLINE
Savetz
    Dragonstomper
  • 942 posts
Posted Tue Aug 25, 2015 10:45 AM
One please
#71 Allan OFFLINE
Allan
  • 6,152 posts
Posted Tue Aug 25, 2015 1:48 PM
Well, if Kevin is getting one, I am too.
One please.
Allan
#72 atariLBC OFFLINE
atariLBC
    Moonsweeper
  • 496 posts
Posted Tue Aug 25, 2015 7:35 PM
I am in for one, too. I am hoping for a cased version, though I have some grey loose carts that could be sacrificed!
#73 Umberto OFFLINE
Umberto
    Moonsweeper
  • 272 posts
Posted Tue Aug 25, 2015 7:39 PM
I definitely want looks great
#74 Clint Thompson OFFLINE
Clint Thompson
  • 4,293 posts
  • Kiss Reality Goodbye.
Posted Tue Aug 25, 2015 7:55 PM
Put me down for 1. Are they going to come blue or can we have them in gray standard XE carts as an option as well?
Thanks!
#75 Defender II OFFLINE
Defender II
  • 1,161 posts
Posted Tue Aug 25, 2015 8:32 PM
Thanks!
It is just the populated PCB. You need to get install into your own case.
Also tagged with one or more of these keywords: multicart, sd, fpga
