Calling All 800s!
129 replies to this topic
#1 ClausB OFFLINE
ClausB
  • 1,596 posts
Posted Sun Aug 30, 2015 7:45 PM
Post your 800's serial numbers here. Don't forget the 3-digit date code! It's ink-stamped on the label or gold-stamped on the case bottom. See discussion in the 400 thread.
Atari 800 serial numbers & owners & dates WW/YY:
NTSC:
26 ClausB ??/78
9 49 3806 ClausB 49/79
9 49 4420 Falter 49/79
060 0501 Scooter83 06/80
070 0133 Scooter83 07/80
1 70 1982 ClausB 17/80
1 80 2443 Sean39 18/80
2 30 4686 (WW031/23) bandit 23/80
G 23 490 0498 a8isa1 49/80
G 091 0679 Sean39 09/81
G 16K 391 2107 (G 175 AW072904-16 9/24 L40 P) Serrameade6 39/81
G 16K 401 5298 (G 174 AW072525-16 9/30 L40 P) Stephen 40/81
G 16K 441 7498 Muzz73 44/81
G 16K 481 5208 (G 161 AW202121-16 11/23 L40 P) hunmanikl 48/81
G 16K 481 5535 Paul Westphal 48/81
G 16K 022 5173 (G 144 AW201792-16 12/29 L40 P) hunmanikl 02/82
G 16K 052 7484 (AW 206504 1-28) russg 05/82
G 16K 062 8153 mutterminder 06/82
AW 303469 082 Skeeter 08/82
AW 306011 102 (AW 212893 3-3) FlorianD 10/82
AW 306445 ??? (G 154 AW213517-16 3/5 L20 H) Pack007 10/82
AW 332067 182 (G 155 AW230681-16 4/28 L114 H) hunmanik 18/82
AW 312189 322 (AW 328667-8-2) oracle_jedi 32/82
AW 327028 322 (AW 332152-8-11) adam242 32/82
AW 329659 332 (AW 327652 8/9) Stephen 33/82
AW 327684 332 (AW 322748 8/13) DrVenkman 33/82
AW 350162 342 Pack007 34/82
AW 350517 342 (AW 345584 8/16) ClausB 34/82
362084 342 adam242 34/82
366633 382 KBRpilot 38/82
357888 392 davidcalgary29 39/82
407147 442 (AW 359989 10-27) megarat 44/82
406740 462 (AW 375210-11-9) Mitch 46/82
389740 472 (AW 385819 11-18) adam242 47/82
388606 472 kb3wmh 47/82
346602 502 (AW 382092 12-7) MrFish 50/82
377147 013 shoestring 01/83
468626 023 wemichener 02/83
474365 033 (AW454017 1/18) gamer-stu 03/83
463113 063 toddtmw 06/83
429962 083 Agent570 08/83
449281 083 (AW 470545-2-24) tep392 08/83
449773 083 Ripdubski 08/83
424185 123 ryanmercer 12/83
467911 153 Pack007 15/83
83S AW 23586 163 FredM 16/83
83S AW 02123 183 pedalnote 18/83
83S AW 02633 183 (AW 507217 5-5) DrVenkman 18/83
83S AW 04211 183 adam242 18/83
83S AW 20118 183 (AW 491283-5-3) ryanmercer 18/83
83S AW 20933 183 (AW 505227 5/4) Faicuai 18/83
83S AW 66508 203 (AW 512190 5-20) DrVenkman 20/83
83S AW 71280 203 (AW 501899 5-18) eegad 20/83
83S AW 98218 203 (AW 512778-5-20) TangentAudio 20/83
83A AW 00620 233 BillC 23/83
85A? AW 01651 243 Agent570 24/83
AW 327741 ??? tschak909 ??/??
AW 347179 ??? adam242 ??/??
AW 356203 ??? adam242 ??/??
PAL:
052 00153 161 G (WW161/25) slx 16/81
052 001287 221 G (WW221/25) JoSch 22/81
BK 004582 (G 162 BK 107585-16 06/02 L40 P) OBO 16/82
BK 004571 232 (G 151 BK108059-16 06/03 L40 P) Wrathchild 23/82
BK 006336 332 (BK 107777 8/4) firestorm 33/82
052 006188 342 (83A CA 00020 213) FredM 34/82
052 006421 (CA 105974 8/31) FlorianD ??/82
052 006528 392 (CA 104541 9/21) Fox-1/mnx 39/82
BK 014072 452 spookt 45/82
BK 009858 502 (BK 129167 12/7) Zarxx 50/82
BK 009914 502 (BK 129074 12/6) oracle_jedi 50/82
052 203561 053 sup8pdct 05/83
BK 016180 063 (BK 202073 2/8) ultrasteve 06/83
052 203717 063 sup8pdct 06/83
BK 026880 093 slx 09/83
052 203140 113 (CA151177 3-15) ebiguy 11/83
83A CA 00092 213 Level42 21/83
BK 013601 AHA ??/??
