.BIN Repository - Images for burning cartridges (8/20/2017)
BLUE GREEN BLACK RED YELLOW
310 replies to this topic
#301 Lee Stewart OFFLINE
Lee Stewart
  • 3,315 posts
Posted Fri Jun 23, 2017 5:22 AM
Not sure why I'm finding this difficult - I'm searching for cart images that will specifically work with a Green Cart (not 128k hacked). Is there a general image type I should be looking for (like all 32k images should work or something?). I just received 20 x 27512 eeproms and want to start playing around with cart images but don't know what I can use and what will not work at all with this cart. My first attempt, at some point this afternoon will be Turboforth. i understand i should fill the cart when dealing with smaller (8k) bins so there is no empty space. And I understand that it's the same bin. Like for Turboforth; Since it is only 8k, I should fill the eeprom space with that very same TF image. I may have asked this before but cannot locate the answer.
The TurboForth binary is 16 KiB, not 8 KiB.  You will need to copy it 4 times to fill a 27512.
[Edit]  Also, binaries for the green boards must have their banks in inverted order.  If they are in normal (non-inverted) order, you will need to re-order them before burning the 27512.
fbForth 2.0 is 32 KiB, so you would need two copies in the 27512.
Both TurboForth and fbForth 2.0 binaries are supplied in inverted order, so you will not need to re-order the banks. [/Edit]
...lee
#302 Sinphaltimus OFFLINE
Sinphaltimus
  • 1,928 posts
  • Distracted at the Keyboard
Posted Fri Jun 23, 2017 6:00 AM
Awesome Lee, thanks. What about other bins? If they are inverted and 512KiB or smaller, they will work with green board (using same copy rules for various sizes)?
#303 Ksarul OFFLINE
Ksarul
  • 4,129 posts
Posted Fri Jun 23, 2017 8:09 AM
Most BIN files that were 64K and smaller were designed for the Inverted (Green or Black) boards. 128K files were for Black boards or hacked green boards. Anything larger than that was in the non-inverted format for the Red or Yellow boards. One note: the files (no matter what their size) in the FlashROM thread are non-inverted, IIRC, so not suitable without inverting them (Rasmus made a nice tool to do that)..
#304 Lee Stewart OFFLINE
Lee Stewart
  • 3,315 posts
Posted Fri Jun 23, 2017 8:11 AM
Yes—as long as the programmer forces startup to the correct bank, which I know is the case with TurboForth and fbForth 2.0.
[Edit] The 27512 EPROMs are 64 KiB—not 512 KiB.  They contain 512 Kib, i.e., 512 x 210 bits, which is the same as 64 KiB, i.e., 512 x 210 bits/(8 bits/byte) = 64 x 210 bytes.  [/Edit]
...lee
#305 Sinphaltimus OFFLINE
Sinphaltimus
  • 1,928 posts
Posted Fri Jun 23, 2017 8:40 AM
And that tool is? :)
Not that I'd want to burn anything already suited for the FR99 but to add another tool to the toolbox in case of future need. I'm probably going to install a better socket for easily inserting and removing chips. Any recommendations on that - A ZIFF socket is what I've ready elsewhere.
EDIT: BTW - I've now made it a habit to "Print to PDF" all this info and saved logically on my PC for future reference. sometimes I lose these things and my search kung fu isn't that great. So thanks.
Edited by Sinphaltimus, Fri Jun 23, 2017 8:41 AM.
#306 Lee Stewart OFFLINE
Lee Stewart
  • 3,315 posts
Posted Fri Jun 23, 2017 9:12 AM
To further clarify my last post:
As long as the number of 8 KiB banks in the binary you want to burn to a 27512 EPROM evenly divides the number of banks ( 8 ) in the EPROM, you are safe just filling it with copies of the binary.  This would be true for a binary of 1, 2, 4, 8 banks, i.e., 8, 16, 32 or 64 KiB.  I am pretty sure there are no binaries produced for EPROM by this community that do not meet the above criteria.  However, if there were, you would need to insure that the binary gets copied from the top down.  Otherwise, the bank select codes would not work.  I will explain this in greater detail later today unless someone beats me to it.  Gotta run right now.  TTFN
...lee
#307 Lee Stewart OFFLINE
Lee Stewart
  • 3,315 posts
Posted Fri Jun 23, 2017 10:08 PM
OK...Here is the promised bank-switching dissertation:
To switch to a particular bank in cartridge space (>6000 – >7FFF), you must perform a write operation to the selector address that corresponds to the desired bank.  For banks in an 8-bank ROM selected by a normal-mode latch, start at >6000 and increment by 2 for each successive bank:
      Selector
Bank  Address
 0    >6000
 1    >6002
 2    >6004
 3    >6006
 4    >6008
 5    >600A
 6    >600C
 7    >600E
 In normal mode, bank 0 is always selected by writing to >6000.
