FPGA Based Videogame System
FPGA
3374 replies to this topic
Poll: Interest in an FPGA Videogame System (448 member(s) have cast votes)
I would pay....
  1. > $100 (37 votes [8.26%] - View)
    Percentage of vote: 8.26%
  2. $100-149 (61 votes [13.62%] - View)
    Percentage of vote: 13.62%
  3. $150-199 (135 votes [30.13%] - View)
    Percentage of vote: 30.13%
  4. $200-299 (125 votes [27.90%] - View)
    Percentage of vote: 27.90%
  5. Sky's the Limit (90 votes [20.09%] - View)
    Percentage of vote: 20.09%
I Would Like Support for...
  1. 8 bit era games (381 votes [46.29%] - View)
    Percentage of vote: 46.29%
  2. 16 bit era games (374 votes [45.44%] - View)
    Percentage of vote: 45.44%
  3. Blip (68 votes [8.26%] - View)
Games Should Run From...
  1. SD Card / USB Memory Sticks (389 votes [54.79%] - View)
    Percentage of vote: 54.79%
  2. Original Cartridges (284 votes [40.00%] - View)
    Percentage of vote: 40.00%
  3. Hopes and Dreams (37 votes [5.21%] - View)
    Percentage of vote: 5.21%
The Video Inteface Should be...
  1. RGB (170 votes [18.66%] - View)
    Percentage of vote: 18.66%
  2. Composite (149 votes [16.36%] - View)
    Percentage of vote: 16.36%
  3. S-video (84 votes [9.22%] - View)
    Percentage of vote: 9.22%
  4. Component (120 votes [13.17%] - View)
    Percentage of vote: 13.17%
  5. HDMI (388 votes [42.59%] - View)
    Percentage of vote: 42.59%
Vote Guests cannot vote
#3351 11numbers OFFLINE
11numbers
    Combat Commando
  • 2 posts
Posted Tue Aug 8, 2017 6:01 PM
For absolutely no reason I took a pic of the three nt units I have.  1 original (the purple) and the 2 minis.  I forgot the bare aluminum mini in the pic though.
Are those anodized?  I have been thinking about getting mine powder coated.
#3352 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 14,953 posts
Posted Tue Aug 8, 2017 7:53 PM
Let us know how that goes... :grin:
#3353 kevtris OFFLINE
kevtris
    Moonsweeper
  • 456 posts
  • FPGA Whisperer
Posted Tue Aug 8, 2017 8:36 PM
yeah the nt mini and original are anodized.  These are just special versions made just for me for doing the project so they are unique.
#3354 ccovell OFFLINE
ccovell
    Space Invader
  • 16 posts
Posted Thu Aug 10, 2017 9:26 AM
Kevin, this is apropos of nothing, but would it be possible to make your Mandelbrot generator work on the NT mini?
#3355 Tusecsy OFFLINE
Tusecsy
    Star Raider
  • 94 posts
Posted Thu Aug 10, 2017 12:35 PM
Is there any reason to keep the NT Mini when the SNES version comes out?  I assume it would do the NES and jailbreaks too??
Ya the minute it gets announced I'm ebaying my NT Mini that's for sure.  Seems like a no brainer.  A simple controller adapter would solve the SNES only controller problem.
#3356 kevtris OFFLINE
kevtris
    Moonsweeper
  • 456 posts
  • FPGA Whisperer
Posted Thu Aug 10, 2017 4:23 PM
Unfortunately, the FPGA on there doesn't have many multipliers, and I used them all up so I can't port it.
#3357 ccovell OFFLINE
ccovell
    Space Invader
  • 16 posts
Posted Thu Aug 10, 2017 4:30 PM
Fixed-point math and lookup tables, c'mon.
Nah, I joke.  I guess you used a really beefy FPGA for that one, and it was just an experiment, right?
#3358 kevtris OFFLINE
kevtris
    Moonsweeper
  • 456 posts
  • FPGA Whisperer
Posted Thu Aug 10, 2017 9:15 PM
this was my big complaint with the cyclone V.  the part I used (a cyclone III) had the same logic resources approximately, but a lot more multipliers.  It was the 25K LE model C3, and the C5 is approximately the same.  Interestingly the chip used on the ntm has 50K LEs about and 66 DSP units (multipliers) but for the A2 part I used, half the resources are not available.  They are on the die but the compiler will not assign them because you didn't pay for them.   I ran out of multipliers on the NES core and had to start converting some multipliers into bogo-multipliers, i.e. repeated shifting and adding or accumulation depending on the size.  The video scaler stuff eats up nearly all of the multipliers between the HQX stuff and all the analog video mode things (composite, s-vid, component, etc).
