FPGA Based Videogame System
FPGA
11485 replies to this topic
Poll: Interest in an FPGA Videogame System (579 member(s) have cast votes)
I would pay....
  1. > $100 (46 votes [7.94%] - View)
    Percentage of vote: 7.94%
  2. $100-149 (74 votes [12.78%] - View)
    Percentage of vote: 12.78%
  3. $150-199 (167 votes [28.84%] - View)
    Percentage of vote: 28.84%
  4. $200-299 (164 votes [28.32%] - View)
    Percentage of vote: 28.32%
  5. Sky's the Limit (128 votes [22.11%] - View)
    Percentage of vote: 22.11%
I Would Like Support for...
  1. 8 bit era games (476 votes [45.42%] - View)
    Percentage of vote: 45.42%
  2. 16 bit era games (492 votes [46.95%] - View)
    Percentage of vote: 46.95%
  3. Blip (80 votes [7.63%] - View)
    Percentage of vote: 7.63%
Games Should Run From...
  1. SD Card / USB Memory Sticks (504 votes [54.31%] - View)
    Percentage of vote: 54.31%
  2. Original Cartridges (373 votes [40.19%] - View)
    Percentage of vote: 40.19%
  3. Hopes and Dreams (51 votes [5.50%] - View)
    Percentage of vote: 5.50%
The Video Inteface Should be...
  1. RGB (222 votes [19.09%] - View)
    Percentage of vote: 19.09%
  2. Composite (175 votes [15.05%] - View)
    Percentage of vote: 15.05%
  3. S-video (107 votes [9.20%] - View)
    Percentage of vote: 9.20%
  4. Component (151 votes [12.98%] - View)
    Percentage of vote: 12.98%
  5. HDMI (508 votes [43.68%] - View)
    Percentage of vote: 43.68%
Vote Guests cannot vote
#2401 Flangle OFFLINE
Flangle
    Space Invader
  • 18 posts
Posted Wed Mar 22, 2017 8:51 PM
As someone else pointed out, it's from JY company... but I have it because we found that logo hidden inside a game I had reverse engineered the mapper to (the infamous mapper 90) hidden in a bunch of the CHR banks of a game, but didn't know how to activate it for a long time.  It was so weird I had to use it as an avatar.  My avatar originally was the wrong colours.  Turns out, a button combo makes it activate, and thus we knew the correct palette finally which is what is now used in the avatar.
That is so freaking awesome, both to them burying it and for you to dig it up like pirate treasure.
All glory to Warren Robinette, the first easter egg hider.
Edited by Flangle, Wed Mar 22, 2017 8:53 PM.
#2402 NoKnownOrigin OFFLINE
NoKnownOrigin
    Space Invader
  • 18 posts
Posted Wed Mar 22, 2017 8:55 PM
first I have heard of this problem.  If it's a mac, they drop all sorts of extra/duplicate meta data files onto the SD card which made life difficult before- there's a hidden file for each file on the card sometimes.  I thought I got rid of those by hiding hidden files, but maybe there's something else there.  On a mac this problem might not be visible since the OS probably strips them out for display.  I couldn't repro the problem until I had someone zip up the contents of an SD card doing it, that's when I found all sorts of hidden dirs and files sprayed everywhere in the file system.  I might need an example dir with the problem zipped up (on a windows machine) to be able to find it.
Just FYI, for those that are on a Mac, there is a little utility called CleanEject that you can drag an SD card onto to remove all of these hidden files (.Trashes, .Spotlight-V100, .DS_Store, etc) and eject the disk. Very useful for any drive that you plan on using with systems which may or may not play nice with those files.
#2403 Sneakyturtleegg OFFLINE
Sneakyturtleegg
    Chopper Commander
  • 238 posts
Posted Wed Mar 22, 2017 10:32 PM
I've combed through this thread a few times now and don't believe this been brought up, but if it has already sorry in advance. I loaded a few ROMs into the NES folder on JB firmware ("1.8") and I see duplicate names in the list, e.g. there are 2 ROMs listed with the same name per ROM in the folder. I popped the SD card back in my PC to verify and to make sure there weren't any hidden files, etc. Any thoughts on what may be causing this?
I'm having the same problem too. I'm on a PC, JB firmware 1.8. In the NT Mini NES folders, I have duplicates of every game listed. They all play. The NES folders seem to be the only ones doing it right now.
#2404 phoenixdownita OFFLINE
phoenixdownita
  • 3,326 posts
Posted Wed Mar 22, 2017 10:54 PM
Maybe when kevtris split out one of the NES mapper from the main NES core to merge it with the secondary NES core he fumbled the FAT directory reader code.
