Tip: working from dropbox
rb+ Dropbox yech barf urgl
6 replies to this topic
#1 ggn OFFLINE
ggn
  • 1,472 posts
Posted Wed Oct 7, 2015 2:39 PM
Ah, Dropbox.
I hate it.
First time I tried to use it, it was because some friends wanted to share their project with me. I ended up deleting all files in the folder (because modern hipster tool programmers can't code for shit apparently) and everyone scrambling to find backups because back then there was no undo on deletion. Ossom service and all.
Anyway, people told me that they actually try to use rb+ with dropbox to sync their projects. The problem apparently is that some times during build, the process will fail, usually when makelink is running. I can only assume that dropbox is trying to sync the build folder and at the same time build.bat is running and is trying to overwrite files in use by the sync. After offering my condolences for using such a shit program, I can offer a fix for this:
You need to make dropbox not sync the "build" folders inside your projects. Now, because hipsters can't code for shit, there's no clean way to do this, but you have to use a workaround apparently. It is explained here. In short, you need to create a folder called "build" in your dropbox root folder, then make it un-syncable, THEN move it to the project folder. It will probably work. I didn't try it. I'm not sure it'll fix the random build errors people report. Try it and tell me.
(nope, sorry, really dislike dropbox - whatever happened to good old floppies to sync files between computers? ;))
#2 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 538 posts
  • Probably RB+ing
Posted Wed Oct 7, 2015 2:45 PM
or just don't forget to copy your working folder into your dropbox before leaving PC  :D
#3 Shamus OFFLINE
Shamus
    Dragonstomper
  • 669 posts
  • Moo, er, Roar!
Posted Thu Oct 8, 2015 7:30 PM
I was going to say, what ever happened to developing off of a flash drive? That's how I did it BITD. :D
#4 CyranoJ OFFLINE
CyranoJ
    RAPTOR Wrangler
  • 5,816 posts
  • reBOOTed
Posted Thu Oct 8, 2015 7:56 PM
Or stop the dropbox service at the top of the build script and (maybe) start it again at the end.
ADMIN POWA FTW!
(btw, F**K dropbox)
#5 ggn OFFLINE
ggn
  • 1,472 posts
Posted Thu Oct 8, 2015 11:33 PM
That's not a bad idea but starting and stopping services on windows takes precious seconds which I'm not comfortable with.
On a related topic, googling for 10 seconds sent me here, where it says that there is a cli interface for dropbox that can start and stop it ...but you have to install more hipster bullshit slowdown crap (i.e. Python). (insert random profoundprogrammer image here).
#6 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 538 posts
  • Probably RB+ing
Posted Fri Oct 9, 2015 12:50 AM
Yeah adding specific things to the build to cater for the possibility someone has certain software sucks. It's the end users problem, not yours ggn.
Insert a flash drive? What is this trickery?  ;)
#7 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 538 posts
  • Probably RB+ing
Posted Fri Oct 9, 2015 12:55 AM
Attached File  1 fast programmar.gif   44.45KB   1 downloads
Click image for realistic example of dropbox syncing
Edited by Sporadic, Fri Oct 9, 2015 12:56 AM.
Reply to this topic
Also tagged with one or more of these keywords: rb+, Dropbox, yech, barf, urgl