 When a latch is used in inverted mode, writing to >6000 selects the highest bank.  For an 8-bank inverted ROM:
      Selector
Bank  Address
 0    >600E
 1    >600C
 2    >600A
 3    >6008
 4    >6006
 5    >6004
 6    >6002
 7    >6000
 Now, you see, bank 0's selector will be different for differently sized ROMs.  For an inverted, 2-bank ROM like TurboForth, it will be:
      Selector
Bank  Address
 0    >6002
 1    >6000
 For an inverted, 4-bank ROM like fbForth 2.0, it will be:
      Selector
Bank  Address
 0    >6006
 1    >6004
 2    >6002
 3    >6000
So, now you can see that for TurboForth to work in an 8-bank EPROM, you only need to put the working binary in the upper 16 KiB and insure that all of the other banks duplicate the startup code that switches to the startup bank.  Of course, if you don't know which bank that is and which label is the entry point, it is enough to copy the binary to each 16 KiB section below the working binary.  If, for example, the TI-99/4A starts up in bank 2, CLR @>6000 is executed, which switches to bank 7 (see 8-bank table) of the 27512 EPROM.  This happens to be bank 1 of the 2-bank TurboForth binary, which now is situated in the highest bank (7) of our 27512 EPROM—and, off it goes.  In fact, for both banks of TurboForth, the startup code switches unconditionally to bank 1 (bank 7 of our 8-bank EPROM).
Pretty much the same thing happens with fbForth 2.0 in that bank 1 is the initialization bank with every other bank switching to it with a CLR @>6004 (see 4-bank table).  By inspecting the 8-bank table, you can easily see that writing to >6004 switches to bank 5 of the 27512 EPROM.  Again, it is the upper 32 KiB of the 8-bank EPROM where all the action is.
 I do hope this is a little clearer than mud.  Let me know.
 ...lee
#308 Sinphaltimus OFFLINE
Sinphaltimus
  • 1,928 posts
Posted Sat Jun 24, 2017 11:38 AM
Lee - I understood everything you typed and the charts make it perfectly clear. I do not understand the actual process though in regards to LINKS. Are those LINKS already encoded in the data?
So essentially I just copy the data in to the eprom programmer software according to your chart layout for inverted banks switching?
So for a green board I can use 8, 16, 32 and 64k files. I start at bank 8 and count backwards until I have enough 8k banks to store the entire file, than I do the same in the empty space that's left to count backwards how many more banks I need for the data to fit and continue until all the space is full? So for 8k it would be 64 times on a 27512, 16k file would be 32 times for a 27512, ...then 8 times for a 64k file? 128k or higher not supported on the green board (128k only with hack).
Do I have that correct?
#309 Ksarul OFFLINE
Ksarul
  • 4,129 posts
Posted Sat Jun 24, 2017 11:53 AM
Remember: the file is 8K Bytes, so that would be 64K bits in the ROM chip. The 512 in the chip is based in bits, so it holds 8 of the 8K Byte files (64K bits x 8=512K Bits). Use the answers I gave you for each chip type to figure out the right chip sizes for what you are trying to do. . .  :)  Have fun--a lot of folks get tangled in the interpretation of chip sizes at first, but once it sinks in, you'll be golden.  :)
#310 Sinphaltimus OFFLINE
Sinphaltimus
  • 1,928 posts
Posted Sat Jun 24, 2017 4:46 PM
Awesome. Lets see, right click - print to pdf....Thanks guys.
Edited by Sinphaltimus, Sat Jun 24, 2017 4:46 PM.
#311 --- Ω --- OFFLINE
--- Ω ---
  • 10,366 posts
Posted Sun Aug 20, 2017 5:37 PM
There are probably some files I've overlooked including recently due to time and scheduling constraints.  If you've posted any new .BIN's in the last 30 days or so, could you please post me a PM with a link to the message/thread.  Once I get it, I can link it here so others in the future can more easily find and enjoy your work.
Thanks,
Ω
Also tagged with one or more of these keywords: BLUE, GREEN, BLACK, RED, YELLOW