He'll fix it in no time.
#2405 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 17,833 posts
Posted Thu Mar 23, 2017 12:21 AM
Windows does this too. The .DS_Store files on MacOS are like the thumbs.db files on Windows. There are hidden directories on Windows folders but "show hidden files" is not enough. You must also uncheck "hide protected operating system files" then the junk is visible. You can delete it after going through a prompt that asks you for admin privleges (and sometimes ask a password if your account have login) but it's a fruitless endeavor. As soon as you do anything in the directory, add, modify, delete files or simply open something, the hidden files are instantly regenerated. MacOS is similar I'm afraid. If you train your software to ignore any files with an "h" or "s" attribute, and also ignore any filename beginning with ".", then most of the Windows/MacOSX garbage should disappear. I would not hide files from view with the "a" (archive) or "r" (read only) attribute, because many software will edit these and some users manually add the read only attribute to protect files. Windows also auto sets read only whenever files are copied from read only media such as CD-ROM or locked SD card, which can be a pain later when doing bulk file management operations.
I don't know of a scrubber utility to bulk remove Mac/Win OS files, but I imagine it would be a pain. You would also need admin privleges in windows to remove windows files and likewise removing MacOS files on Mac. And again, merely inserting the SD card and viewing files without setting the write protect tab (which is pointless to do if you want to add stuff to it) and all the OS junk files come back.
#2406 snatcher1996 OFFLINE
snatcher1996
    Space Invader
  • 47 posts
Posted Thu Mar 23, 2017 2:52 AM
Hi kevtris,
wanted to chime in and congratulate you on your awesome work. Your jailbreak made a way too expensive luxury toy a must have for any retro enthusiast. I've been playing on my new NT mini for some days now and have had a blast doing so.
Here is one possible small bug I stumbled upon. On the Game Gear core, Castle of Illusion has weird colors and won't normally. I tried both the US and Japanese rom from the Smokemonster romset which I believe are No Intro roms so should be fine. I am using your latest firmware.
On another note, I noticed that none of my famicom controllers intended for the expension port are working on my system. I tried several Hori gamepads and a XE-1 Pro Controller. No button input would be recognized. Is there something I need to enable in the menu to make them work? I had to make an RGB Scart cable following Analogues instructions from their webpage to have my system work with my CRT TV which requires a connection to its USB port. Could it be that this disables the expansion port somehow? Sorry if this is a stupid question, but I actually have no possibility to check myself as I don't own a HDTV.
And finally here is a suggestion for the file browser. Since a lot of file or folder names cannot be displayed fully as for the low resolution on a CRT, would it be possible to implement scrolling of the name of the highlighted file or folder, similar to what a SD2SNES card would do? It's sometimes impossible to know which file exactly you're choosing when two files names only differ by something the display won't show.
Sorry for the lenghty first post and again, thanks for your hard work. I'll be following this project as well as any news on your Z3K which sounds very intersting as well.
Cheers
#2407 kevtris OFFLINE
kevtris
    Dragonstomper
  • 712 posts
  • FPGA Whisperer
Posted Thu Mar 23, 2017 2:57 AM
Hi kevtris,
Cheers
I mention that GG game in the readme.  it's an sms game that ran in sms mode on a game gear.  run it in SMS mode and it will work.  (load it thru the sms core).
the expansion port controller working or not depends on the game loaded.  it only works on NES/fami titles, and then when they support it in software.  i.e. SMB will support it, but other games like kirby's adventure might not.  It does not work on other cores than the nes/fami.
you only need the usb power if you are using SCART. if you're using BNCs then it's not needed and you just need one of those 5 BNC "pentapus" cables.
I don't have plans to change the menu interface now since it's so far along and I am going to be working on paid work soon so that will put a crimp on it.
#2408 snatcher1996 OFFLINE
snatcher1996
    Space Invader
  • 47 posts
Posted Thu Mar 23, 2017 3:05 AM
Yes I understand, thanks for clarification.
Have a good one!
#2409 Fafner OFFLINE
Fafner
    Star Raider
  • 80 posts
Posted Thu Mar 23, 2017 4:53 AM
Mac user here!
Haven't run into this issue with my NT Mini.
