FPGA Based Videogame System
FPGA
12276 replies to this topic
Poll: Interest in an FPGA Videogame System (591 member(s) have cast votes)
I would pay....
  1. > $100 (47 votes [7.95%] - View)
    Percentage of vote: 7.95%
  2. $100-149 (76 votes [12.86%] - View)
    Percentage of vote: 12.86%
  3. $150-199 (171 votes [28.93%] - View)
    Percentage of vote: 28.93%
  4. $200-299 (166 votes [28.09%] - View)
    Percentage of vote: 28.09%
  5. Sky's the Limit (131 votes [22.17%] - View)
    Percentage of vote: 22.17%
I Would Like Support for...
  1. 8 bit era games (486 votes [45.51%] - View)
    Percentage of vote: 45.51%
  2. 16 bit era games (501 votes [46.91%] - View)
    Percentage of vote: 46.91%
  3. Blip (81 votes [7.58%] - View)
    Percentage of vote: 7.58%
Games Should Run From...
  1. SD Card / USB Memory Sticks (513 votes [54.11%] - View)
    Percentage of vote: 54.11%
  2. Original Cartridges (382 votes [40.30%] - View)
    Percentage of vote: 40.30%
  3. Hopes and Dreams (53 votes [5.59%] - View)
    Percentage of vote: 5.59%
The Video Inteface Should be...
  1. RGB (228 votes [19.26%] - View)
    Percentage of vote: 19.26%
  2. Composite (177 votes [14.95%] - View)
    Percentage of vote: 14.95%
  3. S-video (109 votes [9.21%] - View)
    Percentage of vote: 9.21%
  4. Component (153 votes [12.92%] - View)
    Percentage of vote: 12.92%
  5. HDMI (517 votes [43.67%] - View)
    Percentage of vote: 43.67%
Vote Guests cannot vote
#4226 RadikusRLZ OFFLINE
RadikusRLZ
    Star Raider
  • 71 posts
Posted Sun Nov 5, 2017 12:48 AM
By the way, I just macgyvered my own shitty looking composite adapter and an RGB cable with some parts I had lying around for the heck of it.
Regarding the person who claimed composite PAL output had problems, I did run into something odd myself as well.
I first tried composite NTSC on both my PVM and modern LCD and both displayed everything perfectly fine.
When I tried composite PAL though, my PVM had no problems but my european modern LCD (which supports both NTSC and PAL) displayed this:
It does almost look like if NTSC was displayed in PAL with the colors missing but I doubt that's it. Anyone's got a clue what that could be about?
PAL composite working good Jailbreak Firmware version 1.7 and older
#4227 bikerspade OFFLINE
bikerspade
    Star Raider
  • 68 posts
Posted Sun Nov 5, 2017 7:45 AM
I also have the same serial number issue with the NT Mini that I received recently.
#4228 RadikusRLZ OFFLINE
RadikusRLZ
    Star Raider
  • 71 posts
Posted Sun Nov 5, 2017 8:18 AM
This is hardware problem, you have to send it back to the  Analogue for warranty service
#4229 DadsGlasses OFFLINE
DadsGlasses
    Chopper Commander
  • 184 posts
Posted Sun Nov 5, 2017 8:38 AM
What is the problem, other than wrong serial number?
#4230 RadikusRLZ OFFLINE
RadikusRLZ
    Star Raider
  • 71 posts
Posted Sun Nov 5, 2017 9:26 AM
Never heard this kind of problem of First Edition Mini and now Second Edition have this serial number problem, I think this is some kind of hardware problem and not software problem. Maybe you have to ask Analogue for that or maybe Kevtris is better to answer this question.
#4231 bikerspade OFFLINE
bikerspade
    Star Raider
  • 68 posts
Posted Sun Nov 5, 2017 10:48 AM
I've heard many people have had this issue, hard to believe that it's a hardware issue affecting so many units. So far the console has been working great still running on stock firmware (both hdmi and component/composite tested to work as expected, works perfectly with my FDS RAM Adapter w/FDSStick). I sent an email to Analogue support.
#4232 RadikusRLZ OFFLINE
RadikusRLZ
    Star Raider
  • 71 posts
Posted Sun Nov 5, 2017 11:04 AM
Yes, stock firmware also working good, no PAL composite problems. But there was also bunch of NES Everdrives that was faulty some time ago , so why not same happen to this also...
#4233 bikerspade OFFLINE
bikerspade
    Star Raider
  • 68 posts
Posted Sun Nov 5, 2017 1:23 PM
Here is the reply from Analogue:
Just a minor firmware reinstall / update should clear that right up. All materials for doing so can be found here:
https://support.anal...are-Update-v2-3
#4234 RadikusRLZ OFFLINE
RadikusRLZ
    Star Raider
  • 71 posts
Posted Sun Nov 5, 2017 1:45 PM
IT IS NOT SOFTWARE PROBLEM IT IS HARDWARE PROBLEM
#4235 DadsGlasses OFFLINE
DadsGlasses
    Chopper Commander
  • 184 posts
Posted Sun Nov 5, 2017 1:48 PM
1. What makes you so sure this is a hardware problem and not software?
2. What about this is actually a "problem"?
#4236 pcfreak324 OFFLINE
pcfreak324
    Combat Commando
  • 8 posts
Posted Sun Nov 5, 2017 1:53 PM
I'm finding that none of the PlayChoice-10 Arcade files in SmokeMonster's NT Mini pack are working for me. "File Size Mismatch" and then I get a black screen.
Any ideas?
This error is related to the file size of the games.
When you try to load a rom, the Analogue Nt mini reads the iNES header and checks if the file size matches with the data specified in the header. If this is not the case, the Analogue Nt mini will not load the game.