The chip I did the mandelbrot on originally had no scaling of any kind and output RGB directly so I could use all of the resources for the mandelbrot.  It had 7 rendering units running in parallel.   I kind of want to revisit that project some time though and redo how the iterations were done to make it more efficient.  Also I wanted to get a vastly higher resolution than 256*240 of the original.  So it might show up one day on the ntm in some other format, like a very limited version that has no scaling and might be analog only or digital only output.  We'll see.
#3359 TokyoBatman OFFLINE
TokyoBatman
    Combat Commando
  • 7 posts
Posted Fri Aug 11, 2017 12:46 AM
Kevtris,
Is the gamate core possible on the nt mini? If so, how hard would it be to get it going?
And is it possible to do the NES overclock ppu feature on the nt mini to run NES games without lag?
Thanks!
#3360 kevtris OFFLINE
kevtris
    Moonsweeper
  • 456 posts
  • FPGA Whisperer
Posted Fri Aug 11, 2017 12:50 AM
Kevtris,
Thanks!
Gamate is already on it.  no I am not handling CPU overclocking because it shares a clock domain with the video.
#3361 TokyoBatman OFFLINE
TokyoBatman
    Combat Commando
  • 7 posts
Posted Fri Aug 11, 2017 1:17 AM
Thanks for the quick response!  I'm thinking hard about my finances and getting a NT mini.
Is it possible to have some sort of controller mapper for the NT Mini?
#3362 atmn OFFLINE
atmn
    Chopper Commander
  • 111 posts
Posted Fri Aug 11, 2017 2:36 AM
Noticed this on the Everdrives forum.
http://krikzz.com/fo...p?topic=6645.30
Krikzz everdrive N8 cant run big games, in this case 16Mbit, the maker of the awesome Zelda and Mario hacks that require bigger memory and a fully featured MMC5 mapper support wont do anything to be able to support this.
I belive Kevtris said that there is no use to make another romcart since there is Powepak and Everdrive. I think it is use for another romcart. There is no other MMC5 support like the ones Kevtris implemented in the Nt mini, that runs the Legend of link flawlessly. Kevtris have the best library of mapper support for the NES, even VRC7, which is incredible to support just for 1? game.
I want a Kevtris-NES-everdrive-powerpak-thingy! :) Would say people would buy it if the price was under 200$.
#3363 Greg2600 OFFLINE
Greg2600
  • 2,752 posts
Posted Fri Aug 11, 2017 8:10 AM
Perhaps the hack makers should have done so within the contemporary limits of the NES?  Just sayin....
#3364 atmn OFFLINE
atmn
    Chopper Commander
  • 111 posts
Posted Fri Aug 11, 2017 10:25 AM
The primary thing is that the MMC5 mapper are poorly implemented on the current flashcarts, its just made to run CV3.
Theese hacks runs fine with real MMC5 chips on real hardware. The hack are for sure within limits of NES capability. Games like that wasnt made back in the days cause the cost should be to high.
Kevtris mapper support are far beyond current flashcarts imo.
#3365 derFunkenstein ONLINE
derFunkenstein
    Space Invader
  • 49 posts
Posted Fri Aug 11, 2017 10:34 AM
So a jailbroken NT Mini should run it, since it can load ROMs off the SD, right? Or am I missing something, like MMC5 emulation support in the jailbroken firmware...
#3366 atmn OFFLINE
atmn
    Chopper Commander
  • 111 posts
Posted Fri Aug 11, 2017 2:31 PM
Yes, it runs perfectly. That is what I mean. The MMC5 support goes beyond CV3 in the jailbroken Nt Mini. This mapper support and support for bigger roms in a flashcart to be able to run on any NES would be neat.
#3367 derFunkenstein ONLINE
derFunkenstein
    Space Invader
  • 49 posts
Posted Fri Aug 11, 2017 2:33 PM
OK I gotcha now. My bad. Reading is fundamental. lol
I didn't realize that mapper support in the Everdrive N8 (which is how I play, in OG hardware) was lacking in places. It'd definitely be a cool bonus to run home-brew that needs it like that.
#3368 atmn OFFLINE
atmn
    Chopper Commander
  • 111 posts
Posted Fri Aug 11, 2017 2:50 PM
Ye. Its far from perfect in current flashcarts. And, if a hack runs fine with the original MMC5 chip as it does on the repos. Its not the hack that is the problem, its the implementation of the mapper.
