Ultimate Cart (SD multicart) info & bits
55 replies to this topic
#26 GyroX OFFLINE
GyroX
    Combat Commando
  • 3 posts
Posted Wed Oct 12, 2016 12:41 PM
.atr is not compatible for software thecartstudio or maxflash software?
#27 Justin Payne OFFLINE
Justin Payne
    Dragonstomper
  • 808 posts
  • Busy updating XEGS Podcast website to Angular6
Posted Sat Nov 19, 2016 4:58 PM
Hmm... I am going to try and make sure to use actual rom dumps and then .car header them.... then the Ult SD cart will really shine and show off what it can do!
I'm in need of fixing Summer Games (Cart version) for the UCart. Can you point me to some info on how to fix the headers?
#28 rdea6 OFFLINE
rdea6
  • 2,723 posts
Posted Sat Nov 19, 2016 6:48 PM
I believe that SG is an XEGS-SWITCHABLE 64k Cart.  So when using the rom 2 cart utility verify that you select the proper selection.  Or your rom may be bad and you need to get another.
#29 billkendrick OFFLINE
billkendrick
    Chopper Commander
  • 120 posts
Posted Sun Nov 20, 2016 1:36 AM
Michael asked me what firmware I have on my Ultimate Cart. I assume "the latest", since MacRorie just built it, and when I noticed the JTAG port on the back, he said "I can flash it when a new version comes out, if you want" (I'm fortunate to live about 15-20min away, though :) )
However, the menu program that comes up when I boot with the cart installed doesn't actually say!  Is there a way to tell?
Further, I noticed in Flashjazzcat's review of the Ultimate SD (sounds like he rewrote the menu program for Electrotrains) that you can drop a "_boot.rom" on your SD card, and the Ultimate Cart will boot the Atari into that, instead of the menu program built into the firmware.  That's cool!  Though my initial thought was "save a game as that file!", but that didn't work.  Reading further, I guess I'm not surprised, since the firmware running on the FPGA maps some data into the ROM that the Atari uses (list of files on the SD card, etc.)  Probably not something Pac-Man would appreciate, for example ;)
Are there any alternate menu ROMs out there to play with, or a way to sign up as a beta tester?  (Sounds like simply dropping a file on the SD card to test, and deleting when you're done, is all that's needed, so seems safe enough.)
So long story short: (1) is there a way to tell what firmware's running on the Ultimate Cart (I suppose, does the firmware make it visible to the menu program?), and (2) can I play with other menu ROMs? :)
#30 flashjazzcat ONLINE
flashjazzcat
  • 13,756 posts
Posted Sun Nov 20, 2016 4:04 AM
If the menu loads XEX files, you're up to date. What features are lacking in the existing menu?
#31 _The Doctor__ ONLINE
_The Doctor__
  • 4,814 posts
Posted Thu Dec 15, 2016 6:49 PM
I always have the super sparta x cart in the computer these days and have notices that using the ultimate carts xex loader fails when using the cold /c command and the car commands as well.... It will load roms all day long no matter which way I enter but fails when using ult cart xex loader... of course the ult cart xex loader works when just the ult cart is in all by itself
Edited by _The Doctor__, Thu Dec 15, 2016 6:50 PM.
#32 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 296 posts
Posted Fri Dec 16, 2016 3:46 AM
The XEX loader on the cartridge uses the $D5xx window to spool bytes from the XEX file to the XEX loader on the Atari itself. So while the XEX loader is running, the atari will be reading from the entire $D5xx range, and writing to $D500+$D501 to request the next file chunk.
Since Sparta dos also reacts to reads in $D5xx, its probably getting enabled/disabled by the XEX loader on the atari. I don't use sparta dos, so I haven't tested this kind of configuration... its possible that FJC can add more...?
One solution might be to recode the XEX loader on the ultimate cart to only use half of the $D500 range - that would keep it free of the range used by spata dos.
Robin
#33 flashjazzcat ONLINE
flashjazzcat
  • 13,756 posts
Posted Fri Dec 16, 2016 3:54 AM
Sounds like there's a cart ROM in the way. The super SDX cart uses the SIDE2 banking ($D5E1 IIRC).
#34 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 296 posts
Posted Fri Dec 16, 2016 4:13 AM
What car type is super SDX? I can't find it on the cart.txt master list.
If super SDX switches itself on/off in response to a READ of $D5E1, that's probably the problem, since the XEX loader will access this location. If it requires a WRITE, it should be ok.
Either way (unless I'm missing something), why not just run SDX from the ultimate cart, rather than have 2 cartridges plugged in?
EDIT - probably the RTC is why you'd rather use this cartridge.
Robin
Edited by electrotrains, Fri Dec 16, 2016 4:15 AM.
#35 _The Doctor__ ONLINE
_The Doctor__
  • 4,814 posts
Posted Fri Dec 16, 2016 4:20 AM
super sparta dos x cart has real time clock built in, passes thru to the express cart and that passes thru to ultimate sd cart.... to the best of my knowledge ult cart does not allow stacked rom images to be actively swapped as the icd / oss / orion / fte stacked carts do. The carts pass control to each other so we don't have yank them out etc. just leave them all in and pop in and out of them at will, no reset needed not plugging and unplugging needed.
Edited by _The Doctor__, Fri Dec 16, 2016 4:23 AM.
