Atari 2600 Trak-Ball Games
Trak-Ball Track Ball Missile Command Centipede Reactor Millipede Challenge of... Nexar Marble Craze Plaque Attack
734 replies to this topic
#1 Omegamatrix OFFLINE
Omegamatrix
  • 6,233 posts
Posted Mon Oct 5, 2015 9:55 PM
As some of you may or may not know, Thomas Jentzsch and I have converted some 2600 games to use a Trak-Ball controller. Thomas originally converted Missile Command to use the trackball over a decade ago. More recently Thomas converted Centipede and Reactor. I joined the fun and did Millipede. The thread we posted the ROMs in wasn't really related... it all came about kind of spontaneously. icon_smile.gif That thread does contain a whole whack of routines if anyone is ever interested. It all starts on page 4 and goes for several pages.
Here in this thread are the latest ROMs, organized, for easy finding.
Note for CX80 Trak-Balls:
Atari CX80 Trak-Balls work the same as the CX22 Trak-Balls. However, some retailers modified the CX80's to be compatible with the ST Mouse (Atari Mouse). If you have a CX80 then you will have to try both the Trak-Ball and Atari Mouse ROMs to see which one works with your Trak-Ball, or try the detection ROM. It is believed only a small number of Trak-Balls were modified.
Note for CX22 Trak-Balls:
An early version of this controller only works in joystick emulation mode and cannot be used with these ROMs unless modified. Check for the presence of the "joystick/trakball" switch on the bottom left side to ensure that you have the later compatible version and set it in "trakball" mode.
Wico Command Controller Trackballs:
These trackballs don't work with these ROMs as is. However, the Wico Trackball can be converted to use the CX80 (Atari Mouse) ROMs. See here for details.
Bob Colbert's Homebrew which can use an Amiga Mouse, Atari Mouse, Driving Controller, or Joystick!
Link: Stell-A-Sketch (Bob Colbert)
Link: Trak-Ball/Amiga Mouse detection (TJ)
Roms: Attached File  Trak-Ball Detect v1.0.zip   2.46KB   427 downloads
Link: Missile Command TB (TJ)
Roms: Attached File  Missile_Command_TB_(TJ).zip   20.5KB   586 downloads
Roms: Attached File  Missile_Command_CX_22_v1.3_(TJ).zip   6.93KB   533 downloads
Link: Centipede TB (TJ)
Roms: Attached File  Centipede_TB_(TJ)_v1.4.zip   111.02KB   597 downloads
Link: Reactor TB (TJ)
Roms: Attached File  Reactor_TB_(TJ)_v1.3.zip   78.91KB   570 downloads
Link: Millipede Amiga and ST Mouse Info (Omega)
Attached File  Millipede(Trakball)v6.5.zip   141.67KB   253 downloads
Link: Challenge Of Nexar, The (TJ)
Roms: Attached File  Challenge_of_Nexar_TB_(TJ)_NTSC_V1.1.zip   8.56KB   432 downloads
Roms: Attached File  Challenge_of_Nexar_TB_(TJ)_PAL_V1.1.zip   17.12KB   356 downloads
Roms: Attached File  Challenge_of_Nexar_CX22_(TJ)_v1.2.zip   8.53KB   522 downloads
Link: SW_Arcade (Omega)
Roms: Attached File  SW_Arcade(Trackball)V4.zip   55.94KB   537 downloads
Roms: Attached File  SW_Arcade(Trackball)V4__Inverted_Y_Axis.zip   56.11KB   425 downloads
Link: SpaceMasterX7_(Omega)
Roms: Attached File  SpaceMasterX7_(Trackball).zip   52.97KB   480 downloads
Link: Missile Control (TJ)
Roms: Attached File  Missile_Control_TB_(TJ)_NTSC_V1.15.zip   9.71KB   323 downloads
Roms: Attached File  Missile_Control_TB_(TJ)_PAL_V1.15.zip   19.42KB   259 downloads
Link: Marble Craze (TJ)
NEW: Attached File  Marble_Craze_TB_(TJ)_NTSC_V1.0.zip   45.24KB   328 downloads
NEW: Attached File  Marble_Craze_TB_(TJ)_PAL_V1.0.zip   90.62KB   235 downloads
Edited by Omegamatrix, Wed Jan 16, 2019 12:50 AM.
Added Marble Craze 1.0 ROMs
#2 Albert ONLINE
Albert
  • 35,241 posts
Posted Mon Oct 5, 2015 10:10 PM
Thanks for starting this thread! More people will probably see these as a result, and it'll be easier to keep tabs of the latest versions in the first post.
