Entry 2015: Zyx
22 replies to this topic
#1 atari2600land OFFLINE
atari2600land
    Channel F Viewer
  • 11,399 posts
Posted Sat Aug 29, 2015 1:41 AM
Oh no! Zyx is trapped in a well! People are kind enough to throw him bananas to catch and eat. They're also worth a point. However if you miss one, the game ends. Complicating matters is the pack of evil Vuts which have found their way into the well and dug a tunnel through it. They also go back and forth sometimes. Your job is to jump over them. Touching a Vut also ends your game.
I started on this game when the contest was announced, but it started giving me problems so I gave up on it. Only today I had come back to it, fixed all the problems. Except one: I can't make a file bigger than 9.55k. I don't know why. It will compile, but when I play it in jzintv, it won't work. So I guess I'll have to keep it under 9.55k, unless someone can figure out why this is?
#2 GroovyBee OFFLINE
GroovyBee
    Games Developer
  • 9,818 posts
  • Busy bee!
Posted Sat Aug 29, 2015 2:10 AM
:cool: Its good to see another entry.
Without more information its difficult to make suggestions. What version of IntyBASIC are you using? Upgrading to 1.2.2 is highly recommended. Is it possible to take a look at the source code?
#3 atari2600land OFFLINE
atari2600land
    Channel F Viewer
  • 11,399 posts
Posted Sat Aug 29, 2015 2:16 AM
I am using 1.0.4. I didn't realize we were up to 1.2.2. That's what I get for not keeping up, I guess.
#4 DZ-Jay OFFLINE
DZ-Jay
  • 11,156 posts
  • The P-Machinery AGE is almost here!
Posted Sat Aug 29, 2015 5:56 AM
Yeah, Óscar is on a roll!  The latest version adds a lot of new features as well. :)
     -dZ.
#5 atari2600land OFFLINE
atari2600land
    Channel F Viewer
  • 11,399 posts
Posted Sat Aug 29, 2015 5:51 PM
It still won't let me do anything above 9.5 k. Here's what I have so far.
  • Attached File  zyx.bas   14.55KB   267 downloads
#6 nanochess ONLINE
nanochess
    Processorus Polyglotus
  • 5,529 posts
  • Coding something good
Posted Sat Aug 29, 2015 8:24 PM
This one compiles, can you put one (the following one) that doesn't compile?
#7 atari2600land OFFLINE
atari2600land
    Channel F Viewer
  • 11,399 posts
Posted Sat Aug 29, 2015 8:25 PM
It compiles OK, but try playing it in jzINTV.
#8 atari2600land OFFLINE
atari2600land
    Channel F Viewer
  • 11,399 posts
Posted Sat Aug 29, 2015 8:36 PM
It likes to be "off in the weeds..."
#9 nanochess ONLINE
nanochess
  • 5,529 posts
Posted Sat Aug 29, 2015 9:50 PM
Hmmm. it works just fine in my setup, there appears a little monster that catch bananas and monsters appears in tunnel from both sides.
Have you updated the intybasic_prologue.asm and intybasic_epilogue.asm files along with the compiler? (I suggest v1.2.1)
#10 atari2600land OFFLINE
atari2600land
    Channel F Viewer
  • 11,399 posts
Posted Sat Aug 29, 2015 10:14 PM
I probably did. I used the same batch files I used, I just copied them into the 1.2.2 file and changed the name of the files it pointed to so it said "zyx" instead of the previous program I was working on.
#11 Tarzilla OFFLINE
Tarzilla
  • 2,069 posts
  • Huh?
Posted Sat Aug 29, 2015 11:23 PM
It works in every of the several different installs of IntyBASIC and jzintv I have on different machines.