#36 flashjazzcat ONLINE
flashjazzcat
  • 13,756 posts
Posted Fri Dec 16, 2016 6:56 AM
Since there's no technical info on the vendor's page I had to search for photos to remind myself what the board which fits in the original shell actually has on it. There's a 512KB flash ROM (so, 64x8KB banks), and I seem to recall it using SIDE2 banking. Can't test here anyway, since I don't own a Super SDX cart.
Edited by flashjazzcat, Fri Dec 16, 2016 6:57 AM.
#37 _The Doctor__ ONLINE
_The Doctor__
  • 4,814 posts
Posted Fri Dec 16, 2016 7:06 PM
what were the original banking addresses for the ICD/OSS/Orion et al line anyway.. I just don't remember... wonder if it's on the jindroush archive... or someone here can just rattle them off all the same or slightly different?
Edited by _The Doctor__, Fri Dec 16, 2016 7:07 PM.
#38 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 296 posts
Posted Sat Dec 17, 2016 12:33 AM
I used the cart.txt file when developing the Ultimate Cart. There are several different versions of it, but here's one of them:
http://ftp.pigwa.net... Maker/cart.txt
#39 ascrnet OFFLINE
ascrnet
    Chopper Commander
  • 162 posts
Posted Fri Dec 30, 2016 7:31 PM
Hi all,
I want to run the following cartridges that are in .BIN format that work in ALTIRRA as 64 KB Williams.
But in the Ultimate Cart does not recognize them and if they change the extension to .ROM they do not work. :?
Attached File  Prisma.zip   293.13KB   92 downloads
Regards
#40 lbaeza ONLINE
lbaeza
    Moonsweeper
  • 499 posts
  • Former NRXA8-staff
Posted Fri Dec 30, 2016 7:44 PM
Ascrnet
You don't have to rename the binary file, you have to convert it from BIN to CAR.
I used this webpage to convert it: http://atariage.com/...to-car-utility/
Regards,
Louis BQ
#41 Kyle22 OFFLINE
Kyle22
  • 3,509 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Fri Dec 30, 2016 7:49 PM
You can also use Altirra. Attach Cartridge, Save Firmware->Save Cartridge.
#42 ascrnet OFFLINE
ascrnet
    Chopper Commander
  • 162 posts
Posted Sat Dec 31, 2016 10:25 AM
Thanks for the info lbaeza and Kyle22, will prove the next year :-D
Regards
#43 ryanmercer OFFLINE
ryanmercer
    Moonsweeper
  • 430 posts
Posted Thu Feb 9, 2017 7:10 AM
Thanks for this thread!!!
#44 tjlazer OFFLINE
tjlazer
  • 2,014 posts
  • Retro Atari Addict
Posted Thu Feb 9, 2017 10:25 AM
Ascrnet
Regards,
Louis BQ
Not entirely true, all the 8k and 16k carts and even some of the 64k and 128k (XEGS) seem to work fine with them being the original ROM dump.(.ROM, not .BIN)  (Some don't so will need to be converted)  But if any don't work, doing the conversion to .CAR will do the trick.  I had to do that for the Atarimax carts and some switchable XEGS carts.
Edited by tjlazer, Thu Feb 9, 2017 10:25 AM.
#45 _The Doctor__ ONLINE
_The Doctor__
  • 4,814 posts
Posted Sun Dec 31, 2017 9:17 PM
Jon, how much do I need to pay you to modify the xex loader so I can use this stacked on the Sparta X, Super Sparta X, Orion Express Carts, et al?
I mean you could do it just for me, or you could do it just because it would be incredibly cool, or you could do it so it might work with your GUI cart of the future or.... :)
#46 Kyle22 OFFLINE
Kyle22
  • 3,509 posts
Posted Sun Jan 7, 2018 8:37 PM
That would indeed be a very cool feature, but I believe that would be dependent on the CPLD code more than the Loader menu.
#47 SS OFFLINE
SS
  • 6,032 posts
Posted Mon Jan 8, 2018 9:48 PM
Here's my entire Ultimate Cart, if anyone is interested.
#48 MacRorie OFFLINE
MacRorie
    Dragonstomper
  • 921 posts
  • No matter where you go, there you are.
Posted Wed Jan 10, 2018 12:22 PM
Why not just load up the AtariMax 1Mb version of SDX?  I use that to test all of the R-Time8 replacement carts I sell.  Works wonderfully.
#49 _The Doctor__ ONLINE
_The Doctor__
  • 4,814 posts
Posted Wed Jan 10, 2018 1:46 PM
Not what I am getting at.... the ultimate cart is plugged in to the top of the stack to save space I use the combined super sparta cart on some of the Atari's as it's time clock is built in, I then have whatever I want on top of that....I switch in and out of the ultimate sd cart on top of that stack, but it's XEX loader won't pass thru because it uses the whole range... it can use a smaller range and still do it's job on xex loading, I would never have to take apart the stack and have it all at my fingertips... I don't have to keeps re selecting stuff, just set it and forget it... or pick whatever and go...... no need to plug and unplug the stack ever.. no need to power cycle the Atari...
Edited by _The Doctor__, Wed Jan 10, 2018 1:49 PM.
#50 flashjazzcat ONLINE
flashjazzcat
  • 13,756 posts
Posted Wed Jan 10, 2018 1:48 PM
Yep: see Robin.