Edited by ClausB, Tue Mar 5, 2019 7:51 PM.
#2 adam242 OFFLINE
adam242
  • 1,010 posts
Posted Sun Aug 30, 2015 9:09 PM
I have three 800s...
83S AW 04211  #183
Third one is missing the sticker entirely, but it has 48K and GTIA, so can't be that old.
#3 Mitch OFFLINE
Mitch
  • 6,630 posts
  • 7800 Guy
Posted Sun Aug 30, 2015 10:33 PM
Mine has: No 406740 on the main sticker and a date code of 462. On the smaller sticker below it is hand written AW375210-11-9
It has a GTIA.
Mitch
#4 russg OFFLINE
russg
  • 1,648 posts
Posted Mon Aug 31, 2015 3:16 AM
It has a GTIA.
Mitch
I have one the numbers are wiped off the sticker, but has ATARI / 081 stamped on it (8th week 1981, don't think so)
My second one has:
G 16K 052 7484  (5th week 1982?) on sticker
and on second sticker:  AW 206504  1-28
has ATARI 081 stamped on case
So '081' stamped doesn't mean 8th week 1981.
or 081 means the case was made 8th week 1981?
Edited by russg, Mon Aug 31, 2015 3:35 AM.
#5 Stephen ONLINE
Stephen
  • 7,593 posts
  • A8 Gear Head
Posted Mon Aug 31, 2015 9:01 AM
NTSC 800 with GTIA.  This is my 800 with Incognito.
This is also an NTSC unit which is currently not working.  It has a weird stamp in the bottom of the case and is sadly also a GTIA.
#6 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
  • Back off, man! I'm a scientist.
Posted Mon Aug 31, 2015 6:04 PM
I'm rather astounded that no such thread existed before now. Well done, Claus. :)
I have two currently. The first looks to have been built in August 1982, per both the "332" week/month inkstamp on the main serial number label, as well as the "8/13" date on the handwritten second serial number label. August 13 is a pretty good correlation with the 33rd week of 1982. This machine still has thumb tabs rather than screws for the slot cover, although the ram is uncased. Speaking of which, this machine has one stock Atari 16K board in slot 1, and a vintage third-party 32K board in slot 2. Thus I suspect this was built as a 16K machine but later upgraded by its owner early in life.
My second is a "late model" 800 from May 1983, per the three digit inkstamp on the large main label, as well as the "5-5" date on the handwritten secondary label. Again, May 5 matches up pretty well with week 18 of 1983. This machine is boxed and was 48K straight from the factory as you would expect from the manufacturing date (and from the large "48K" sticker on the box ;) ) - the slot cover is screwed down and there are the expected 3 standard Atari 16K boards.
Interestingly, in both cases the number on the handwritten label does not match the number on the large main label. Also, looking at these two, it is apparent that Atari changed their numbering scheme for the large labels somewhere along the way.
#7 tep392 OFFLINE
tep392
  • 3,111 posts
Posted Tue Sep 1, 2015 10:35 AM
The handwritten labels look similar to the labels that are attached to the boards inside the computer.  Is it possible this label is a copy of the label on the main board?  Or it could just serve the same purpose as the labels on the internal boards, whatever that might be.
#8 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
Posted Tue Sep 1, 2015 10:51 AM
I don't think there are labels on the boards inside either of mine. I'll have to review all my photos tonight when I get home from work to be sure. One of my 400's has a secondary label like this on the bottom as well, without any internal labels that I recall.
Sent from my iPhone using Tapatalk
#9 tep392 OFFLINE
tep392
  • 3,111 posts
Posted Tue Sep 1, 2015 11:00 AM
I posted this pic of my 810 side board a while back that shows the tag on it.  Not exactly the same but it has a similar code with 2 alpha and 6 numeric characters.  I'm pretty sure I've seen these inside my 400 as well.  I'll have to take a look later.
http://atariage.com/...d/#entry1907307
#10 tep392 OFFLINE
tep392
  • 3,111 posts
Posted Tue Sep 1, 2015 11:11 AM
 This guy has disassembled/photographed a TON of hardware.  This 400 has the labels on every board but none start with AW.  Of course it's missing from the bottom of the case. :roll:  I would still like to know the purpose of that sticker since it doesn't seem to match the S/N on the label.  Were's an ex-Atari employee when you need one?
http://www.the-liber...-1-16k-ntsc.htm
#11 tep392 OFFLINE
tep392
  • 3,111 posts
Posted Tue Sep 1, 2015 11:32 AM
Here we go.  It's not very clear, but I'm pretty sure the sticker on the bottom of this 800's case matches the code on the sticker attached to the top of the RF shield.
http://imgur.com/gallery/rJyB3
#12 spookt OFFLINE
spookt
  • 1,794 posts
  • This is SPARTA(DOS)
Posted Tue Sep 1, 2015 11:33 AM
OK here's my PAL (UK) 800:
Edited by spookt, Tue Sep 1, 2015 11:34 AM.
