_The Doctor__ Posted September 25, 2018 Share Posted September 25, 2018 You can either punch a hole opposite the s1 hole in the jacket or you can add an index faker or ir diode detector pair on the other side of the actual drive spindle. 2 Quote Link to comment Share on other sites More sharing options...
Bill Lange Posted September 26, 2018 Share Posted September 26, 2018 I'll try to create a raw stream tonight. I'll also look at the various solutions for side B. 3 Quote Link to comment Share on other sites More sharing options...
Bill Lange Posted September 28, 2018 Share Posted September 28, 2018 For Ultima I side one, is this the format you want? dtc -p -fultima_one_side_one\track_ -g2 -y -i0 -i2 -k2 -b-8 Side 2 might take a bit longer. I don't want to destroy the disk, so I need to modify a 5 1/4. Bill Quote Link to comment Share on other sites More sharing options...
Farb Posted September 28, 2018 Share Posted September 28, 2018 That command is if you have a floppy-modified drive. I'm assuming you don't so you would need: dtc -p ultima_one_side_one\track_ -g0 -y -i0 -i2 -k2 Quote Link to comment Share on other sites More sharing options...
Bill Lange Posted September 29, 2018 Share Posted September 29, 2018 Attached is a zip file containing U1 S1 using dtc -p -fu1_s1\track_ -g0 -y -i0 -i2 -k2 u1_s1.zip 2 Quote Link to comment Share on other sites More sharing options...
Farb Posted September 29, 2018 Share Posted September 29, 2018 (edited) Oops, sorry, I didn't type the -f. The dump looks great! Thank you for doing it! Are you able to generate an ATR from side B with a regular Atari drive? Edit: Also, what kind of drive did you use to make the dump? Edited September 29, 2018 by Farb Quote Link to comment Share on other sites More sharing options...
Bill Lange Posted September 30, 2018 Share Posted September 30, 2018 Ultima I Side 2 .atr attached. Copies from 1050 to AspeQt using Ultra Copy (with Translator) on an Atari 800XL. u1_s2_org.atr 2 Quote Link to comment Share on other sites More sharing options...
Farb Posted September 30, 2018 Share Posted September 30, 2018 Thanks, Bill. Your side B dump matches Atarimania's. It would still be great to eventually get a raw Kryoflux dump but this is super helpful! Quote Link to comment Share on other sites More sharing options...
Stechmann Posted December 21, 2023 Share Posted December 21, 2023 The Sega Master System version i find the best in terms of playability. Unfortunately they botched the music somewhat Quote Link to comment Share on other sites More sharing options...
