FPGA Based Videogame System
FPGA
10406 replies to this topic
Poll: Interest in an FPGA Videogame System (562 member(s) have cast votes)
I would pay....
  1. > $100 (46 votes [8.19%] - View)
    Percentage of vote: 8.19%
  2. $100-149 (73 votes [12.99%] - View)
    Percentage of vote: 12.99%
  3. $150-199 (161 votes [28.65%] - View)
    Percentage of vote: 28.65%
  4. $200-299 (159 votes [28.29%] - View)
    Percentage of vote: 28.29%
  5. Sky's the Limit (123 votes [21.89%] - View)
    Percentage of vote: 21.89%
I Would Like Support for...
  1. 8 bit era games (464 votes [45.49%] - View)
    Percentage of vote: 45.49%
  2. 16 bit era games (477 votes [46.76%] - View)
    Percentage of vote: 46.76%
  3. Blip (79 votes [7.75%] - View)
    Percentage of vote: 7.75%
Games Should Run From...
  1. SD Card / USB Memory Sticks (491 votes [54.43%] - View)
    Percentage of vote: 54.43%
  2. Original Cartridges (360 votes [39.91%] - View)
    Percentage of vote: 39.91%
  3. Hopes and Dreams (51 votes [5.65%] - View)
    Percentage of vote: 5.65%
The Video Inteface Should be...
  1. RGB (218 votes [19.24%] - View)
    Percentage of vote: 19.24%
  2. Composite (171 votes [15.09%] - View)
    Percentage of vote: 15.09%
  3. S-video (103 votes [9.09%] - View)
    Percentage of vote: 9.09%
  4. Component (148 votes [13.06%] - View)
    Percentage of vote: 13.06%
  5. HDMI (493 votes [43.51%] - View)
    Percentage of vote: 43.51%
Vote Guests cannot vote
#1451 Jimjans OFFLINE
Jimjans
    Space Invader
  • 48 posts
Posted Fri Feb 24, 2017 11:24 AM
@everyone
I have been experiencing issues with the 8bitdo controller that came with my Analog.
The controller will sometime not register inputs, and other times will go a direction for longer than the amount of time the direction was pressed.
This issue can mostly be detected when navigating a menu, but I have had times where the in game controls led to non-responsive movements too.
I have fully charged the game pad and re-synced it to the wireless dongle.
Anyone else having this issue? I would like to contact Analog or 8bitdo but I want to make sure its not the actual system.
Thanks!
Yes I got this problem to the dpad is awful on my nes30 I got a replacement but it was bad to .
When pushing the dpad it will register two inputs at the same time , for example when pushing up it will register up and right at the same time.
I have a sfc30 to from 8bitdo and that controller working as it should.
#1452 Kismet OFFLINE
Kismet
    Moonsweeper
  • 444 posts
Posted Fri Feb 24, 2017 2:39 PM
That almost sounds like a short on the controller board, but I don't have any of those 8bitdo controllers to reference. It's almost certain that the PCB's inside these are nearly identical to each other.
Take note of what the SFC30 controller PCB looks like
(source http://muchreviews.c...-snes-teardown/ )
8Bitdo-close-internal-1-e1452629149851-7
Also take note here:
http://forum.8bitdo....ad-446-1-1.html(8Bitdo D-Pad PCB Contacts Issue)
If you read the thread, it sounds like maybe the 8Bitdo is "supposed to" do this. Maybe get some input from a few more people with the controllers to see if maybe it's supposed to be that way?
#1453 cacophony OFFLINE
cacophony
    Moonsweeper
  • 428 posts
Posted Fri Feb 24, 2017 3:09 PM
On my NES30 controller if you press directly down it registers DOWN correctly, but the tiniest movement left or right will register DOWN-LEFT or DOWN-RIGHT, respectively. It makes games like Contra impossible to play because the difference between DOWN and DOWN-LEFT/RIGHT is the difference between ducking and standing. This causes the character to stand when you don't intend him to. Maybe I should try to exchange it?
Also, for some reason the only purpose of the custom Analogue firmware for the NES30 controller is to remove the turbo button functionality.
I really wish there was a way to enable turbo via the menu (similar to AVS), so that even a regular controller could do turbo. Some games really need it... I'm looking at you Silver Surfer!!!  :)
Edited by cacophony, Fri Feb 24, 2017 3:18 PM.
#1454 Namdor OFFLINE
Namdor
    Star Raider
  • 51 posts
Posted Fri Feb 24, 2017 3:18 PM
I really wish there was a way to enable turbo via the menu (similar to AVS), so that even a regular controller could take advantage of it.
I can't even beat the first level of contra because my guy constantly stands up when trying to crouch etc. Is this an issue with all of their nes style controllers? If not I need a refund as well!