..Al
#3 OldSchoolRetroGamer OFFLINE
OldSchoolRetroGamer
  • 5,538 posts
  • aka MaximumRD !
Posted Mon Oct 5, 2015 10:29 PM
Man I gotta get around to getting a Trak-Ball controller.
#4 Mitch OFFLINE
Mitch
  • 6,613 posts
  • 7800 Guy
Posted Tue Oct 6, 2015 9:29 PM
As some of you may or may not know, Thomas Jentzsch and I have converted some 2600 games to use a Trak-Ball controller. Thomas originally converted Missile Command to use the trackball over a decade ago. More recently Thomas converted Centipede and Reactor. I joined the fun and did Millipede. The thread we posted the roms in wasn't really related... it all came about kind of spontaneously. :) That thread does contain a whole whack of routines if anyone is ever interested. It all starts on page 4 and goes for several pages.
Here in this thread are the latest roms, organized, for easy finding.
Rom: attachicon.gifMissile_Command_TB_(TJ).zip
Rom: attachicon.gifCentipede_TB_(TJ)_v1.1.zip
Rom: attachicon.gifReactor_TB_(TJ)_v0.9.zip
Link: Millipede TB (Omega)
Rom: attachicon.gifMillipede_TB_(Omega)_v5.zip
I'm also working on a CX80 and Amiga rom of Millipede. I will update this post when it's ready, but it won't be real soon.
This is awesome!
Incidentally, you probably should call the CX-80 version the ST mouse version instead. The CX-80 is natively the same as the CX-22. Some were factory modified in the late 80s to be compatible with the ST mouse. ;)
Mitch
#5 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 18,399 posts
Posted Tue Oct 6, 2015 9:40 PM
This is awesome!
Mitch
I believe one of them used proper gray code. The other didn't. Is there a pinout to convert an arcade trackball (or a 5200 trackball) to Atari 2600? The arcade version use optical wheels for the encoder so you would need to tap VCC for the power source. And a bit of simple 74xx logic if the output does not match proper grey code.
Edited by stardust4ever, Tue Oct 6, 2015 9:43 PM.
#6 Bodyshots OFFLINE
Bodyshots
    Dragonstomper
  • 623 posts
Posted Tue Oct 6, 2015 10:05 PM
Thanks! A new folder for my Harmony Cart :)
#7 Albert ONLINE
Albert
  • 35,241 posts
Posted Tue Oct 6, 2015 10:10 PM
This makes me wonder what other 2600 games would be suitable for this treatment. Probably this was discussed in the other thread...
..Al
#8 davidbrit2 OFFLINE
davidbrit2
    Dragonstomper
  • 515 posts
Posted Fri Oct 9, 2015 4:14 PM
Holy damn, Millipede and Reactor already? Guess I'll be firing up the Harmony tonight.
#9 Albert ONLINE
Albert
  • 35,241 posts
Posted Fri Oct 9, 2015 4:21 PM
They are lots of fun with a Trak-Ball!!
#10 davidbrit2 OFFLINE
davidbrit2
    Dragonstomper
  • 515 posts
Posted Fri Oct 9, 2015 4:34 PM
Agreed, I just gave them a quick test. Millipede is super smooth, but needs a bit of speed adjustment. The shooter moves way too fast, particularly in the vertical direction. That ought to be a super simple change with all of the hard stuff out of the way, I would imagine.
#11 Omegamatrix OFFLINE
Omegamatrix
  • 6,233 posts
Posted Sat Oct 10, 2015 10:06 AM
I originally had the Y axis speed cut in half, and heard it was too sluggish. Maybe try playing Millipede (as it is now) for a while and see if you get use to it. I think after a while it will feel natural.
#12 BigO OFFLINE
BigO
  • 4,410 posts
Posted Sat Oct 10, 2015 11:27 AM
It sounds like I could tap into the signals just downstream from the encoder optics on one of the joystick-emulating 3rd party trackballs I have and run those signals as the output and have a "real" trackball. I may try that with a Wico trackball that I have with a bad microcontroller, (or a Microsoft Easy Ball Mouse, or a Philips Roller Controller, or a 5200 Trak Ball).
Edited by BigO, Sat Oct 10, 2015 11:31 AM.