I got the Nt mini so I'm not complaing, but Im just saying there is alot of people thats willing to pay good money for a ZimbaPak N8  ;)
#3369 Wolf_ OFFLINE
Wolf_
    Chopper Commander
  • 163 posts
Posted Fri Aug 11, 2017 3:04 PM
So I've looked at the user manual and these are all the shortcut keys it lists:
Select + Down = menu
Select + A = Power on/off
Select + up = Reset Game
Select + Right = Video Switch
hold up while powering up = analog video menu
hold down while powering up = controller test menu
hold start while powering up = reset nt mini settings to default
Am I missing something or is there no way to easily change the settings of your mini while a game is on/resume that game after you have changed them? I was trying out some nes palettes (neat update the the custom palettes you can apply will be available in the next Smokemonster pack update) and it was a real chore, as was changing the video settings. The only way I could find a way to do it was by using the code to turn the nt mini off, changing the settings, then loading the core I wanted and finding the game all over again.
Edited by Wolf_, Fri Aug 11, 2017 3:05 PM.
#3370 Greg2600 OFFLINE
Greg2600
  • 2,752 posts
Posted Fri Aug 11, 2017 3:09 PM
My point is that such games would never have existed during the run of the system.  To me, it's verging on the concept of the OpCode SGM or 7800XM or IntelliXpander or similar.  Like building a hot rod out of a '57 Chevy.  Sure, you have something really cool and fun, but it's not really "original" or true to the design of the system.  So to expect the current flash carts to support hacks like that are unlikely.
#3371 Wolf_ OFFLINE
Wolf_
    Chopper Commander
  • 163 posts
Posted Fri Aug 11, 2017 3:17 PM
I'm sure that the vast majority of people are unaware of flash carts (or at least unaware of them being good), or don't care because they strictly emulate. I doubt the concern someone might want to play their rom on original hardware ever entered their minds.
#3372 kevtris OFFLINE
kevtris
    Moonsweeper
  • 456 posts
  • FPGA Whisperer
Posted Fri Aug 11, 2017 3:18 PM
select+down to go into the menu, then hit start to bring up the settings stuff, which varies by core.
#3373 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 14,953 posts
Posted Sun Aug 13, 2017 12:08 AM
Would like to see this on the Zimba3000. I consider myself a fractal geek so would be fun to play around with.
Bignum calculations would be super duper fast on an FPGA. The speed increase from 32-bit to 64-bit big-num integer maths is 400% on the same x86-64 class CPU. If you created say a 256-bit, or even possobly 1024-bit RISC CPU that basically does square and add repeatedly, then replicated your core until it filled the FPGA die, clocked at a couple hundred megahertz or whatever the max speed is for the FPGA, it would do laps around my AMD bulldozer (FX-8150 O.C. to 4.2Ghz). A slower 1024-bit CPU with less cores for really super duper deep stuff, and a faster 128 or 256-bit CPU for lighter zoom depths. Or you know, just dynamically scale the precision on the CPU to whatever depth you needed.
FPGAs should be far more efficient at massively parallel simple operations compared to traditional CISC CPUs like x86. Let me know if you want some alternate formulas for fratcals, Burning Ship, Celtic, Mandelbar, Perpendicular, Buffalo, etc. I catalogued a bunch of ABS() Mandelbrot variants in 2nd, 3rd, 4th, and 5th orders. Here's my 2nd and 3rd formula sheets:
https://stardust4eve...mulas-487039852
https://stardust4eve...plete-487039945
#3374 kevtris OFFLINE
kevtris
    Moonsweeper
  • 456 posts
  • FPGA Whisperer
Posted Sun Aug 13, 2017 12:22 AM
FPGAs should be far more efficient at massively parallel simple operations compared to traditional CISC CPUs like x86. Let me know if you want some alternate formulas for fratcals, Burning Ship, Celtic, Mandelbar, Perpendicular, Buffalo, etc. I catalogued a bunch of ABS() Mandelbrot variants in 2nd, 3rd, 4th, and 5th orders...
The one I made had 7 cores running at 90MHz, doing 3 multiplies at a time.  Each multiply is 36*36 bits giving a 72 bit product.  So that's 21 multiplies/clock at 90MHz or or 1.8 billion multiplies/second.   One thing I found super interesting is when the clock was too high, the output glitched.  But the glitches were fractal in nature, and made up of interesting loops and curls.    I did a total of 256 iterations and used a table LUT to palette entry.
After 7 cores, no more would fit because it was trying to generate them using logic elements.  This killed the clock rate, too.
Each core handled 1/7th of the screen which wasn't the most efficient.  A better method would be to render each scanline individually on the cores as they finish.  This would prevent idle cores which was a problem on the current implementation.
For a hypothetical newer implementation, I would pipeline the processing so that the clock can go a lot higher than it does now and possibly add more iterations.
#3375 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 14,953 posts
Posted Sun Aug 13, 2017 1:19 AM
What a fucking waste of die space... :roll:
Yeah at 256 max iterations it would be limited utility if still fun to explore. My zoom videos typically got to 2^-1000 (E-300) or beyond... :P
Also tagged with one or more of these keywords: FPGA