#1455 Fafner OFFLINE
Fafner
    Star Raider
  • 75 posts
Posted Fri Feb 24, 2017 3:25 PM
Haven't had a bit of trouble with mine
#1456 cacophony OFFLINE
cacophony
    Moonsweeper
  • 428 posts
Posted Fri Feb 24, 2017 3:26 PM
Have you tried Contra? In many other games the issue is not noticeable.
#1457 Jimjans OFFLINE
Jimjans
    Space Invader
  • 48 posts
Posted Fri Feb 24, 2017 3:29 PM
Try the controller test push down when you start the console.
#1458 Jimjans OFFLINE
Jimjans
    Space Invader
  • 48 posts
Posted Fri Feb 24, 2017 3:36 PM
Tried a wiiu controller and a ds4 also and they do not have these problems, but the nes30 controller is useless ..
The advise after my complaint to analogue was use a orginal controller or a oem instead..
Edited by Jimjans, Fri Feb 24, 2017 3:38 PM.
#1459 Fafner OFFLINE
Fafner
    Star Raider
  • 75 posts
Posted Fri Feb 24, 2017 3:43 PM
Eeyup!
Played through the whole game!
#1460 cacophony OFFLINE
cacophony
    Moonsweeper
  • 428 posts
Posted Fri Feb 24, 2017 3:59 PM
Eeyup!
Looks like there's some variation with the NES30 then.
But to be honest, I think I still would prefer a wired controller due to the reduced lag. Zero lag one of the biggest benefits of using an FPGA, so adding lag back into the console chain (even if it's just a small amount) seems wrong. Plus it's nice not having to keep yet another controller charged.
Edited by cacophony, Fri Feb 24, 2017 4:06 PM.
#1461 Fafner OFFLINE
Fafner
    Star Raider
  • 75 posts
Posted Fri Feb 24, 2017 4:22 PM
I just tried again.
I think I see what you mean.
It can be touchy on the diagonal downs
#1462 kevtris OFFLINE
kevtris
    Dragonstomper
  • 682 posts
  • FPGA Whisperer
Posted Fri Feb 24, 2017 4:44 PM
It's that time again: New Firmware Friday! This time, I have added the Atari 2600 core. It is a very full featured core, able to run nearly anything.
It supports the following things:
2K non-bankswitched
2K with 1K of RAM (magicard, video life)
4K non-bankswitched
8K F8 normal bankswitching
8K F8 and superchip RAM
8K parker bros
8K tigervision
8K UA bankswitching
8K activision
10-11K pitfall 2 (DPC)
12K RAM+
16K F6 normal bankswitching
16K + superchip RAM
16K M-network
24K FA2
32K F4 normal bankswitching
32K F4 + superchip RAM
64K dynacom
It also supports some newer mappers:
tigervision + RAM (boulder dash)
econobanking
EF bankswitching
X07 bankswitching
superbanking
The Supercharger is fully supported, including the demo unit.
This core is extremely extensive, so please read the including readme in the 2600 directory. You will have to change the file extension on some games
to select the bankswitching mode for them.
There's partial atarivox support (speech).
http://blog.kevtris....re_verJB1.3.zip
Enjoy!
Oh yeah, I fixed a couple bugs in the NES core, too. Specifically mapper 163 so that pokemon yellow game now appears to be fully playable, and the pitch sweeps which should fix that test rom and punch out SFX.
#1463 theboy181 OFFLINE
theboy181
    Space Invader
  • 12 posts
Posted Fri Feb 24, 2017 4:51 PM
SWEEEEEEEETTTTT!!!! only the 2600,  such a tease.. I hope you removed the 7800 reference.. that was mean!!
#1464 roaringchicken OFFLINE
roaringchicken
    Space Invader
  • 19 posts
Posted Fri Feb 24, 2017 4:59 PM
Awesome, thanks so much kevtris!  Another great way to start the weekend.
#1465 rezb1t OFFLINE
rezb1t
    Star Raider
  • 79 posts
Posted Fri Feb 24, 2017 5:02 PM
Thank you very much kevtris! :) Another amazing update, as always!
#1466 genfuyung OFFLINE
genfuyung
    Chopper Commander
  • 103 posts
Posted Fri Feb 24, 2017 5:18 PM
2K non-bankswitched
4K non-bankswitched
8K parker bros
8K tigervision
8K UA bankswitching
8K activision
12K RAM+
16K + superchip RAM
16K M-network
24K FA2
64K dynacom
econobanking
EF bankswitching
X07 bankswitching
superbanking
Enjoy!
Those atarivox Bios files are very difficult to find.