#13 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 18,399 posts
Posted Sat Oct 10, 2015 2:45 PM
I was looking into arcade trackball controllers and while they are very expensive, the harness has a VCC and ground that power the controller, and outputs simple 5V logic on the XA, XB, YA, YB pins. This would be compatible with the Atari. Also since there are two standards, one of which has the outputs in the incorrect order, one could add a breadboard with some 74xx converter logic. I could hammer out a quick and dirty schematic if I had the truth table, and use either the genny chip, or dual ganged DPDT switches to select the output mode. Throw in a Dsub 15 pin and one could make it dual compatible with 2600/7800/8-bit and 5200. But the 5200 trackball is built up like a tank so no real reason to reinvent the wheel. Maybe it would be possible to add a  9-pin Dsub to the 5200 trackball to use with A2600/7800/8bit.
#14 BigO OFFLINE
BigO
  • 4,410 posts
Posted Sat Oct 10, 2015 3:53 PM
Would there be any particular benefit to implementing something other than the standard gray code? Referring specifically to the 2600, are there games that only support the non-standard version?
My Wico trackball actually has a PIC microcontroller in it now so could do pretty much whatever protocol was useful. I did one mode that scaled the relatively huge number of gray code transitions down to simulate a driving controller. Playing Indy 500 with a trackball was certainly not worth the effort. (Now if I can just find that controller... :ponder:)
Edited by BigO, Sat Oct 10, 2015 3:59 PM.
#15 sramirez2008 ONLINE
sramirez2008
  • 2,799 posts
  • Stella Foreva
Posted Sat Oct 10, 2015 9:02 PM
These games are amazing with TB capability. Been playing them for a few hours now. Thanks for making them available gents! :thumbsup: :thumbsup: :thumbsup: :thumbsup:
#16 Master Phruby ONLINE
Master Phruby
  • 9,728 posts
Posted Sat Oct 10, 2015 9:27 PM
Someone needs to convert star wars arcade game to use the trackball or the ST mouse.
#17 iesposta OFFLINE
iesposta
  • 3,886 posts
  • Retro-gaming w/my VCS
Posted Sat Oct 10, 2015 10:02 PM
I agree you have to adjust and get used to the trak-ball movement.
But before, in the first trak-ball version, it didn't feel like a trak-ball game when moving up was slower. I found myself spinning up very fast and it was lagging.
Also there is paddle-like jitter left/right/up/down, and probably no cycles left to add code to smooth it out.
Explanation: When playing with a stick, I start the game going to one spot left of center, just right of the DDT, sit there and take out most of 'pede #1. With a stick I can zoom over there and tap adjust to my spot, and start to fire, and only move when a spider hit is coming, or the 'pede #1 is nearing the bottom, so I need to go on the attack.
I play my same opening strategy with the trak-ball, but when I zoom there and get lined up and start firing, more often I'll end up hitting the DDT because the smallest movements slide the player all around.
Again, just explaining, not a complaint or request for a change.
If you have ever used trackball software on a computer, there is a curve adjustment in the Control Panel to set fast movement when moving fast (so you can get where you intend to click fast and without overshooting), and fine slow movement when you are moving slow (for detailed precise drawing, cursor placement, letter selection, etc.).
Understand that this is a primitive game console needing to read the trak-ball output "a lot of the time" and you wouldn't want to sacrifce quickly moving around for precision slight movements.
Correct me if I'm wrong, but there's only enough time to go with movement that is "a good balance" for the game play -- neither too fast nor too slow, right???
I'm amazed the impossible "add trak-ball to Millipede" was done, and that it involved much more than just finding ROM, RAM, re-coding kernels to run more efficiently, and finding cycles, but involved all that and the need to expand the ROM, move sections around, and it was all done in record time!
My already #1 favorite 2600 game in the "game play category", Millipede, just became a whole lot better!
#18 iesposta OFFLINE
iesposta
  • 3,886 posts
Posted Sat Oct 10, 2015 10:17 PM
Star Wars The Arcade Game.
Good suggestion!
I hadn't thought of that game, but I loved that title so much seeing what Parker Bros. achieved on the 2600, I had to collect it CIB.
It currently is slightly frustrating with joystick control.
I'd like to second that suggestion, and add that I'd play Crossbow with trak-ball control.
Currently to me Crossbow, both 2600 and 7800 versions, seem both too slow and too imprecise with joystick control to be enjoyable.
Imprecise light gun shooting is tolerable because, well, it's like shooting!
I would like any "shooting gallery" game with trak-ball added, before Crystal Castles, the only other arcade trak-ball game i can think of that made it to the 2600.
Even Carnival, but Carnival is too crippled missing the bears stage, and could play better with Paddle added.
