WIP Kaboom!
Kaboom Raptor Basic
34 replies to this topic
#1 omf OFFLINE
omf
    Dragonstomper
  • 782 posts
Posted Tue Oct 13, 2015 5:06 PM
Ok, i have been working on this for a month or so in the evenings / night after work and i think its coming along nicely now
in the current version i have tried to include most of the features of the original atari 2600 game:
8 levels
8 speeds
8 different point amounts for collecting the bombs in the bucket
this version does not follow the same bomb dropping as the atari 2600, i decided to spice it up a little and use some degree of randomness (based on the x position of the bomber and the x position of the player for the seed
some features are not included as yet, the item that most concerns me is the extra life every 1000 points, i may be over thinking this quite substantially but to me right now this seems to be very complicated.  you cant check dead on 1000 / 2000 etc because if your at 995 then earn 10 points you are at 1005 and the check will not catch it.  using greater than would cause a new life to be added every program loop if the score higher than 1000 which is not wanted
i tried to use:
if (score / new_life_points) = cint(score / new_life_points), this caused its own issues, mainly because the jaguar as i understand it does not take kindly to decimal numbers and in my tests 995/1000 although should equal 0.995, the jaguar decides it equals 0.  Nice!!!   this option is however thinking about it no good because it still only basically gives you if score = 1000.
so for the moment im at a loss on that one, if anyone has any ideas let me know :)
moving on,
there are only two sound samples integrated currently, the explosion sound and a splash sound
all sprites are 16 colours
i hope to work on this beautifying it somewhat in the future, as i am quite enjoying actually making something useful for the jaguar
things to do:
new life every 1000
change bombers face to smile at 10000
add rotary support, which I don't think can be tested in VJ
add title / options / game over screens
achievements - i am undecided on this one yet
add a selection of bombs to use
add a selection of buckets to use
probably a load of things I haven't listed
thanks goes to:
CJ / GGN / SH3 for continued abuse comments and help and putting up with my stupid questions at times which has lead to the creation of this spaghetti bowl of bad code :)
if anyone has any useful criticism, please post it here, i shall be keeping an eye on the thread to see what people think of this
#2 CyranoJ OFFLINE
CyranoJ
    RAPTOR Tamer
  • 5,600 posts
  • reBOOTed
Posted Tue Oct 13, 2015 5:48 PM
Have a variable called highscore_check set it to 1000
then if score>highscore_check do
  highscore_check=highscore_check+1000
  lives=lives+1
end if
don't forget to reset it at the start of each game.
Edited by CyranoJ, Tue Oct 13, 2015 5:49 PM.
#3 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 516 posts
  • Probably RB+ing
Posted Wed Oct 14, 2015 12:14 AM
Excellent, sounds great. I'll definitely give it a go later on and feedback any thoughts, cheers
#4 sh3-rg OFFLINE
sh3-rg
  • 3,396 posts
  • doge + tie = dothemath
Posted Wed Oct 14, 2015 12:16 AM
Good on you OMF for working on that and posting the binary.
#5 ggn OFFLINE
ggn
  • 1,433 posts
Posted Wed Oct 14, 2015 9:31 AM
Hi omf - good stuff in there! I'm always glad to see people picking up and giving rb+ a spin!
i tried to use:
Well, that's mostly C dickiness there. I assume you have "score" and "new_life_points" declared as integers - if so then when you try to divide those two variables C will take a look at the types and sizes and decide what's best for it. In this case it will probably do a long integer division, and this will result in an integer! I then expect cint to do nothing since the number will be already integer.
So, with that out of the way let me offer a few suggestions on what you can do.
The first solution would be to use floats, so your snippet above will most certainly work (if it doesn't, let me know!). However I do NOT suggest this as the floating point lib bundled with the compiler rb+ uses (gcc) is really slow.
Ah, I just noticed the CJ has posted a good suggestion there as well. Saves me some time then! A small variation would be to have an array of extra live scores and check against that. Something like
set highscores as int
  1000,2000,5000,10000,20000,999999999
end set
dim current highscore_index as short=0
then in your main loop
if score>highscores[highscore_index] then
lives=lives+1
 if highscore_index<ubound(highscores) then
  highscore_index=highscore_index+1
 endif
endif
Hope this helps, and again keep up the good work!
