Joey Z Posted April 25, 2017 Author Share Posted April 25, 2017 (edited) it looks to me like the NVT codes match with ASCII control codes, and the meanings of those are fairly standard, and normally act as they are described in that specification. I think you can pass them without translation (aside from the 850 style translation, if enabled) Also, does the 850 support translation in concurrent mode? if it does, this normally happens in the R: handler. In concurrent mode, the 850 becomes a fancy level shifter, digitally copying serial RX to SIO TX and SIO RX to serial TX. In line mode, the 850 may do the translation. Either way, I think the differences between RespeQts R: and the 850 is probably going to be different enough that at least a partial rewrite of the handler is going to be necessary, or at least beneficial. The 850, in concurrent mode, was a fairly dumb device limited by the lack of real UARTs, small RAM, and slow CPU. The 850, for these reasons, offloaded some things to the atari computer. However, these limitations aren't present within RespeQt, so we can do these things in RespeQt rather than on the atari. translation is the first example that comes to mind, but another example is that a FIFO can be implemented in RespeQt, unlike the 850 hardware which had no FIFO in concurrent mode. Some of these changes need no change to software (a FIFO would not break the 850's R: handler) but others do, like translation within RespeQt. EDIT: additionally, you can assume that if the user is using a terminal that doesn't comply with NVT (ATASCII terminal for example), then the user knows what they are doing, and is also sure that the far end doesn't expect compliance with NVT and will instead cater to the needs of the client (send ATASCII characters for example). Edited April 25, 2017 by Joey Z 1 Quote Link to comment Share on other sites More sharing options...
phaeron Posted April 26, 2017 Share Posted April 26, 2017 The 850 controller source is available: http://www.atarimuseum.com/computers/8bits/400800/atari850.html It does not do translation or parity, in either block or concurrent mode. That's done by the R: handler. In-band signaling is also likely to be more reliable for sensing control signals, which for the 850 requires frequently dropping in and out of concurrent mode to send check commands. The downside is that RespeQt would not be compatible with standard 850 R: handlers. PC serial timing may not be good enough for that anyway, though. The P:R: Connection uses a similar protocol to the 850 but ditches block mode in hardware, emulating it with concurrent mode. The R-Verter and SX212 solve the control signal sensing problem by using SIO proceed/interrupt lines, but good luck finding an SIO2PC cable supporting those. The Telnet protocol is a bit of a mess -- you really have to test against actual servers upon which you'll find that (a) a popular Telnet server relies upon a behavior counter to the standard but which everyone has to support, or (b) the behavior you're seeing isn't accounted for in the five RFCs you're looking at because there's another sixth RFC up in the 7xxx range that accounts for it. 2 Quote Link to comment Share on other sites More sharing options...
TheMontezuma Posted April 26, 2017 Share Posted April 26, 2017 I only wondered if this approach would work if the application would not explicitely call close operation of the R Handler (to leave concurrent IO mode) before accessing SIO devices (like a disk drive). Normally an application does not need to do it, because the asserted command line would automatically stop the 850 concurrent IO mode. I need to sniff the communication with a real 850 and study the 850 documentation to find it out From 850 doc: CLOSE is the only way to terminate concurrent mode I/O from a program.[...] FAILURE TO TERMINATE CONCURRENT MODE I/O PROPERLY BEFORE ATTEMPTING I/O TO OTHER PERIPHERALS (OR EVEN OTHER RS-232-C PORTS) WILL PROBABLY RESULT IN PROGRAM FAILURE. THE ONLY WAY TO RECOVER FROM SUCH FAILURE IS BY TURNING TNE COMPUTER OFF THEN ON AGAIN, WHICH RESULTS IN THE LOSS OF INFORMATION IN MEMORY. Quote Link to comment Share on other sites More sharing options...
phaeron Posted April 27, 2017 Share Posted April 27, 2017 The R: device might not be able to handle this, but the mechanism is still useful in the case that the computer restarts or is power cycled as it allows the 850 to recover and stop using the SIO bus. 2 Quote Link to comment Share on other sites More sharing options...
w1k Posted May 20, 2017 Share Posted May 20, 2017 any news? Quote Link to comment Share on other sites More sharing options...
TheMontezuma Posted May 20, 2017 Share Posted May 20, 2017 We have to spend more time in order to make the software well protected against ransomware 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 2, 2017 Share Posted November 2, 2017 I think this will progress much more quickly as the serial and control line protocol reveals themselves and further their understanding 1 Quote Link to comment Share on other sites More sharing options...
w1k Posted November 4, 2017 Share Posted November 4, 2017 when will be this finished? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted November 4, 2017 Share Posted November 4, 2017 when will be this finished? Feel free to write some code and submit it to the Github repository. 3 Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted November 10, 2017 Share Posted November 10, 2017 This is excellent people, glad you are doing this. As much as I love APE, this not only brings RESPEQT in line with it.. it surpasses it with the ability to write to a shared folder. I do use the R: handler from APE as my way to get online with my 8-bit, and would use it if I was to run a bbs with it. But I am a caller of BBSs not a host.. so this is excellent. Really for me the last and only reason I do not use RespeQT over APE. Thank you all for your work, great to see hobbiest enjoying their hobby. James 2 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 19, 2018 Share Posted February 19, 2018 Did this ever get done ? -Thom Quote Link to comment Share on other sites More sharing options...
w1k Posted February 20, 2018 Share Posted February 20, 2018 death project Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted February 20, 2018 Share Posted February 20, 2018 Did this ever get done ? -Thom I gather JoeyZ has moved on in his interests and no one else has picked up the baton. Quote Link to comment Share on other sites More sharing options...
TheMontezuma Posted February 21, 2018 Share Posted February 21, 2018 I'm actually interested in doing that, but my long TO DO list hinders me... 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted June 19, 2019 Share Posted June 19, 2019 bump :) Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted June 19, 2019 Share Posted June 19, 2019 5 minutes ago, _The Doctor__ said: bump Good luck. Since @JoSch got in a huff and quit the forum, and with @Joey Z busy with other interests in life, I don't guess anyone is doing much very actively with RespeQt anymore. Maybe @ebiguy or @TheMontezuma will pick up the torch, but I'm not holding my breath. Quote Link to comment Share on other sites More sharing options...
w1k Posted February 13, 2022 Share Posted February 13, 2022 im interested:) Quote Link to comment Share on other sites More sharing options...