#13 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
Posted Tue Sep 1, 2015 12:08 PM
Now this I can confirm for at least one or two of my machines. I'll have to get home from work for photos but I've noticed this before.
#14 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
Posted Tue Sep 1, 2015 6:06 PM
Okay, I've reviewed the disassembly photos of my machines tonight and I stand corrected - most of the boards inside my 400/800 machines do indeed have stickers, but not all of them. All four were made from mid-'82 to around May '83, so I think it's likely they all started life with stickers like that but some of them have gotten lost. For instance, in my later 800 (the one with 3 stock 16K boards) two of the RAM boards have stickers but one does not.
To address the question I've bolded above, one of my 400's has a sticker on the main board but the other does not. However, on the one with such a sticker, the number there does not match the handwritten label on the case.
Edited by DrVenkman, Tue Sep 1, 2015 6:07 PM.
#15 tep392 OFFLINE
tep392
  • 3,111 posts
Posted Tue Sep 1, 2015 9:46 PM
Here are the numbers for my 800.
date code: 083  week 8, 1983
s/n: 449281
hand written label  AW 470545    2-24
The AW number matches the label on the RF shield.
#16 ClausB OFFLINE
ClausB
  • 1,596 posts
Posted Wed Sep 2, 2015 6:29 PM
Two more of mine:
Handwritten and gold-embossed: 9 49 3806
Printed AW 350517 342 and handwritten AW 345584 8/16
#17 ClausB OFFLINE
ClausB
  • 1,596 posts
Posted Sat Sep 5, 2015 6:13 AM
Does the third one have an embossed stamping at the back of the case bottom? My third one also lacks a sticker but the stamping shows the numbers.
#18 ClausB OFFLINE
ClausB
  • 1,596 posts
Posted Sat Sep 5, 2015 6:36 AM
NTSC:
26 ClausB ??/78
406740 462 (AW375210-11-9) Mitch 46/82
PAL:
#19 DrVenkman OFFLINE
DrVenkman
  • 3,970 posts
Posted Sat Sep 5, 2015 6:58 AM
Just a suggestion, Claus - PM Albert or another Moderator and ask for permission to edit the first post of this thread so you can keep the up-to-date list there where it's easy to find. I think they can rescind the time limit for you to do that. :)
#20 Ripdubski OFFLINE
Ripdubski
  • 1,308 posts
Posted Mon Sep 7, 2015 8:10 PM
Here is mine.  Had to dig it out of storage.
The bottom shell doesn't match the innards.  In the late 80's I replaced the bottom due to a crack/chip.
Edited by Ripdubski, Mon Sep 7, 2015 8:12 PM.
#21 Paul Westphal OFFLINE
Paul Westphal
  • 1,295 posts
Posted Thu Sep 10, 2015 3:05 PM
G 16k 481 5535
#22 Paul Westphal OFFLINE
Paul Westphal
  • 1,295 posts
Posted Thu Sep 10, 2015 3:07 PM
Related : I have a 400 with #331 that came from Alamogordo, NM.
#23 pedalnote OFFLINE
pedalnote
    Combat Commando
  • 1 posts
Posted Sat Sep 12, 2015 10:45 PM
I am new here, but I can contribute my serial plate!  The handwritten sticker fell off a long time ago....  From what I have learned here, it appears my 800 is a later model.  I recently retrieved it from storage because my oldest son (10yo) has become interested in retro-gaming.
From lurking on this board and reading 800 technical documents, I have learned that it is very similar the 68HC11 I used in college and in my early professional life - I learned machine language coding on it in school and did a lot of robotics work and control systems work using the HC11.  I even wrote an Ada compiler that targeted the HC11.  Of course, this was all some time ago ('93 to '99)   But, I only have a single 800 at the moment, and I am a bit apprehensive to hack on it.  I did build the SIO2PC - out of necessity as my 1050 drive died shortly after getting it out of storage along with the 800.  I even pulled out my HP1651A and my (broken screen) TDS2012 in anticipation of some kind of HW work ;)  The HP still works, but the screen takes about 10min to warm up....  my first project seems to be to try and get the 1050 operational again.
#24 ryanmercer OFFLINE
ryanmercer
    Moonsweeper
  • 433 posts
Posted Mon Sep 14, 2015 5:13 AM
83s aw 20118 183 (aw 491283-5-3)
Image at -> http://www.ryanmerce...5phl1o5sipcim04 (forums image linking doesn't like the fact that there is no image file extension)
#25 Agent570 OFFLINE
Agent570
    Space Invader
  • 13 posts
Posted Thu Sep 17, 2015 3:12 PM
Machine #1:
Serial 429962 083 (no sticker)
Machine #2:
85A AW 01651 243 (bought this one from BNC in '91)