#1467 kevtris OFFLINE
kevtris
    Dragonstomper
  • 682 posts
  • FPGA Whisperer
Posted Fri Feb 24, 2017 5:21 PM
Oh yeah, to head off the impending bug reports, the "rom hunter" 2600 ROM pack (which is what I used) has a lot of non-ASCII characters in the filenames. This causes the menu to show "funny" characters (like flashing ones). This is not a bug. This is more a wart.
I will fix this in the future by filtering those maybe. This is normal behavior though. If you want it fixed now you can edit the filenames. Examples would be Pele's soccer where the 'e' is an e with a doodad on top.
#1468 NE146 ONLINE
NE146
    Dumbass Atari Fan
  • 15,302 posts
Posted Fri Feb 24, 2017 5:32 PM
Man so what's the deal with the Mini NTs?  Still waiting for stock. :P
#1469 genfuyung OFFLINE
genfuyung
    Chopper Commander
  • 103 posts
Posted Fri Feb 24, 2017 5:34 PM
Same here. Nearly 2 weeks ago they said they would have more in 10 days. A few days ago they said they were just being taken off the ship. They're supposed to send out a newsletter stating when they'll be back but I still reload the page a few times a day in blind hope...
#1470 electristan OFFLINE
electristan
    Combat Commando
  • 3 posts
Posted Fri Feb 24, 2017 5:44 PM
Thanks again Kevtris!
So happy i got this just before they ran out of stock :) have been playing and tweaking away now for two weeks happy as can be.
Never played much Atari 2600, looking to diving in.
#1471 Dweezicus OFFLINE
Dweezicus
    Space Invader
  • 17 posts
Posted Fri Feb 24, 2017 6:47 PM
@everyone
Thanks!
Seriously, FUCK 8Btido's controllers.  The d-pad is an absolute nightmare where you need to hold down or up (Castlevania, Contra, Mega-Man 3, Super Mario)  I scoured the internet looking for a fix, and even removed a d pad from an OEM NES Controller to swap with the NES30, and it actually made things worse.  What i finally figured out was that I could sync my Wii Remote with the Retro receiver and plug in a Classic controller.  The classic controller works flawlessly.  I tried plugging in an SNES controller through a Wii Remote adapter, but for some reason it won't recognize the select button when it's pushed.  I also tried hooking up an NES controller to my wii remote, but because the wii remote registers all external controllers as classic controllers, you can't play any games (as Classic Controllers/the Analogue NT use Y/B as the main inputs instead of A/B on the NES controller).  Also, I agree with the other posters talking about how Contra is unplayable with the NES30.  To all of you saying the NES30 is fine, try playing Contra and get back to us here at the forum.  Honestly, since I synced my wii remote with my NT Mini, I haven't touched my NES30(s) (I stupidly bought an extra one so I could have two wireless controllers).  Also, for the record, I was experiencing this same issue on my original NES long before I got my NT Mini, so it is not an Analogue problem, but an 8Bitdo hardware problem (their PCB contacts are bullshit)
@Kevtris
What do you recommend in terms of wireless controllers for the NES?
Edited by Dweezicus, Fri Feb 24, 2017 6:50 PM.
#1472 hyrulebr OFFLINE
hyrulebr
    Space Invader
  • 20 posts
Posted Fri Feb 24, 2017 7:29 PM
My life in gaming just release an in-depth NT mini review:
#1473 cacophony OFFLINE
cacophony
    Moonsweeper
  • 428 posts
Posted Fri Feb 24, 2017 8:17 PM
^^^^^ Most thorough Nt Mini review yet with a huge emphasis on the genius behind it all!!!
Edited by cacophony, Fri Feb 24, 2017 8:19 PM.
#1474 theboy181 OFFLINE
theboy181
    Space Invader
  • 12 posts
Posted Fri Feb 24, 2017 9:04 PM
Been Using my SPC30 8bitdo controller instead, and the up works way better than the NES30. Thanks for the recommendation!
The issue I'm having is more of a loss of BT connectivity.. I'm wondering if others are having these issues too. Since it happens on both the SPC30 and the NES30 I'm thinking that the issue is with the BT receiver connected to the NT-mini. Im going to see if its a voltage issue from the NT-mini by powering the thing with the USB cable, but I was wondering if any of you have updated the device, and saw improvements ?
#1475 xga OFFLINE
xga
    Combat Commando
  • 3 posts
Posted Fri Feb 24, 2017 9:13 PM
Hi Guys,
Does anyone know if it would be possible to add S/PDIF / TOSLINK support to the Analogue Nt Mini?  I'd be interested in using digital audio output with the Analogue Nt Mini's RGB output (not HDMI).
Also tagged with one or more of these keywords: FPGA
16 user(s) are browsing this forum
5 members, 11 guests, 0 anonymous users