You might also want to catch up on the many features added to the last several versions of IntyBASIC, especially the flurry of user friendly enhancements done in the last 2 months. For instance:
print_score: procedure
print at 233,(#score/1000%10+16)*8+7
print at 234,(#score/100%10+16)*8+7
print at 235,(#score/10%10+16)*8+7
print at 236,(#score%10+16)*8+7
Can be replaced with one line of optimized code
PRINT AT 233,<4>#score
You should probably install the IntyBASIC SDK kit from this thread:
http://atariage.com/...-intybasic-sdk/
It will give you "clean" install, along with new code examples and better workflow. Use the INCLUDE feature to access all the new Constants in CONSTANTS.BAS so you can get rid of lots of the hex values scattered throughout your code, it'll make your life easier.
#12 atari2600land OFFLINE
atari2600land
    Channel F Viewer
  • 11,399 posts
Posted Sat Aug 29, 2015 11:26 PM
I renamed the file zyx2 and it works perfectly. How weird is that?
  • Rev likes this
#13 atari2600land OFFLINE
atari2600land
    Channel F Viewer
  • 11,399 posts
Posted Sat Aug 29, 2015 11:28 PM
I'd like the score to be against a black background, not a gray one that looks cut out from the background.
#14 atari2600land OFFLINE
atari2600land
    Channel F Viewer
  • 11,399 posts
Posted Sat Aug 29, 2015 11:54 PM
OK, sorry if I sounded mean in the last post, but I think my score is fine. Anyway, here's an updated version of my title screen.
I thought the [C] looked stupid (the parenthesis look more like brackets than they do parentheses), so I changed it.
#15 DZ-Jay OFFLINE
DZ-Jay
  • 11,156 posts
Posted Sun Aug 30, 2015 5:59 AM
Your new copyright symbol looks good.  There's only so much you can do with an 8x8 tile.  I use the same as you:
	' Real Copyright Symbol
	BITMAP ".######."
	BITMAP "#......#"
	BITMAP "#..###.#"
	BITMAP "#.#....#"
	BITMAP "#.#....#"
	BITMAP "#..###.#"
	BITMAP "#......#"
	BITMAP ".######."
By the way, if you have some GRAM free, how about making your own fonts for your name? :)
     -dZ.
Edited by DZ-Jay, Sun Aug 30, 2015 6:00 AM.
#16 atari2600land OFFLINE
atari2600land
    Channel F Viewer
  • 11,399 posts
Posted Sun Aug 30, 2015 4:46 PM
I actually did, but I changed it back. I forgot why. So I redesigned some new fonts for my name. I used the a as what I put here because that's how I would write it. Not like the fancy a in most fonts with the line above the round part. I hope it doesn't interfere with the built-in font I use to explain the game (seen later in the attract mode.)
I also added a jumping sound, as well as a banana catching sound and made the game speed up at ten points, and again at twenty points. I am on a roll with this.
#17 DZ-Jay OFFLINE
DZ-Jay
  • 11,156 posts
Posted Sun Aug 30, 2015 6:06 PM
They "a" could use some work, but in general it looks good. :)
Perhaps pimpmaul69 will chime in with some suggestions. He's our resident pixel artist. :)
dZ.
#18 pimpmaul69 OFFLINE
pimpmaul69
  • 4,854 posts
  • INTV Brotherhood Technician
Posted Sun Aug 30, 2015 6:11 PM
I would just chop the highest pixel off. And for the r's i would add one pixel to the blank space to make the r's match the others.
#19 atari2600land OFFLINE
atari2600land
    Channel F Viewer
  • 11,399 posts
Posted Sun Aug 30, 2015 10:56 PM
I fixed the a and r.
#20 Rev OFFLINE
Rev
    A.K.A. Revolutionika
  • 16,128 posts
Posted Wed Sep 16, 2015 1:12 PM
Any more updates to show off?  thanks!
#21 atari2600land OFFLINE
atari2600land
    Channel F Viewer
  • 11,399 posts
Posted Fri Dec 4, 2015 11:44 AM
I e-mailed the entry about a month ago and got no response.
#22 Albert ONLINE
Albert
  • 34,720 posts
Posted Fri Dec 4, 2015 12:27 PM
I do have your entry, I'll go over the email later today.
..Al
#23 Rev OFFLINE
Rev
  • 16,128 posts
Posted Sat Dec 26, 2015 5:34 PM
Update on zyx?