Edited by ggn, Wed Oct 14, 2015 9:32 AM.
#6 sh3-rg OFFLINE
sh3-rg
  • 3,396 posts
Posted Wed Oct 14, 2015 9:34 AM
GGN's solution is a bit better as it's more flexible, but also means you have to define the full set of possibilities.
#7 GroovyBee OFFLINE
GroovyBee
    Games Developer
  • 9,821 posts
  • Busy bee!
Posted Wed Oct 14, 2015 9:52 AM
A technique I've used on lesser machines than the jag for increasing lives, is to look at the score after its been BCD converted. Specifically the digit of the decade that increments the life counter. If its not the same as the last time I checked it, add one to the lives and save the new "digit" value. This might be applicable to RB+, but it all depends on what kind of buffers are exposed to the BASIC language itself.
#8 Kiwi OFFLINE
Kiwi
  • 1,625 posts
Posted Wed Oct 14, 2015 12:48 PM
I'm making a Kaboom clone for the Intellivision. So my solution to increase the lives by 1 whenever the 1000th digit is added.  Every digits is it own variable since I didn't want the 6 zeros to be drawn and wanted to be like the Atari 2600.  Pretty much my procedure for the scores are,
AddScore:procedure
sc(5)=sc(5)+pointvalue
if sc(5)>=10 then sc(4)=sc(4)+1:sc(5)=sc(5)-10:flag5=1
if sc(4)>=10 then sc(3)=sc(3)+1:sc(4)=sc(4)-10:flag4=1
if sc(3)>=10 then sc(2)=sc(2)+1:sc(3)=sc(3)-10:flag3=1:SL2=66:SPointer2=0:lives=lives+1:gosub loadlives
if sc(2)>=10 then sc(1)=sc(1)+1:sc(2)=sc(2)-10:flag2=1:wait:define 6,1,ohface
if sc(1)>=10 then sc(0)=sc(0)+1:sc(1)=sc(1)-10:flag1=1
if sc(0)>=10 then sc(1)=sc(1)-10
return
end
drawscore:procedure
if flag1=1 then print at 7,$800+320+(sc(0)*8)+6
if flag2=1 then print at 8,$800+320+(sc(1)*8)+6
if flag3=1 then print at 9,$800+320+(sc(2)*8)+6
if flag4=1 then print at 10,$800+320+(sc(3)*8)+6
if flag5=1 then print at 11,$800+320+(sc(4)*8)+6
print at 12,$800+320+(sc(5)*8)+6
return
end
It is kinda obsessive to use a single variable to hold a binary digit, but the solution works and still have variables left to use.
#9 omf OFFLINE
omf
    Dragonstomper
  • 782 posts
Posted Wed Oct 14, 2015 1:40 PM
  lives=lives+1
end if
with small modification i think this option is the best one for me and the game :)
i integrated it  today while at lunch at work :)
end set
lives=lives+1
 endif
endif
danm c++. i still struggle with c quite a lot, i do dabble with arduino stuffs but im still shite at the language, i end up giving up when it spews out some weird errors as i have no idea how to fix stuff lol
im pretty sure i had some issues with the set command, something about if it was defined in a subroutine if it was called more than once the array would contain zeros if i remember.
AddScore:procedure
return
end
drawscore:procedure
return
end
humm i dont think i will be attempting an intellivision game any time soon, that looks far too complicated for a score system LOL
#10 ggn OFFLINE
ggn
  • 1,433 posts
Posted Wed Oct 14, 2015 1:51 PM
Arduino Basic+ maybe? :D
#11 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 516 posts
  • Probably RB+ing
Posted Wed Oct 14, 2015 2:12 PM
Rb+ at work lunch for the win!!!!!
#12 ggn OFFLINE
ggn
  • 1,433 posts
Posted Thu Oct 15, 2015 12:52 AM
Also:
be nice if someone reported an example where this fails. Perhaps it was memory corruption?