You need to fix the roms. Open them with NESHead (https://www.romhacki.../utilities/665/) which will tell you what the expected file size is. Then, use a hex editor and remove/add the required number of empty bytes at the end of the rom.
Edited by pcfreak324, Sun Nov 5, 2017 1:53 PM.
#4237 RadikusRLZ OFFLINE
RadikusRLZ
    Star Raider
  • 71 posts
Posted Sun Nov 5, 2017 2:02 PM
This problem
No problem first edition Nt mini, only second edition problem, not help If you update firmware. Bad quantity of second edition minis
#4238 DadsGlasses OFFLINE
DadsGlasses
    Chopper Commander
  • 184 posts
Posted Sun Nov 5, 2017 2:15 PM
This problem
Repeat: What about this makes you think it's a "problem"? Have you seen any behavior from the unit other than serial number? Any performance issues?
#4239 RadikusRLZ OFFLINE
RadikusRLZ
    Star Raider
  • 71 posts
Posted Sun Nov 5, 2017 2:35 PM
Som
Also scaling problems, can you send me pictures of your nt mini motherboard so we see what is problem there
#4240 DadsGlasses OFFLINE
DadsGlasses
    Chopper Commander
  • 184 posts
Posted Sun Nov 5, 2017 2:39 PM
SomAlso scaling problems, can you send me pictures of your nt mini motherboard so we see what is problem there
My NT Mini is functioning as it should. I have no reason to open the casing in order to photograph the motherboard.
What "scaling problems" have you viewed that are associated with the serial number "problem"?
#4241 RadikusRLZ OFFLINE
RadikusRLZ
    Star Raider
  • 71 posts
Posted Sun Nov 5, 2017 2:44 PM
You have to read thread what other users have written, cannot help you without seeing the faulty motherboard, bad caps?
#4242 DadsGlasses OFFLINE
DadsGlasses
    Chopper Commander
  • 184 posts
Posted Sun Nov 5, 2017 2:52 PM
Ok thanks. I don't need help. My NT Mini is functioning as at should.
#4243 cacophony OFFLINE
cacophony
    Dragonstomper
  • 531 posts
Posted Sun Nov 5, 2017 4:14 PM
What thread are you talking about? Please link to something.
#4244 Great Hierophant OFFLINE
Great Hierophant
  • 1,590 posts
  • Scribbler
Posted Sun Nov 5, 2017 4:34 PM
Time for Part Four in the on-going series on the Nt Mini : Vs. System Support
The file referred to at the end of the blog entry is attached.
Edited by Great Hierophant, Sun Nov 5, 2017 4:35 PM.
#4245 Riptide OFFLINE
Riptide
    Chopper Commander
  • 116 posts
Posted Sun Nov 5, 2017 5:18 PM
Got my NT Mini in, thing is so sweet, specially the jailbroken firmware. Thanks so much for all your hard work Kevtris!
I have noticed a couple issues though. For one, it appears that all filters aside for hq2x and scale2x are broken and don't do anything, or at least don't make any discernable difference over hq2x or scale2x. This problem does not exist on my Hi-Def HDMI modded AV Famicom, you can easily see the difference between hq2x and hq3x and so forth. Not the case with the NT Mini, there seems to be no change at all when going from hq2x to hq3x and above, same thing for scale2x & 3x.
2nd issue I've noticed is the system is showing a serial # of 00000001. Have seen others mention this but no ideas why or solutions. Anyone know why that is happening?
Thanks for the help in advance :) Am so glad to hear that Analogue is going to continue to let Kevtris update the JB firmware and cores. I would think it would be smart of them to just make that firmware the official one and officially release cart & controller adapters for it.
Som Also scaling problems, can you send me pictures of your nt mini motherboard so we see what is problem there
The post RadikusRLZ is referring to is quoted first. I have a unit with the serial number issue and I'll give those hq2x/hq3x settings a try and see if I have an issue with them like Skins4thewin does. If the serial number problem is the only problem I'm fine with it, but if its only a symptom of something more then we may need to send these back to Analogue.
#4246 _omega_ OFFLINE
_omega_
    Space Invader
  • 12 posts
Posted Sun Nov 5, 2017 7:36 PM
OMG I hope this is the best troll ever. I'm dying.
#4247 Riptide OFFLINE
Riptide
    Chopper Commander
  • 116 posts
Posted Sun Nov 5, 2017 7:49 PM
I don't think he is trolling. A bunch of people have encountered the serial number issue. One of those people also has malfunctioning scalers. Its possible that some or all of the people with the serial number problem also have the scaler problem but haven't noticed yet since they haven't tried to use them. I can, however, disprove the "all" part of the previous statement, as my NT Mini has the serial number issue but appears to have no problems with any of the scalers. I hope these are unrelated problems.
#4248 kevtris OFFLINE
kevtris
    Dragonstomper
  • 735 posts
  • FPGA Whisperer
Posted Sun Nov 5, 2017 9:30 PM
The serial number issue shouldn't affect operation of any other aspect of the system.
#4249 Riptide OFFLINE
Riptide
    Chopper Commander
  • 116 posts
Posted Sun Nov 5, 2017 10:23 PM
Great, thank you.
#4250 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 18,390 posts
Posted Sun Nov 5, 2017 10:38 PM
No better way to shut up troll than straight from the designers mouth. Kudos. I don't think a couple digits displayed on a menu screen is any reason to return a console, especially with what they charge for shipping... :P
Also tagged with one or more of these keywords: FPGA
5 user(s) are browsing this forum
0 members, 5 guests, 0 anonymous users