#19 Lynxpro OFFLINE
Lynxpro
  • 3,736 posts
Posted Sun Oct 11, 2015 8:46 AM
Good suggestion!
I made this separate thread prior to the creation of this one concerning suggestions for more 2600 games to add Trak-Ball support to:
http://atariage.com/...-support-added/
Crossbow definitely needs it.  As I've mentioned in the 7800 - relevant here since the 7800 has a lot more light gun games than the 2600 obviously does - threads before, any light gun game would be ideal candidates for adding Trak-Ball support to considering the whole modern LCD TV issue.
Star Wars the Arcade Game would be an interesting choice. It's also an amusing choice because on the 5200 side back in the day, Dan Kramer, the Atari Inc engineer who created Atari's consumer Trak-Balls, was working on a 5200 Yoke Controller [using Atari's arcade Star Wars yoke controller] for such games. That and a 5200 Driving Controller [using the Steering Wheel and Shifter from Atari arcade Pole Position] but the industry crash put the kibosh on those projects of his. Essentially, management killed those projects as they had already committed to the 7800 as their future.
#20 Omegamatrix OFFLINE
Omegamatrix
  • 6,233 posts
Posted Sun Oct 11, 2015 11:07 PM
I now have working versions of Millipede for CX80 Trak-Balls that were modded to be like the ST Mouse, and an Amiga Mouse version. I'm just working on reducing the cycles I use in overscan. Expect some trial roms soon.
#21 Omegamatrix OFFLINE
Omegamatrix
  • 6,233 posts
Posted Mon Oct 12, 2015 12:25 PM
Here is the basic code for the Amiga and ST mouse versions for those who are interested:
    LDX    SWCHA                 ;4  @4
    LDA    lastTrack             ;3  @7
    ORA    SwchaTab,X            ;4  @11    shift 4 and ORA quickly...   lastTrack | (newTrack >> 4)
    STX    lastTrack             ;3  @14
    TAX                          ;2  @16
    LDA    MovementTab,X         ;4  @20    indexes diffA to diffD, or a trash register
    TAX                          ;2  @22
    BMI    .dec                  ;2³ @24/25
    INC    diff,X                ;6  @30
    JMP    .rejoin               ;3  @33
.dec:
    NOP                          ;2  @27
    DEC    diff-$80,X            ;6  @33
.rejoin:
SWACNT has been set to output on bits 3-0, and a zero is outputted on them so that when SWCHA is read it is always xxxx0000. The code essentially joins the old state of SWCHA with the new, and uses it to reference a one page look up table to find a state to increment or decrement. The states I chose are as follows:
diff   = $7F      ; undefined register for read/write, used when no change for X and Y
diffA  = diff+1   ; [inc] Y = no change, X = right 1    [dec] Y = no change, X = left 1
diffB  = diff+2   ; [inc] Y = up 1, X = no change       [dec] Y = down 1, X = no change
diffC  = diff+3   ; [inc] Y = down 1, X = right 1       [dec] Y = up 1, X = left 1
diffD  = diff+4   ; [inc] Y = up 1, X = right 1         [dec] Y = down 1, X = left 1
I aligned diffA to be zp location $80, and made use of zp $7F as a trash register (to save a byte of ram). These states get summed together in overscan to give a signed differential direction change:
  MAC FIND_Y_DIFF
    CLC                          ;2  @2
    LDA    diffB                 ;3  @5
    ADC    diffD                 ;3  @8
    SEC                          ;2  @10
    SBC    diffC                 ;3  @13
    STA    diffY                 ;3  @16  +/- value to change Vpos
  ENDM
  MAC FIND_X_DIFF
    CLC                          ;2  @2
    LDA    diffA                 ;3  @5
    ADC    diffC                 ;3  @8
    CLC                          ;2  @10
    ADC    diffD                 ;3  @13
    STA    diffX                 ;3  @16  +/- value to change Hpos
  ENDM
That's pretty much it. I only count one step changes. Two steps changes are ignored.
#22 Omegamatrix OFFLINE
Omegamatrix
  • 6,233 posts
Posted Mon Oct 12, 2015 12:35 PM
Millipede Amiga and ST Mouse versions added to the first post. If you have a CX80 Trak-Ball then you'll have to try it with the CX22 version of Millipede and the ST Mouse version of Millipede to see which one is compatible. Atari at some point started modifying the CX80 to be compatible with the ST Mouse, but it seems like most of the CX80's are the same as the CX22.