#13 omf OFFLINE
omf
    Dragonstomper
  • 782 posts
Posted Thu Oct 15, 2015 2:13 AM
Also:
i thought i would give it a rest with reporting issues that 95% of the time were actually my issues LOL
ill look into it again, i may have another mess of code that causes this to error saved in a project
#14 ggn OFFLINE
ggn
  • 1,433 posts
Posted Thu Oct 15, 2015 3:51 AM
It's quite ok really! That 5% is always worth investigating.
#15 omf OFFLINE
omf
    Dragonstomper
  • 782 posts
Posted Wed Nov 25, 2015 6:05 PM
ok, i have been working on this for some time now in part this and the list editor i have released
this has been the guinea pig for list editor work
latest version is attached
some stuff still needs adding and fixing, but all in all i think this is coming along nicely
finally got round to fixing the issue where if you die it takes ages to destroy all the bombs
#16 sh3-rg OFFLINE
sh3-rg
  • 3,396 posts
Posted Thu Nov 26, 2015 1:05 AM
That's really coming together - good work, omf!
Looking forward to spinner controls, it'll really take it to the next level fun-wise.
Edited by sh3-rg, Thu Nov 26, 2015 1:07 AM.
#17 omf OFFLINE
omf
    Dragonstomper
  • 782 posts
Posted Thu Nov 26, 2015 3:02 AM
is there an example of spinner code for rb+?,i dont recall seeing any.
i don't mind trying to get it working but may need a little nudge with working code so i know what i'm doing
#18 sh3-rg OFFLINE
sh3-rg
  • 3,396 posts
Posted Thu Nov 26, 2015 3:27 AM
If you're using zero player it's super easy, will chat later.
#19 omf OFFLINE
omf
    Dragonstomper
  • 782 posts
Posted Thu Nov 26, 2015 6:38 PM
had a go at getting rotary working tonight, it mist have been a wery poor attempt as all i could get by checking zero_rotary_delta was 0
i did enable it (i think) with
Input_SetJoyPort2
Input_SetRotaryMode
#20 sh3-rg OFFLINE
sh3-rg
  • 3,396 posts
Posted Fri Nov 27, 2015 12:54 AM
You have to do stuff in the right order, will chop it out of my game later and post.
#21 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 516 posts
  • Probably RB+ing
Posted Fri Nov 27, 2015 1:36 AM
Also, did you remember to enable zeroplayer in the rapapp.s ?
Edited by Sporadic, Fri Nov 27, 2015 1:36 AM.
#22 sh3-rg OFFLINE
sh3-rg
  • 3,396 posts
Posted Fri Nov 27, 2015 1:46 AM
Yep, do them in the other order:
CALL Input_SetRotaryMode
CALL Input_SetJoyPort2
Then just sub zero_rotary_delta from your 16.16 x-pos. Instead of <<16, I did <<17 to make it more responsive.
xpos=xpos-(zero_rotary_delta<<17)
Moves really slick, and so damn simple!
#23 omf OFFLINE
omf
    Dragonstomper
  • 782 posts
Posted Tue Dec 1, 2015 7:23 PM
rotary support added to the game now including main menu and achievement screen (which is not working yet)
game detects dpad and rotary in joypad port 1
have fun!
#24 Sporadic OFFLINE
Sporadic
    Dragonstomper
  • 516 posts
  • Probably RB+ing
Posted Wed Dec 2, 2015 1:38 AM
Another reason for me to get off my arse and convert my second joypad. Really must get on that :)
#25 omf OFFLINE
omf
    Dragonstomper
  • 782 posts
Posted Mon Jan 11, 2016 6:14 PM
achievements added which are not saved as yet
various bugs / issues fixed
the file name issue of 'bomb.bmp' took far to long to realise that that was the problem!!! :(
play / test / give feed back (if you can be bothered)
I don't care either way ;-) :P
option screen and achievement saving is next up
Reply to this topic
Also tagged with one or more of these keywords: Kaboom, Raptor, Basic