I've seen it on other devices (stuff from AtGames) but not on my Analogue
#2410 Daschewie OFFLINE
Daschewie
    Space Invader
  • 23 posts
Posted Thu Mar 23, 2017 6:57 AM
For Mac users, there is a free utility that removes both window and mac junk files on eject. I use this for my other flash carts with great success: http://macpaw.com/cleanmydrive
#2411 simbin OFFLINE
simbin
    Star Raider
  • 63 posts
Posted Thu Mar 23, 2017 12:04 PM
Kevtris,
How do we add custom bezel artwork around the display port on Game Gear core?
Can you please add menu functionality for Famicom Network Controller?
#2412 Vector OFFLINE
Vector
    Space Invader
  • 18 posts
Posted Thu Mar 23, 2017 5:02 PM
Thanks for all the hard work on the cores for the Analogue NT Mini. I can honestly say that the accuracy and attention to detail that the Analogue NT Mini delivers, has me enjoying the NES like I had years ago on my 27 inch CRT. For people like myself in cramped quarters in NYC having a system (without dragging out a tiny CRT) that I can play "Mike Tyson's Punchout" with no noticeable lag is truly amazing. I am looking forward to playing SMS as well!
#2413 cacophony OFFLINE
cacophony
    Moonsweeper
  • 482 posts
Posted Thu Mar 23, 2017 11:30 PM
@Kevtris, I'm not sure if this is intended, but there's a flow that allows you to quit a game without ever being prompted to save. It's a little convoluted to describe, but it actually happens quite naturally in practice:
1. Load a rom that has save ability (I picked The Legend of Zelda)
2. I wanted to start by modifying a video setting so I hit SELECT+DOWN to bring up the file browser. It prompts me if I want to "Save Game RAM?". I haven't done anything in the game yet, but I select "Yes".
3. I then hit START to enter the Settings menu. I change a setting and then hit SELECT to dismiss the Settings menu.
4. Then I play the game for awhile and make some progress, and eventually do an in-game save after dying.
5. Then I want to quit so I hit SELECT+DOWN. This time it takes me to back to the Settings menu (b/c that's where I was last), so I hit "A" to go back to the file browser.
6. Then I hit SELECT to quit the file browser and I get prompted with "Really Exit?", but there's never the prompt to save.
To save my game I would have had to know to do this instead for step 6:
6. Hit SELECT and pick "Back" when prompted to "Really Exit? to force the game to remain open
6.5. Then hit SELECT+DOWN to enter the file browser again. Because you're starting at the file browser this time it will prompt to "Save Game RAM?".
I imagine this issue is even more problematic (due to lack of menu prompt feedback) if you have "Always Save" selected instead of "Prompt" but I haven't tried it.
Edited by cacophony, Fri Mar 24, 2017 12:06 AM.
#2414 Pal251 OFFLINE
Pal251
    Space Invader
  • 24 posts
Posted Fri Mar 24, 2017 12:39 AM
@Kevtris
JBfirmware 1.8 fixed my audio problem for my Samsung monitor far as I can tell.
Thank you very much for your help and support for this console.
If there is anything I can do to help please let me know.. :)
#2415 kevtris OFFLINE
kevtris
    Dragonstomper
  • 712 posts
  • FPGA Whisperer
Posted Fri Mar 24, 2017 2:46 AM
Yeah this is kind of an issue but I am not 100% sure how to fix it.  It's because you exited back to the menu from somewhere other than the file browser.  It only performs the save check when exiting TO the file browser.  The workaround is to go back to the file browser after making settings changes.  If you forget, you can go back to the file browser, hit select then dismiss the menu to return to the game.  Then exit the game again and you will get the prompt.  If you go back to the cores menu, it will erase the RAM when you reload the game.
@Kevtris
great! glad it worked.  That should finish up audio issues then all around.
#2416 Radfoo OFFLINE
Radfoo
    Chopper Commander
  • 155 posts
Posted Fri Mar 24, 2017 4:38 AM
Hey Kevtris,
Been playing RC Pro AM and noticed the text on the track near the start line saying "RC Pro AM" flickers when using HDMI on my LCD. At first thought this was due to do the horizontal and width settings but this is not something I've been able to tweak away. Get no flicker with RGB on a CRT with the NT mini or original NES. Do you know a setting that would sort this or is this just a side effect of the scaling?
Mentioned this over on the thread about the video output and confirm someone else has noticed the same.
Thanks
Oli
Edited by Radfoo, Fri Mar 24, 2017 5:27 AM.
#2417 snatcher1996 OFFLINE
snatcher1996
    Space Invader
  • 47 posts
Posted Fri Mar 24, 2017 7:00 AM
I noticed in the Game Boy core that the title music of Rolan's Curse sounds completely off. I reckon the channels used here aren't accurate as of now.