Please report any bugs. For example the bugged version of Millipede CX22 played all the way to 160,000 points before it started freezing.
Otherwise enjoy. :)
#23 Omegamatrix OFFLINE
Omegamatrix
  • 6,233 posts
Posted Mon Oct 12, 2015 5:02 PM
These are the bit patterns for each Trak-Ball, or Mouse. This is for using the left "P0" controller port for the Trak-Ball or Mouse.
; CX22 TRAK-BALL
;       SWCHA
;      76543210
;      ||||not used
;      |||X direction (1=Right,0=Left)
;      ||X state (one bit)
;      |Y direction (1=Down,0=Up)
;      Y state (one bit)
;                  SWCHA     SWCHA
; LEFT   (00,10)  xx00xxxx  xx10xxxx
; RIGHT  (01,11)  xx01xxxx  xx11xxxx
; UP     (00,10)  00xxxxxx  10xxxxxx
; DOWN   (01,11)  01xxxxxx  11xxxxxx
; Example: Moving DOWN
;   1st sample (01) 01xxxxxx    (initial state can be any DOWN state)
;   2nd sample (11) 11xxxxxx
;   3rd sample (01) 01xxxxxx    (sequence starts to repeat)
;   4th sample (11) 11xxxxxx
;   5th sample (01) 01xxxxxx    (sequence repeats, again...)
;   6th sample (11) 11xxxxxx
; ST MOUSE (Some CX80s are wired like this too)
;       SWCHA
;      76543210
;      ||||not used
;      ||X state (two bits)
;      Y state (two bits)
;                        SWCHA     SWCHA     SWCHA     SWCHA
; LEFT   (00,01,11,10)  xx00xxxx  xx01xxxx  xx11xxxx  xx10xxxx
; RIGHT  (00,10,11,01)  xx00xxxx  xx10xxxx  xx11xxxx  xx01xxxx
; UP     (00,01,11,10)  00xxxxxx  01xxxxxx  11xxxxxx  10xxxxxx
; DOWN   (00,10,11,01)  00xxxxxx  10xxxxxx  11xxxxxx  01xxxxxx
; Example: Moving RIGHT
;   1st sample (11) xx11xxxx    (initial state can be any RIGHT state)
;   2nd sample (01) xx01xxxx
;   3rd sample (00) xx00xxxx
;   4th sample (10) xx10xxxx
;   5th sample (11) xx11xxxx    (sequence starts to repeat)
;   6th sample (01) xx01xxxx
; AMIGA MOUSE
;       SWCHA
;      76543210
;      ||||not used
;      |||Y state (1 of 2 bits)
;      ||X state (1 of 2 bits)
;      |Y state (2 of 2 bits)
;      X state (2 of 2 bits)
; LEFT   (00,10,11,01)  0x0xxxxx  1x0xxxxx  1x1xxxxx  0x1xxxxx
; RIGHT  (00,01,11,10)  0x0xxxxx  0x1xxxxx  1x1xxxxx  1x0xxxxx
; UP     (00,10,11,01)  x0x0xxxx  x1x0xxxx  x1x1xxxx  x0x1xxxx
; DOWN   (00,01,11,10)  x0x0xxxx  x0x1xxxx  x1x1xxxx  x1x0xxxx
; Example: Moving UP
;   1st sample (10) x1x0xxxx    (initial state can be any UP state)
;   2nd sample (11) x1x1xxxx
;   3rd sample (01) x0x1xxxx
;   4th sample (00) x0x0xxxx
;   5th sample (10) x1x0xxxx    (sequence starts to repeat)
;   6th sample (11) x1x1xxxx
#24 iesposta OFFLINE
iesposta
  • 3,886 posts
Posted Wed Oct 21, 2015 9:13 AM
So Thomas and Omegamatrix, what does it feel like to hear that the creator the the Atari Trak-Ball is amazed and overjoyed that these hacks were made?
It must have been a letdown designing a true trackball mode, and then have no 2600 or 7800 games use that mode (just the less accurate joystick compatible mode).
I never owned ColecoVision Roller Controller or Atari 5200 trackball controllers, so I can't comment on those.
Otherwise enjoy. :)
#25 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,972 posts
  • Always left from right here!
Posted Wed Oct 21, 2015 9:19 AM
I feel more or less neutral. It took him 12 years to notice. :)
Also tagged with one or more of these keywords: Trak-Ball, Track Ball, Missile Command, Centipede, Reactor, Millipede, Challenge of... Nexar, Marble Craze, Plaque Attack