The same goes for the same game on the Game Boy Color core, though it sounds different.
#2418 cacophony OFFLINE
cacophony
    Moonsweeper
  • 482 posts
Posted Fri Mar 24, 2017 10:04 AM
Not sure how easy these would be to implement but here are a couple ideas:
1. Bringing up the menu via SELECT+DOWN *always* starts with the file browser regardless of where last where. So you'll always get the save prompt.
or alternatively
2. Bringing up the menu via SELECT+DOWN *always* starts wit the Settings menu (and there's no save prompt on entry). But the Settings menu has a new entry for "Exit to roms...", and when you select that it does the save prompt. I like this method because it allows you to play with and dismiss settings without getting needless save prompts. It's also a consistent user experience when compared to outside the cores area in that SELECT+DOWN always brings up the Settings menu.
#2419 rezb1t OFFLINE
rezb1t
    Star Raider
  • 79 posts
Posted Fri Mar 24, 2017 3:18 PM
Bug report : Noticed that the Pokemon Trading Card Game won't boot in the Gameboy Color core, yet runs just fine in the Gameboy core.
This might be a known issue. Figured I may as well make sure!
Edited by rezb1t, Fri Mar 24, 2017 3:20 PM.
#2420 kevtris OFFLINE
kevtris
    Dragonstomper
  • 712 posts
  • FPGA Whisperer
Posted Fri Mar 24, 2017 4:13 PM
Well it's firmware friday again!   This time, it's Odyssey^2 including The Voice.   Since this is a system with a keyboard, I also finished the PS2 keyboard adapter.  These aren't for sale yet though, but I have included a schematic for those who wish to build it.  I have made it so start/select/A/X on the controller emulate pressing 1, 2, 3, 4 on the keyboard to allow most games to be started.  Only a couple really need the keyboard.
http://blog.kevtris....re_verJB1.9.zip
If you wish to build one, it only needs 6 parts.  It plugs into the fami expansion port on the nt mini.  I built it using a small PCB that fits fully inside the plastic back shell of the connector.  The mini DIN locks it in place, so I could cut the plastic ears off the back shell that normally retain the DB15 connector, without it falling apart.  This way it plugs into the mini and doesn't hit the enclosure.
Some pictures of the adapter below, and of my unique hot pink/purple mini, too.
Enjoy!
#2421 Fafner OFFLINE
Fafner
    Star Raider
  • 80 posts
Posted Fri Mar 24, 2017 4:48 PM
Enjoy!
I am beyond jealous of THAT NT mini!!!!
#2422 Namdor OFFLINE
Namdor
    Star Raider
  • 59 posts
Posted Fri Mar 24, 2017 5:07 PM
Thanks so much kevtris!!! I am not at home yet to test it out but on the new core and future systems that use keyboards rather than use or make a ps2 adapter can I use my family computer keyboard?
Thank you
#2423 jamon1567 OFFLINE
jamon1567
    Star Raider
  • 89 posts
Posted Fri Mar 24, 2017 5:14 PM
To follow up on Namdor's question, will the famicom network controller be supported for this core since it has a number pad itself?
#2424 simbin OFFLINE
simbin
    Star Raider
  • 63 posts
Posted Fri Mar 24, 2017 5:34 PM
Strange. I'm getting "File not found" when I attempt to load Oyssey^2 roms
Here's everything I did.
  1. Flashed latest v1.9 firmware
  2. Copied over SYSTEM/CORES/o2.cor
  3. Named all bios files according to readme
I don't see any other updated files. Did I miss something? Thanks
My mistake. Had dashes instead of underscores in the speech files. Oops :-)
Edited by simbin, Fri Mar 24, 2017 5:41 PM.
#2425 kevtris OFFLINE
kevtris
    Dragonstomper
  • 712 posts
  • FPGA Whisperer
Posted Fri Mar 24, 2017 5:53 PM
Thank you
not at this time
nope not yet
re: the galaxy of controllers possible to use on cores:  I don't have time right now to add half a dozen controllers to every core unfortunately.  I need to get the rest of these cores converted before I run out of time.  Deadlines on paid stuff are fast approaching so I am trying to get the last few cores released before that hits.  So unfortunately I can't do a lot of controller adding and stuff yet.  Eventually I hope to go back and add more options and things but for now I don't have the time.
Also tagged with one or more of these keywords: FPGA
7 user(s) are browsing this forum
2 members, 5 guests, 0 anonymous users
